Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
South East Region Club
Go Back   NASIOC > NASIOC Regional Areas > South East Region Forum
Old 02-03-2013, 07:51 PM   #1
scairkro
Member#: 345832
2005 wrx sti
blue
Default idle problems
when my car idles, it drops constantly as low as 500 and below. drives like a champ until i put it in neutral and idle. it sometimes dies at stop lights. anyone have any idea
05 sti
greddy turbo
turboxs fmic
ecutek injectors
scairkro is offline   Reply With Quote
Old 02-03-2013, 08:41 PM   #2
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
did you do anything to your car lately?
Old 02-03-2013, 10:33 PM   #3
white guys wrx
Member#: 223316
2005 STi
& 02 WRX
Hey there again! I understand your new to the forum so I'm guessing you bought your sti with these modifications on it?
It SOUNDS to me like you have a boost leak or a bad intercooler coupler (or one that needs to be tightened
Check all of your couplers and make sure that they are tight
Also, remember to check the boost lines around the turbo for breaks/tears
- There could be quite a few other things that could cause rough idle, Let us know what progress you make with checking for leaks
white guys wrx is offline   Reply With Quote
Old 02-03-2013, 10:38 PM   #4
scairkro
Member#: 345832
2005 wrx sti
blue
thanks, i will check tomorrow after work
Old 02-03-2013, 10:38 PM   #5
BoxKicker128
Member#: 326036
2005 WRX STi
Same here. i just adjusted it with the Cobb. No boost leak but im running really rich. My mpg are down to 19 and going lower when im just sitting there or i turn the car on to warm up. I just need a tune.
BoxKicker128 is offline   Reply With Quote
Old 02-04-2013, 12:09 AM   #6
scairkro
Member#: 345832
2005 wrx sti
blue
Ooo....forgot to mention I cleaned my maf to make sure that wasnt the problem
Old 02-04-2013, 01:47 PM   #7
white guys wrx
Member#: 223316
2005 STi
& 02 WRX
The MAF's are VERY TOUCHY on these cars. If you do not put it back to the correct location this will cause your car to not start. I've had this issue before also. Try to make sure everything is tight and in the correct location were it was before you cleaned it.
- If you cleaned it with anything other then MAF sensor cleaner... I would recommend picking up a bottle. At the worse case senero you will need to buy a new MAF on the forum if you used anything with alcohol in it or gas.
Old 02-04-2013, 03:23 PM   #8
scairkro
Member#: 345832
2005 wrx sti
blue
I used maf cleaner.....when I was looking up my problem I seen it could be a dirty maf....cleaned it and had no change...im checking all of couplings and hoses later....
Old 02-04-2013, 04:17 PM   #9
white guys wrx
Member#: 223316
2005 STi
& 02 WRX
Alright, Good deal. Those MAF sensors can be a real pita.
keep me posted. I'll check back later
Old 02-04-2013, 07:08 PM   #10
scairkro
Member#: 345832
2005 wrx sti
blue
Checked all my hoses.....all seems well....everything is tight.....still stumped
Old 02-04-2013, 11:14 PM   #11
white guys wrx
Member#: 223316
2005 STi
& 02 WRX
Is there anyway you can post a video of what its doing? or explain exactly what and when the issue is starting?
Old 02-04-2013, 11:44 PM   #12
SubyRS03
Member#: 245297
2004 WRX vf48 93 oct
Try your idle air control valve. There's plenty of threads on it. You'll need a new gasket $6 at advanced auto. But like everyone else check for leaks. Especially pre turbo there's so many hoses to check. Also check your PCV. If you take it off be careful it should move freely pick some carb cleaner or maf cleaner I can't remember double check. Just spray in all the holes and shake it to get the crap out. I only suggest all this cause I'm dealing with this problem as well
SubyRS03 is offline   Reply With Quote
Old 02-05-2013, 06:51 AM   #13
scairkro
Member#: 345832
2005 wrx sti
blue
Ive read that too....I have seen plenty of pics, but I still cant find the iacv. They may also be cuz im limited on my knowledge of engines. Is there anyway you could post pics or vid of where its at? The ones ive seen havent been much help.
Old 02-05-2013, 06:51 AM   #14
scairkro
Member#: 345832
2005 wrx sti
blue
Ill try and get a vid of it idling today
Old 02-05-2013, 12:43 PM   #15
SubyRS03
Member#: 245297
Give me an email and ill email or txt em to you instead of going through all the image link ish lol just shoot me a pm with a email/number
Old 02-05-2013, 05:00 PM   #16
white guys wrx
Member#: 223316
2005 STi
& 02 WRX
Old 02-05-2013, 06:59 PM   #17
ogintheback
Member#: 99163
Check throttle body gasket too.
ogintheback is offline   Reply With Quote
Old 02-05-2013, 07:01 PM   #18
scairkro
Member#: 345832
2005 wrx sti
blue
https://www.youtube.com/watch?v=xMby...e_gdata_player
This is what it is doin at idle and after I let off the gas to put in neutral and coast....it drops really hard especially after it was just in a higher rpm range such as navigating a parking lot in 1st or 2nd....im sorry about the music
Old 02-05-2013, 09:35 PM   #19
jenzos
Member#: 90363
2005 Nobro
video says its private
jenzos is offline   Reply With Quote
Old 02-06-2013, 09:15 PM   #20
83roothm
Member#: 317673
2004 wrx
wrb
IACV is right on top of the intake manifold before the intercooler
83roothm is offline   Reply With Quote
Old 02-06-2013, 09:17 PM   #21
83roothm
Member#: 317673
2004 wrx
wrb
Just cleaned and replaced my IACV gasket moments ago... Having the same problem. Still low idle. Hoping it just needs to break in. Stay in touch if you fix or diagnose any problems
Old 02-06-2013, 10:44 PM   #22
scairkro
Member#: 345832
2005 wrx sti
blue
Im gonna replace the spark plugs and a few other little things and see what happens
Old 02-21-2013, 04:56 PM   #23
scairkro
Member#: 345832
2005 wrx sti
blue
So just changed plugs and no change.....any ideas?
Old 02-22-2013, 11:55 AM   #24
Turbo Time
Member#: 226988
Like Us on Facebook!
www.turbotime.us
Could it just need a good tune? When was the last time it was tuned and was it someone reputable? Also, have you recently added an atmospheric BOV? Last question is, have you disconnected the battery recently?
Turbo Time is offline   Reply With Quote
Old 02-22-2013, 12:27 PM   #25
scairkro
Member#: 345832
2005 wrx sti
blue
Not sure f it was tuned...bought it as is 3 weeks ago....its got a bypass valve and I just disconnected the battery to change my pkugs.. u guys are in cary, nc right?
