Old 02-07-2013, 12:00 PM   #1
AkumaMotorsports
Member#: 214570
Default 2011 WRX Stage 2 Retune
Event yno Tune (Re-tune with FIC 900cc)
2 Amboy Ave
Woodbridge, NJ 07095
Dyno: Mustang AWD 500
Tuner: John Shafer
Car: 2011 WRX
Mods: Stage 2 (DP,CB,FMIC,EBCS,FIC 900CC,CAI,DW65C)
Tuned using: Cobb AP
Weather: 40 Degrees, Cloudy
Elevation: Sea Level
Numbers: W/ Stock Injectors-282whp,289wtq
W/900cc's-305whp/334wtq
This Stage 2 WRX was previously tuned with stock injectors as shown on the graph below. During the tune we had run out of fueling to play with so we had jst recently re-tuned the car with a set of 900cc's thanks to Fuel Injector Clinic. This allowed us to add a little more fuel, boost, and timing. Check it out.
AkumaMotorsports is offline   Reply With Quote
Old 02-07-2013, 12:34 PM   #2
foolycooly
Member#: 260545
2011 WRX Limited 4dr
Great numbers!
At what point do you consider injectors needed/beneficial on the 2011s? I'm installing a TBE/EBCS/CAI and getting a protune in a few weeks--just curious how big of a difference the FMIC/pump make.
Thanks.
foolycooly is offline   Reply With Quote
Old 02-07-2013, 01:18 PM   #3
AkumaMotorsports
Member#: 214570
We generally see injectors maxed out once the car has been modified with full bolt ons including a fuel pump.
Once you start adding more modifications to add power you need an intercooler to keep that air charge cool enough to run efficiently with the rest of you bolt ons. The stock intercooler is just not efficient enough to keep up with a full bolt on car.
If you have any more questions shoot us a line at (732)-326-0090.
-Kevin
Old 02-07-2013, 02:45 PM   #4
NoGraffix
Member#: 276209
I am Rub
Function>Form
So were the only adjustments fuel related or were other changes made? The gains are really good though.
NoGraffix is offline   Reply With Quote
Old 02-07-2013, 02:50 PM   #5
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
You can see that they added 1.5lbs of peak boost. Probably other changes as well I would assume.
Old 02-07-2013, 03:04 PM   #6
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
Old 02-07-2013, 03:47 PM   #7
BroBroBroBroBro
Member#: 338211
2011 wrx cobb 20G
The curve looks a lot better than previous wow....im gonna do this one day...stock clutch on this eh? good luck!
BroBroBroBroBro is offline   Reply With Quote
Old 02-07-2013, 03:59 PM   #8
AkumaMotorsports
Member#: 214570
Yes fuel changes were made which allowed us to up the boost and change the timing a little.
Yup Stock clutch
Old 02-07-2013, 05:25 PM   #9
FCmaniac
Member#: 142029
2013 Forester
2008 350z, 1991 Miata BRG
Those are great numbers for a stage 2 setup on pump on your dyno.
FCmaniac is offline   Reply With Quote
Old 02-07-2013, 10:58 PM   #10
PROcede
Member#: 293500
2015 FXT Stage 2
CWP
Stock clutch should last until around 350tq+
PROcede is offline   Reply With Quote
Old 02-08-2013, 02:43 PM   #11
Nimbus09
Member#: 212399
09 wrx 301hp/328tq
'00 miata blue
^mine was giving out at 335whp
Nimbus09 is offline   Reply With Quote
Old 02-14-2013, 09:53 AM   #12
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
Right, but how much torque? That's what they're rated by.
Subian is offline   Reply With Quote
Old 02-14-2013, 03:52 PM   #13
Nimbus09
Member#: 212399
09 wrx 301hp/328tq
'00 miata blue
^argh, typo, i meant 335wTQ
lol, sorry
Old 02-17-2013, 06:57 PM   #14
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
how does this dyno compare to others? I just tuned a 2012wrx with a turbo back only. made 279whp and 350wtq on the virtual dyno w/ correction at 1.0.
Old 02-17-2013, 08:47 PM   #15
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
It reads low but if u made 350wtq with just a tbe u def entered something wrong on vd cause that's impossible
Slimsti is offline   Reply With Quote
Old 02-18-2013, 09:59 PM   #16
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
nope, just entered the log like i always do, put in tire size and the 350 lbs of me and the other guy and thats it. i tuned it to 20psi tapering up top a bit to 15ish. didnt mess with the timing too much and left avcs alone. i did read the 2012 wrx's put a bit more down and the turbo spooled faster. im used to tuning 02-07 vehicles but this was the result on a friends 2012 and figured i would ask
