#1 |
Member#: 341005
Tri-State
i just bought a accessport and now im looking at the boost levels and i wondering how much but should i be running for a stage1 93 + sf? i have peaked 19.1 psi i figured thats a lil to high so if i want it down futher i would have to download the low waste gate map off cobb correct?
thanks cory
#2 | |
Member#: 258219
South East
Vehicle:2011 WRX Limited WR Blue Pearl |
![]() Last edited by shamrocker; 02-03-2013 at 10:10 PM. |
#3 | |
NASIOC Manufacturer
Member#: 4803
Based on your screen name, I'm assuming this is a 13' WRX? If so, the peak boost target for the stage 1+SF 93 map is 17.5 psi, so you are overboosting a bit. What you'll want to do is download the low wastegate (LWG) map from the maps section at cobbtuning.com. Use the Accessport Manager software to transfer it from your computer to the Accessport and then reflash the map to the car via the "Tune" -> "Change Maps" function. This should bring boost down, but you'll want to verify via data logging (if you can do so safely). Check out our data logging video below for details: Bill |
#4 | |
NASIOC Manufacturer
Member#: 4803
#5 |
Member#: 341005
Tri-State
thanks i am now running the low waste gate setting and its around 17 but it happen to peak 19 in 3rd i think but maybe this cold weather has somthing to do with this?
#6 | |
NASIOC Manufacturer
Member#: 4803
Bill |
#7 |
Member#: 341005
Tri-State
Okay I might try just leaving it on the lwg and trying to to hit full boost till spring to see if it is still over boosting
