Old 11-27-2012, 11:36 AM   #26
WRick
Member#: 86107
Originally Posted by WRick View Post
I'm getting pm's by the dozen about this !
Here's another pic :
If you need info :
martin.gingras @ gmail com
take the spaces out.
I flushed my defi's for this and had change left
best mod ever. If the ecu reads it, this also reads it, and displays it.
Send this guy an email.
I think he has one or two left.
Did I say it's amazing ?
WRick is offline   Reply With Quote
Old 11-27-2012, 12:58 PM   #27
jthatch12
Member#: 321715
03 Big 16G WRX
I need that gauge also!
Old 11-27-2012, 01:44 PM   #28
WRick
Member#: 86107
thank ?
Old 12-05-2012, 08:01 PM   #29
xxBrun0xx
Member#: 285940
2008 STi
As awesome as that is, I'd rather spend $300 less and get a tactrix, considering you can do a lot more with it. Call me crazy :S
xxBrun0xx is offline   Reply With Quote
Old 12-06-2012, 09:50 AM   #30
WRick
Member#: 86107
I don't think you get the point
You don't buy the Dash Display for it's logging capabilities, you buy it to display the ecu's information.
If you are looking at buying such a display and are interested with your WGDC's and Total timing, you probably already have a tactrix.
This replaces countless guages.
I have a speed density setup, And have displayed the VE, SD load, Intake temps, Wideband, boost, gear, and fuel error %. On one of the screens.
Here's an old pic. At that stage it was still work in progress.
Long term fuel trims on the fly ? ( good tool for us SD boys, or ppl trying to scale a MAF )
( I just flashed a map, IAM15 is normal, don't worry )
DTC's, oil pressure, egt's, logger, whatever.
Look, I don't build, profit, or benefit from what I'm saying. Everyone has guages. Noone has dash displays.
Old 12-06-2012, 04:37 PM   #31
Daluv
Member#: 159325
Nice Speed Density screen
Daluv is offline   Reply With Quote
Old 12-06-2012, 09:49 PM   #32
xxBrun0xx
Member#: 285940
2008 STi
I'm just starting to get into the whole tuning thing, so thanks for clearing that up! Makes a lot of sense, and if I had the money, I would absolutely do this. Automatic baller status.
Old 12-07-2012, 12:53 PM   #33
WRick
Member#: 86107
Yes, and the idea behind this, is it lets you visualise what is happening.
I have a huge AFR screen now
Old 12-07-2012, 01:37 PM   #34
Daluv
Member#: 159325
PIC or it didnt happen :P
Mart
Old 02-01-2013, 09:13 AM   #35
sheshani
Member#: 345603
2002 STI Impreza 200
Default need one
If you need info :
do they have one for STI 2004 ?
sheshani is offline   Reply With Quote
Old 02-02-2013, 09:16 AM   #36
Ziggyrama
Member#: 53665
2011 STI Stg2 w/EBCS
Focal Active Setup
I think this thread has been derailed enough. I think this should be taken to another thread as this one was originally made for SD logging. If this is such a hot topic, start another thread and people can inquire there.
Ziggyrama is offline   Reply With Quote
Old 02-07-2013, 01:52 PM   #37
jthatch12
Member#: 321715
03 Big 16G WRX
I'm totally going to build that gauge for my capstone project next semester.
Anyway back on topic, is the sampling rate of SD logging significantly slower in comparison to normal logging?
Old 02-07-2013, 03:18 PM   #38
Ziggyrama
Member#: 53665
Focal Active Setup
You got it reversed. SD logging is significantly faster than normal logging. The sampling rate is still tied to the number of parameters but it is MUCH faster. To give you an idea, I am collecting 15 counters and I get about 35 samples per second, where 1 of the counters requires extensive calculations (those slow it down). So, I am running slower than normal 15 counters would. Normal logging can't touch that kind of rate.
Old 02-07-2013, 03:49 PM   #39
jthatch12
Member#: 321715
03 Big 16G WRX
Sweet. I'm so glad I found out about this haha. I have mine set up to start logging during throttle opening angle above 60% and if there is any knock above 2000 rpm. It stops logging when rpms drop below 2k. Such a neat tool!
Old 02-15-2013, 04:49 PM   #40
mikeyPSF
Member#: 236475
Originally Posted by Dartholomew View Post
If only you could leave the Tactrix in the ODB port without draining your batteries.
The OpenPort only draws around 60 milliamps so it shouldn't be a problem to leave in for long periods of time.
mikeyPSF is offline   Reply With Quote
Old 11-26-2013, 07:06 PM   #41
Daluv
Member#: 159325
I wonder how long can it stay connected at that rate...
Mart
Old 11-27-2013, 08:25 PM   #42
BeastianSTI
Member#: 310506
2005 WRX STi
Silver, Sexy 'n Raspy
I've left mine plugged in for a few days before without any issues lol
BeastianSTI is offline   Reply With Quote
Old 11-27-2013, 08:31 PM   #43
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
As long as you drive your car every day or two there is zero worry about it killing your battery. I've left it in for a long time before I noticed it was left in.
WTB: (MD) Tactrix OpenPort 2.0 eduSti MAIC Private Classifieds 3 03-31-2009 03:10 PM
FS CT: Tactrix Openport 2.0 Boosted WRX STi Engine/Power/Exhaust 10 03-19-2009 07:30 AM
Tactrix Openport 2.0 Coming Soon! 07-08+ compatible. fujiillin Open Source Reflashes 388 02-21-2009 01:56 AM
WTB: Tactrix Openport 2.0 Cable Xissix NWIC Private Classifieds 2 11-04-2008 10:35 PM
FS: Tactrix Openport 2.0 $160 shipped scoobysti05 Engine/Power/Exhaust 7 10-20-2008 12:30 PM
