Old 12-24-2012, 03:18 PM   #26
sburck
Member#: 191491
2011 Forester
than an ej22t or ej207 would prob rip with just a stock block on e85
sburck is offline   Reply With Quote
Old 12-24-2012, 03:40 PM   #27
CatfaceType-R
Member#: 81102
+1, I totally agree.
But...some people like to tinker, build their own stuff, and that's cool.
Old 12-31-2012, 10:53 AM   #28
3MI Racing
Member#: 200987
Originally Posted by tachrev View Post
He's limited to a 2285cc or so do to the class he wants to run in. So no 2.5l.
Hence the 2.2l.
Also, no such thing as too fast.
Yup!
Yeah but those also won't rev over 9k and I'll let you check to see where and EJ22t puts the CR with D25 heads
3MI Racing is offline   Reply With Quote
Old 12-31-2012, 03:50 PM   #29
SurfWagon
Member#: 156861
2005 LGT Wagon 5MT
swp, 16g
I missed this thread earlier. I'm working on something very similar. Tube frame, mid-engine RWD, 1500 lbs (TBD). After talking with subie friends and then people on here, I decided on an ej22t with s20 heads (were cheaper and I'm on a serious budget.) I think you'll get a good powerband with an increased compression ratio on e85. I'm shooting for something closer to 300 tq/whp, so I'm not going as crazy all out as you. Having the turbo relocated also really gets the power started early. Look at the 2010 LGT power curve.
Anyways, I think you're on the right path. I'll keep an eye on this build ...should be fun!
SurfWagon is offline   Reply With Quote
Old 02-07-2013, 04:32 PM   #30
68Cadillac
Member#: 95901
Originally Posted by 68Cadillac View Post
He also asked if there was room in the 818 chassis to mount the turbo off to the side of right side valve cover. Shortening the header/uppipe pipes feeding the turbo and also moving the CG forward and down. I don't know if it'll work because I don't have the chassis with the motor actually in it to mock up.
Looking at a current photo just released today
I don't think there'll be room to mount the turbo that way.
68Cadillac is offline   Reply With Quote
Old 02-07-2013, 04:53 PM   #31
tachrev
Member#: 115260
04 WRX
205/22E Hybrid w/ VF39
Jeeze, I wonder if you have to drop the engine to replace the fan belt!
tachrev is offline   Reply With Quote
Old 02-08-2013, 01:56 PM   #32
spintheground
Member#: 239638
2007 WRX TR UGM
Super interesting thread! Will have to keep an eye on this.
spintheground is offline   Reply With Quote
Old 02-17-2013, 04:44 PM   #33
68Cadillac
Member#: 95901
After 3 months of searching, including two guys who reneged on selling me one,
I now own a EJ22t case.
Good view of the closed deck, Oil squirter holes in mains 2 and 4.
Top and Bottom
EJ22t OEM Oil squirters. Removed with a 8mm long socket. Those threads are M5 (5mm). Tiny. They're barely had any torque holding them in.
Subaru EJ22t vs Cadillac 500 (500 in^3 = 8.2 liters)
Old 02-18-2013, 02:31 PM   #34
philly15
Member#: 223137
14' super ultimate
race car project
Definitely subscribed to this thread Im on the list for the S model I'm starting with the ej255 basically for the first year then going to an ej22t I think
philly15 is offline   Reply With Quote
Old 02-20-2013, 02:17 PM   #35
68Cadillac
Member#: 95901
3MI Racing's Micah wanted to see better shots of the EJ22t case halves mating surfaces. Who ever separated my case used screwdrivers. Which is bad, M'kay.
Right Case Half Overview.
Oil crossover gallery, Right Case Half
Oil and Coolant Crossover gallerys - Right Case Half
Oil Gallerys near Oil Pump Front, Lower section of Right Case Half
Coolant Crossover, Right Case Half
Rear Main Seal Machined Surface, Right Case Half
Old 02-20-2013, 02:18 PM   #36
68Cadillac
Member#: 95901
EJ22t Left Case Half Overview
Oil Crossover Gallery, Left Case Half
Front, Lower Oil and Coolant Crossover gallerys - Left Case Half
Front, Lower Oil Mating Surface - Left Case Half
Coolant Cross Over - Left Case Half
Rear Main Seal Machined Surface - Left Case Half
Old 02-20-2013, 02:26 PM   #37
68Cadillac
Member#: 95901
EJ22t
Gouge in #1 Main bearing Machined Surface - Left Case Half
Old 02-20-2013, 02:37 PM   #38
Squidz
Member#: 142608
2003 Sonic Yellow
Marginally well behaved.
Kinda a bummer, but it looks like you can't put a six-speed in it either. The tail housing is missing off of that 5-speed in the pic and it's almost poking out the back as it is.
So far this and no option for AWD are the only downsides i can find to building a car like this. Very cool.
Squidz is offline   Reply With Quote
Old 02-20-2013, 05:09 PM   #39
Matty_STi
Member#: 333602
2012 STi
How much longer is the 6 speed MT versus the 5's??
Matt
Matty_STi is offline   Reply With Quote
Old 02-20-2013, 05:23 PM   #40
68Cadillac
Member#: 95901
Once again the STI 6mt will not fit.
Three reasons:
1. It's too long
2. FFR is not making a 'lock out kit' for the 6mt center diff. Pretty sure there's not an aftermarket one either.
3. Must convert 6mt shift linkage to cable operated. FFR is only providing for the 5mt.
The STi 6mt is a no go. It will not fit in the 818.
There is the 2010+ Legacy Trans - 6 speeds in the 5mt case!
Here's the gearing:
Gear Ratio -------- Top speed (mph) assuming 245/40R17 tires and 7250 rpm limit
1st: 3.454 --------- 35
2nd: 1.947 --------- 62
3rd: 1.296 --------- 93
4th: 0.972 --------- 123
5th: 0.825 --------- 145
6th: 0.695 --------- 173
Final: 4.444:1
I'm not considering this transmission for my personal project. Ijust know it exists.
Old 02-20-2013, 06:20 PM   #41
Matty_STi
Member#: 333602
2012 STi
Three reasons:
1. It's too long
3. Must convert 6mt shift linkage has to cable operated. FFR is only providing for the 5mt.
I know what FFR has said....
1. How much longer?
2. There are options
3. Not that big of a challenge.
I'm just wondering how much longer it is. If I decide to do a 6mt it's very much possible but I'm not sure that's what I would do.
Matt
Old 02-21-2013, 07:53 AM   #42
3MI Racing
Member#: 200987
Well I'm glad to see that the soda blasting was very light!!
Old 02-21-2013, 12:11 PM   #43
68Cadillac
Member#: 95901
40 psi baking soda blast. I was tempted to turn up the pressure so I could get it done faster but left it low. I avoided the mains and rear main seal machined surfaces.
This is how it looked before. I honestly thought it was painted black.
Old 02-21-2013, 01:10 PM   #44
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Matt
The question I have is why would you even consider a 6MT on a car this light? 5MTs won't grenade if you beat on them with a <2000 pound RWD and you can get a used 5MT + whatever factory gearing suits you + motorsports diff all for less money and weight than a 6MT.
5MT actually seems very well suited towards the application. Maybe I'm missing what the advantage of the 6MT would be in this application?
Old 02-21-2013, 01:22 PM   #45
Matty_STi
Member#: 333602
2012 STi
I don't want to clutter this thread with my stuff
I have my reasons for wanting to do a 6mt in my setup. Haven't made any decisions yet. But we shall see. I am working with a couple people on the FFR forums for a different body style than the current 818. And also low power won't be what I'm doing. 700+whp will be the name of the game with massive down force.
I'll do a build thread when it comes closer to that.
Sorry for the thread-jack.
-Matt
Old 02-21-2013, 01:33 PM   #46
Squidz
Member#: 142608
2003 Sonic Yellow
I was simply stating an observation i had made about the picture...wasn't intended to annoy or piss anyone off. Certainly not to make someone have to go out of their way and take the time to quote themselves to show us that they had already graciously provided information on this topic.
I agree with Concillian and won't be puting a six speed in mine, i think the longer gears would be better suited for street use...but since the question has been asked:
The advantages of a six speed are still the same in this car as they are in any car. They went to a 6-speed in the miata and BRZ, they are both lightweight vehicles. Six gears changes the ratio of each gear, you can have six shorter ratios instead of five longer ones (to achieve the same final gear ratio). This means that each gear effectively has a shorter rpm range and you have more choices to keep the car in the powerband of your engine setup.
Nothing about running a six speed in this appication was about grenading anything.
Old 02-21-2013, 08:35 PM   #47
3MI Racing
Member#: 200987
Just but kurt to hurry up and release his flywheel and bellhousing adapter for the Boxster S trans (getrag 6mtl380)...so that I can use the one sitting in my garage
I know what I have cooking for Matty and well, talking with Matt Monsoon at Guard Transmissions might be worth a call for Matt. Tell him I sent you and that'll save some briefing as he and I've talked about this trans before.
-Micah
'Homemade WRX'
Old 02-22-2013, 12:23 AM   #48
Matty_STi
Member#: 333602
2012 STi
-Micah
'Homemade WRX'
oh my!!!!!!!!
Old 02-23-2013, 10:01 AM   #49
spintheground
Member#: 239638
2007 WRX TR UGM
-Micah
'Homemade WRX'
I thought that adapter was already out? Or is there a different one being made?
Old 02-28-2013, 11:10 PM   #50
3MI Racing
Member#: 200987
I don't think Kurt ever released it. I'd asked and he wanted to thoroughly track test it first.
