#1 |
Member#: 199995
South East
Vehicle:2004 Impreza WRX Aspen White |
I have a 04 wrx that needs a rebuild, and i also picked up a 02 block off craigslist to biuld it u an minimize the down time.
I found a 2.1 strocker kit that comes with the 430 crank-79mm. I read a while back that some blocks and cranks have the trust washer in eigther #3 or #5 position but i have not found the information again Can anyone tell me if this crank will work?
#2 |
Member#: 71875
Vehicle:98 2.5GT my wheels fit |
99 and up all have the thrust bearing in the #5 spot.
So yes it will work. |
#3 |
Member#: 199995
South East
Ok, does anyone know what commission ratio I should have using that crank?
#4 | |
Member#: 103757
Good stroker pistons include Cosworth and Mahle. |
#5 |
Member#: 199995
South East
Does anyone know of any problems with going up to a 93mm bore, any known block failures?
In general Pros/Cons? |
#6 |
Member#: 276443
AKIC
Vehicle:2005 Subaru wrx OBP |
Manley has stroker pistons a well. I run them.
#7 |
Member#: 276443
AKIC
I would say do the minimum bore that is needed. 93 is only 1mm over stock bore.
#8 |
Member#: 200987
MAIC
JE stocks the stroker pistons.
Their off the shelf 92.5mm 8.5:1 pistons are going into my personal 2.1L stroker for my bugeye project build with a set of my standard length rods. Keeping it light and strong! -Micah |
#9 |
Member#: 199995
South East
How long have you been running them?
#10 |
Member#: 199995
South East
Ok, so I'm starting to buy all the parts now. I'm getting a Stroker kit so that will take care of the crank, rods, pistons, and bearings. I already have a timing belt kit with the water pump also. And a set of Manley valve springs. So I need:
Oil pump - stock or something else? Gasket set - any suggestions? Where to get a good deal? 93mm head gasket set - is .027 the thinnest available? Am I overlooking/missing anything? |
#11 |
Member#: 347463
Good info here , Nice Treat
