Old 06-05-2012, 01:02 AM   #176
super_usdm
Member#: 286211
2003 WRX
1993 Legacy SS
An aftermarket clutch and/or lightweight flywheel will cause the car to stall or shudder if no gas is applied... Only leaving one option.
super_usdm is offline   Reply With Quote
Old 06-05-2012, 01:57 AM   #177
lefor3
Member#: 320309
2004 WRX
Originally Posted by easterbran View Post
I find (in my 05 sti) that I can move the car very little by just letting off the clutch. I generally give it a bit of gas as I begin to let the car lurch forward. However, in an 08 Elise, I have to give it gas immediately otherwise I'll stall. I think it just varies car to car, transmission to transmission.
thanks! just seeing if there was a more correct way.
lefor3 is offline   Reply With Quote
Old 06-05-2012, 10:16 AM   #178
easterbran
Member#: 307359
'05 STi Stage II
From various articles I've read, you are always supposed to give it gas before finding the friction point. But I doubt that letting the clutch move the car a bit will damage the clutch.
easterbran is offline   Reply With Quote
Old 08-23-2012, 12:51 PM   #179
dritgert
Member#: 320203
2015 Impreza wrx STI
Galaxy Blue Pearl
Friend of mine actually had a hard time learning shifting, but I got him to read this post. great post
dritgert is offline   Reply With Quote
Old 08-25-2012, 03:01 PM   #180
CrashBandit
Member#: 329543
2003 WRX Wagon
Sonic Yellow
I live in the mountains where elevation changes drastically, is it "better" for the tranny/turbo/drivetrain to shift into 4th and stay out of boost but be higher up in RPMs or keep it in 5th, gas pedal mashed, and boosting?
CrashBandit is offline   Reply With Quote
Old 08-25-2012, 04:12 PM   #181
easterbran
Member#: 307359
'05 STi Stage II
I'm curious about this as well....
Old 08-25-2012, 07:31 PM   #182
super_usdm
Member#: 286211
2003 WRX
1993 Legacy SS
Im not an authority on the matter but I do 4th with less boost. You could drive in the 3500-4k range all day with no issues.
Old 08-26-2012, 12:17 AM   #183
AaronCompNetSys
Member#: 144848
05 WRX, 05 Saabaru
01 S2K, 91 Impulse RS
I posed this question to a tuner, and the best answer I got (as well as from the other local shops posting) is that staying in lower RPM with higher boost is more efficient. Friction losses and all.
AaronCompNetSys is offline   Reply With Quote
Old 08-26-2012, 06:42 PM   #184
CrashBandit
Member#: 329543
2003 WRX Wagon
Sonic Yellow
Well then, two different answers.. I think I'm using more gas being in 5th gear with the gas pedal pressed more than being in 4th using less gas.
Old 08-27-2012, 12:51 PM   #185
CrashBandit
Member#: 329543
2003 WRX Wagon
Sonic Yellow
Bump to top..any ideas??
Old 08-27-2012, 09:01 PM   #186
Sillyak
Member#: 330465
Originally Posted by lefor3 View Post
Hmmm, quick question, I've been driving a manual (a FWD RSX-S though if that makes a difference) for about 3 years now and am looking to get a Bugeye.
Is it necessary, or more correct to do this method shown in this thread at a complete stop in first?
1) Clutch depressed, 1st gear, Rev up to 2000RPM
2) Slowly let off clutch while maintaining the 2000RPM
this whole time, I was taught (and seen other people) this method to start in first gear:
1) Clutch depressed, in 1st gear, slowly let off to where you can kind of feel the car lurk forward
2) Give it some gas and you'll be around 1500RPM with foot off the clutch
Is there a better, right, wrong, etc. way to this? Sorry if it's such a noob question, just rather learn now then damaging a clutch/transmission. Thanks!
The proper way to let off the clutch for regular driving is not to rev up the engine (even to a modest 2000rpm) and let off the clutch, but to slowly give it gas as the clutch engages so the rpm come up smoothly. A perfect start in a standard is exactly as it would be in an auto, that is, just a smooth increase in rpm from idle to shift point.
If you rev, then release the clutch pedal, you are increasing wear on the clutch. This is acceptable in some situations (like if one wants a faster launch), and is almost negligible if you're only modestly reving the engine, but why wear when you don't have to?
Sillyak is offline   Reply With Quote
Old 08-28-2012, 12:54 AM   #187
hi-revs
Member#: 233229
2007 sti
wrb
I think its better on the engine to have the rpm's higher that to have higher boost.
Going up a steep hill in 5th with the gas pushed further seems to me like its causing more stress on the engine from "struggling".
Whereas going up a steep hill in 4th with the rpm higher makes the load on the engine a lot easier.
hi-revs is offline   Reply With Quote
Old 08-28-2012, 05:37 PM   #188
nature0220
Member#: 279396
2011 STI Sedan
Rally Blue
Some question about my 2011 STi. When shift and down shift sometimes I feel some friction when going into gears. it will go in, just not very smooth, feels like there's a bump on the way going into gear.
And when it's smooth, it will be smooth all drive long (most of the time). When it's not smooth, I can feel the bump (down shift even up shift), it will happen to maybe not every shift but probably around 60% of the shifts.
As I stated, it will go into gear just doesn't feel smoothly kind feel like a bump in between or something blocking in the middle, and yes I always press clutch to the bottom. I think I heard some of my friends experiencing similar issue with their STis.
I'm just wondering is this a common thing? Is it because of my driving habit or shift timing?
nature0220 is offline   Reply With Quote
Old 08-28-2012, 06:18 PM   #189
Sillyak
Member#: 330465
It could be how you're shifting or your synchros could be a little worn. It would be nice if everyone could try an unsynchronized transmission, it tells a lot about ones shifting. With a unsychronized tranny you will grind if you shift too slow, too fast or you let off the throttle wrong.
You could be upshifting too slow or too fast, meaning your synchros have to do more work, hence the bump. When you downshift try rev matching.
Old 11-23-2012, 01:42 AM   #190
383 GUY
Member#: 338654
1995 Legacy wagon
Brown 2.2 Auto
Default Awd Not Working
ANY INFO ON MY 1995 LEGACY AUTO AWD NOT WORKING WOULD BE GET!. YES THE FUSE IS REMOVE AND NO CODES. CAR HAS 161 ON IT. I HAVE READ YOU CAN REPLACE THE TRANSFER SOLENIOD AND TRANSFER CLUTCHS WITH JUST REMOVING THE TAIL SHAFT . AND MORE INFO WOULD BE GREAT!!!!!!!!
383 GUY is offline   Reply With Quote
Old 12-05-2012, 12:41 AM   #191
BeastBoy_Sy
Member#: 339306
2013 Wrx Hatch
Thank You!
BeastBoy_Sy is offline   Reply With Quote
Old 01-17-2013, 05:58 PM   #192
Tommyp
Member#: 277475
How bad is it for the car if I over-rev when I rev-match or up-shift
Tommyp is offline   Reply With Quote
Old 01-17-2013, 06:15 PM   #193
DaBigs11
Member#: 262750
12 WRX
I'm no expert but I would think all your damaging is the clutch. Can't imagine it's hurting synchros since your not shoving it into gear and dumping the clutch without rev matching. Flame me if I'm wrong but that's my best guess
DaBigs11 is offline   Reply With Quote
Old 01-20-2013, 07:56 PM   #194
AaronCompNetSys
Member#: 144848
05 WRX, 05 Saabaru
DaBiggs is right, once you've slotted the gear in then the only wear your are going to have if you mess up is on the clutch.
Examples that might wear your syncros:
  1. Quickly skipping gears up or down (out of 5th and straight into 2nd; out of 1st and straight to 4th)
  2. Over reving when double clutching (rev too much when in neutral)
  3. When at a stop in neutral, quickly pressing in the clutch and ramming into first before the gearbox spins down.
  4. Shifting into 1st while moving without double clutching
Not all of these are going to be lethal to your trans, but if you want it to still feel brand new at 100k, then take gentle care of your syncros.
Old 02-05-2013, 05:19 AM   #195
Calimanwrxdriver
Member#: 317436
2013 WRX Hatchback
Ice Sliver
Default Muscling into first gear
Unabomber is it normal for WRX's to be a little hard to put in first gear? I get it 30% of the time at a dead stop, other times is goes in like butter. I dont down shift in first but I do in every other gear (2-4). Will double clutching or rev matching help that?
I read your post every night for 1 hour before going to bed. Thank you for all you wonderful information.
Calimanwrxdriver is offline   Reply With Quote
Old 02-05-2013, 08:16 AM   #196
cheezmunky
Member#: 167627
2011 WRX Ltd Hatch
These transmissions are notoriously bad for being able to down shift into first, but I see no problem with this because it prevents damage from over-revving. You rarely need to down shift into first unless you're creeping along (<10 mph) anyways, and then it should work fine. I don't know if rev matching will help, per se, but double clutching does. The two go hand in hand if you're double clutching correctly.
I've also noticed on my car that the gears are much more notchy and temperamental when it is cold outside and the car hasn't warmed up at all.
cheezmunky is offline   Reply With Quote
Old 02-06-2013, 12:39 AM   #197
GregOrz
Member#: 339148
When I down shift, I brake, depress the clutch, drop to the lower gear, rev match, and engage the lower gear in one smooth motion. It just feels right to me. Sounds like I shouldn't be doing that though.
Hitting that stiff, hard clutch twice seems inefficeint to me and tedious.
What kind of problems am I setting myself up for doing it that way? If someone can explain to me how bad I am being maybe I'll change my ways .
GregOrz is offline   Reply With Quote
Old 02-06-2013, 04:25 AM   #198
Schikane
Member#: 337700
2013 WRX
Ice Silver Metallic
I do the same thing as well.
Schikane is offline   Reply With Quote
Old 02-06-2013, 08:40 AM   #199
cheezmunky
Member#: 167627
2011 WRX Ltd Hatch
Double clutching was needed to synchronize the engine with the gears in older cars before synchros. Otherwise the gears would grind or wouldn't go into gear at all. With the invent of the synchro, double-clutching became unnecessary unless in specific conditions such as the aforementioned 2-1 downshift or when racing and skipping multiple gears. Even in the latter case, you most likely don't have to double-clutch; you'll just be saving your synchros from a lot of wear if you do.
With that said, if you're currently only rev-matching, you are unlikely to be creating any problems down the road. Double-clutching is just something that many find fun to master when enjoying the experience of a manual transmission.
Old 02-06-2013, 07:44 PM   #200
Calimanwrxdriver
Member#: 317436
2013 WRX Hatchback
Ice Sliver
Awesome! Thanx for the quick reply!
Uppipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 378 12-27-2015 07:49 AM
Car Buying FAQ: read if you are buying/selling/leasing a Subaru or other car Unabomber Newbies & FAQs 82 10-19-2015 06:42 AM
Pulley FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 110 07-02-2015 11:25 PM
Subaru FAQ: Read if you are a new Subaru owner! Unabomber Newbies & FAQs 41 10-11-2013 03:04 AM
