Alaskan Impreza Club
Old 01-30-2013, 11:50 AM   #1026
chanomatik
Member#: 159474
2013 BRZ Ltd 6MT CBS
Counter-steer like a boss
Ha! I just came in here to post that. Thanks, Davin.
Old 02-01-2013, 07:30 PM   #1027
Dominator
Member#: 156712
1991 Legacy SS
Pearl White
I like where this is going.
Dominator is offline   Reply With Quote
Old 02-01-2013, 07:39 PM   #1028
_davin
Member#: 260501
2011 WRX 5dr SWP Ltd
I liked the shooting brake or whatever the hatchback thing was called, but it seems like a convertible would kind of defeat part of the car by softening the chassis. That's what an MX-5 is for.
_davin is online now   Reply With Quote
Old 02-01-2013, 07:45 PM   #1029
chanomatik
Member#: 159474
Looks like a pre-2010 Mazdaspeed 3. I like.
Some say the essence of a "sports" car IS having a convertible variant.
Old 02-01-2013, 08:07 PM   #1030
Dominator
Member#: 156712
1991 Legacy SS
Pearl White
I'm interested in a convertible. Not that I could buy one new, but I would like for it to be available to buy used in a couple years. When Chano buys one and sells it a year later or something,
Old 02-01-2013, 09:14 PM   #1031
LiLpNoY
Member#: 94836
2oo5 STi Aspen
2o12 PiLoT CherrY
Considering the mx5 is a main competitior, a convertible make sense.
LiLpNoY is online now   Reply With Quote
Old 02-01-2013, 11:26 PM   #1032
chanomatik
Member#: 159474
Old 02-02-2013, 02:25 AM   #1033
insane_one
Member#: 301431
2010 Subaru WRX
OBP Hatch
if the FRS came in a vert i would get one.
insane_one is online now   Reply With Quote
Old 02-04-2013, 11:40 AM   #1034
chanomatik
Member#: 159474
Default Steering Rack Bushings Group Buy
http://www.ft86club.com/forums/showt...430#post710430
One of the first things out of the box that we were unhappy with were the steering rack bushings. Here's what we found:
Stock bushings use a bolt with a rolled thread. This means that the shank is only 11mm.
The stock bushing crush tube has a bore of over 13mm.
Between those two items you immediately have a good bit of slop. Sure you could argue that small amount isn't that much, and you'd be right until you consider what that translates to at the tire.
The other big item we found is that the rubber is soft. I mean S.O.F.T. Like bubblegum. Not so good.
The last item we found is the hole on the rack for the stock bushings isn't all that concentric. That would explain the really soft rubber.
I mean here's this car than handles great out of the box, but could be made that much better with some simple forethought on how the car is going to be used. Especially when someone throws on a set of sticky tires. What's going to happen then? I can tell you - slop, inprecision, poor handling. Not good.
So what we did was make something better, and here's how:
Our bushings are aluminum. Nice and solid, and fill more of the hole on the rack.
Our bushings have a bore that fits the bolt with a proper clearance
Our bushings get you a new grade 8 bolt with a consistent thread to shank transition
Our bushings feature a split design for easier install.
Our bushings also use retaining o-rings to make for a really tight fit to account for stock bore inconsistencies so you get a postive snap into place.
In other words you get what should be in there from the factory. Plain, simple, and functional. Just how we like to do things here at TiC.
Old 02-04-2013, 12:02 PM   #1035
furtive
Member#: 320658
2013 BRZ
SSM
Oo lemme know once you get yours how it is
furtive is offline   Reply With Quote
Old 02-04-2013, 12:06 PM   #1036
chanomatik
Member#: 159474
Review right here!
http://www.ft86club.com/forums/showthread.php?t=27727
Just deposit $25, Alex. It's all good.
Old 02-04-2013, 02:40 PM   #1037
Getagrip
Member#: 2045
BRZ, E90 BMW 330xi
05 Mustang GT (hers)
Looks good. But I will not be installing as it is not allowed in Stock and STX classes for autocrossing
Getagrip is offline   Reply With Quote
Old 02-04-2013, 02:48 PM   #1038
chanomatik
Member#: 159474
Looks like I'll be moving up a class then.
Old 02-04-2013, 03:46 PM   #1039
insane_one
Member#: 301431
2010 Subaru WRX
OBP Hatch
them FRS's be sexy though.....
Old 02-04-2013, 06:26 PM   #1040
chanomatik
Member#: 159474
According to Scooby South the Whiteline ones are okay because the material amount compared to stock bushings are similar enough. Whiteline just made it a harder compound. http://www.rallysportdirect.com/Whit...Mount-Bushings
Otherwise, because these TiC one's are mostly aluminum, they do not qualify. Hmmmm...
Old 02-04-2013, 08:43 PM   #1041
Getagrip
Member#: 2045
BRZ, E90 BMW 330xi
Hmmm. Whitlines may be up my alley. Scooby South definately is a pioneer of research on STX built BRZs.
Old 02-05-2013, 05:19 PM   #1042
chanomatik
Member#: 159474
Old 02-06-2013, 01:52 AM   #1043
kayetealynn
Member#: 253304
2001 Impreza 2.5RS
Plus MOAR
kayetealynn is offline   Reply With Quote
Old 02-06-2013, 11:46 AM   #1044
chanomatik
Member#: 159474
Originally Posted by kayetealynn View Post
Old 02-08-2013, 02:36 PM   #1045
907scoobyrex07
Member#: 296069
07 Rex
wrb
907scoobyrex07 is offline   Reply With Quote
Old 02-08-2013, 03:01 PM   #1046
bjcarter2
Member#: 227288
2008 FSXT
Red
^^^ Oh, look, 370Zs !!!
bjcarter2 is online now   Reply With Quote
Old 02-08-2013, 03:06 PM   #1047
chanomatik
Member#: 159474
That's terrible, but fitting for a VW forum.
Old 02-08-2013, 03:20 PM   #1048
907scoobyrex07
Member#: 296069
07 Rex
wrb
I thought it was pretty sweet, but everyone likes different things I suppose.
Old 02-08-2013, 03:24 PM   #1049
chanomatik
Member#: 159474
No, you're right, variety is good. I actually don't mind the red BRZ, but that white one is too much with the wheels. I love the exhaust tips, though!
Old 02-08-2013, 03:33 PM   #1050
907scoobyrex07
Member#: 296069
07 Rex
wrb
Oh yes of coarse! They both have quite a bit going on haha. I just recently helped a friend of mine bag his Mercedes and since then I have wanted to do my car. I think it would be different, and a fun little project. Plus, no one that I know of up here has a bagged suby.
Any thought on the RWD Subaru?? lindsayicon Vancouver Impreza Club Forum -- VIC 9 05-06-2011 12:54 AM
Best ways in learning on how to work on subaru's (or cars in general) sizzflair Newbies & FAQs 33 02-04-2010 10:22 PM
new motortrend article on fwd vs rwd vs AWD Ghost Rider General Community 63 05-06-2005 11:31 AM
Thoughts on gear oil... and Subaru's response DrD Transmission (AT/MT) & Driveline 14 05-01-2004 01:26 AM
A thought on Subaru's 4EAT AWD (non-WRX) live311 General Community 6 11-18-2002 03:54 PM
Message Board Statistics All times are GMT -4. The time now is 01:08 AM.
