Old 02-07-2013, 06:24 PM   #5626
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
Originally Posted by WRXt4cy View Post
Yeah, I wanted to find a "plug and play" solution. I have all the tools and skills to tap it myself, I just don't want to do it that way if I can buy the something that will work.
I simply want to determine that the existing manifold temp sensor's thread size and pitch and buy the right kind of intake temp sensor with a matching thread size and pitch so I can swap into place.
Ill see If I can pull mine off tonight and figure out what size it is.
lukeskywrx is offline   Reply With Quote
Old 02-07-2013, 06:33 PM   #5627
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Haha, thanks. I don't mean to sound like a helpless idiot. I was just hoping to find the info, order the part and then do the work of taking the old one out.
Looking at pictures of the bare manifold it does look to the be the same.
Do you have an FMIC? I just hate the irritating process of putting the TMIC back on.
WRXt4cy is offline   Reply With Quote
Old 02-07-2013, 10:45 PM   #5628
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
Yup, pry the easiest setup to work on with no extra clutter in the engine bay. I always hated dealing with the TMICs.
Hit a new personal best spoolup, 24 PSI at 3500 RPM on the Vf 36 in 4th gear , on corn naturally.
Old 02-07-2013, 11:59 PM   #5629
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Yeah its much easier for sure. I would have thought the VF36 would spool a bit quicker than that in 4th. Do you have a catted DP? I have the VF36 from the engine in my car but it has bad seals so I'm running a VF37. I keep debating on having it rebuilt to see if the ball bearing is noticeably better but maybe it wouldn't be worth it.
I finally got a 3 port BCS installed last night and dialed in. I peaked a little high in 4th.
Old 02-08-2013, 05:33 AM   #5630
2JZ
Member#: 291949
So I went ahead and listened to the advice some of you gave me on this thread...
Well I found a good 05 wrx donor for the swap but its auto. Will it be plug and play for a full jdm sti swap (including the 6MT)?
2JZ is offline   Reply With Quote
Old 02-08-2013, 10:12 AM   #5631
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
4th gear on a 6 speed and a FMIC, no cats, It hits 18 psi by 3200RPM so I cant imagine getting it spooled up any faster. The vf37 on a TMIC is closer to 4000 once it is all spooled up to ~20psi.
Are you on a 5-speed or a 6-speed?
Old 02-08-2013, 10:15 AM   #5632
simon021
Member#: 157532
2002 MY03 EJ207 E85
Dom 1.5XTR Twinscroll!
My VF37 on the sti top mount hits 22psi @ 3589 on my last log w/45 degree intake air temps. This is with the 5MT in 3rd doing a pull from 2500
18psi by 3200 on a front mount is pretty impressive.
Just ordered up a Dom 1.5XTR TS so I'm hoping to get similar spool out of it.
simon021 is offline   Reply With Quote
Old 02-08-2013, 10:31 AM   #5633
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
I can't wait to see how that DOM turns out for you. Keep us posted.
Old 02-08-2013, 02:59 PM   #5634
verve94
Member#: 78701
2004 WRX Wagon
WRBlue, of course
I have a brand new EJ207 swap here on a 2004 WRX Wagon. All is installed, and running nicely with a 22611AF481 ECU (v7).
I need to flash the ECU to at least get off of the 96 octane map! I've started to read the RomRaider forums and frankly, it's overwhelming. I have a friend with a 2.0 Tactrix cable.
1. Is my ECU flashable with this cable (or do I need and RomRaider/EcuFlash? What I saw on romraider's site didn't match my ecu serial, so I'm confused.
2. Has anyone here run RomRaider/EcuFlash successfully on their MacBook Pro without bootcamping it or hacking the Unix version?
3. Does anyone have a map they'd be willing to share with me? I'm not looking for anything crazy...
Thank you!
verve94 is offline   Reply With Quote
Old 02-08-2013, 04:06 PM   #5635
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
1) yes
2) I have no experience with that
3) I do not, but an e-tuner should be able to nail timing down at a safe level on stock fueling if you're not looking for full tuning. Clark Turner has a lot of experience with the 207 tunes, and he may have some sort of starter / off-the shelf map that he'd offer cheaper than a full e-tune, maybe not, too... I dunno.
Old 02-08-2013, 04:22 PM   #5636
vogun16
Member#: 93206
02 WRX....
JDM V7/8/9 RA-R Rotated
The avcs Cel P1306 light ended up coming back after two days of running great. Any suggestions? I will probably swap solenoids and see if the problem follows the solenoid.
vogun16 is offline   Reply With Quote
Old 02-09-2013, 02:27 AM   #5637
Klear
Member#: 312980
My V7 with a TMIC and Dom 1.5XT-R doesn't hit until 4k. I went with the 10cm to take advantage of the 8k redline, which will delay spool-up. It is on a pretty conservative tune at 19 PSI on 91 octane. When I get my E85 tune in a week or so ill post up. According to what I have seen this turbo wants to be in that 22-24 PSI range. I am not complaining since on that 91 octane tune she threw down 320WHp with some left on the table.
What kind of gas mileage are you guys seeing from your 207? I know that it isn't a priority when going the performance route but man mine drinks gas.
Klear is offline   Reply With Quote
Old 02-09-2013, 11:57 AM   #5638
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
I've got the JDM 6MT. I've only done a little tuning on this car because I'm still waiting on a catless DP I ordered. The current one is homemade and catted. I only have one 4th gear log and it was before the 3 port BCS. I wasn't WOT until 3500 and it was at 22 psi by 3900.
The downpipe is the last thing I need and then I'll do the final tuning and post some VD graphs. I feel like the catted DP is final thing holding me back on the stock turbo. I don't think the stock airbox is a restriction on the stock turbo even at higher boost levels but eventually I'm going to get a different intake and see if it adds anything or not.
Old 02-09-2013, 03:23 PM   #5639
D-Rodman
Member#: 110078
05 saabaru artc gr
02 wrx wag wrb ej207
Klear, even with the stock turbo my tuned 207 on a stock gear 5 speed is quite thirsty. Keeping it off boost and on cruise control at 65mph on the highway is the only way to get decent fuel economy out mine. I do a 20 mile each way commute 6 days a week, mostly highway but there's always additional running around town driving or whatever. I can't help myself, I do get on it here and there. Im burning 3/4 of a tank per week, cost between $40-$45, not too bad. You are feeding a big turbo, get throttle happy and fuel is going to burn very fast.
D-Rodman is offline   Reply With Quote
Old 02-09-2013, 04:25 PM   #5640
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
I'm not too surprised that the 207s aren't getting great mileage:
1) Based on Sponaugle's spreadsheet, the piston to deck clearance is quite large. This design difference would result in lower MPGs
2) The CL / OL transitions in the ROM are set for performance, not economy:
listings will be for 2400 / 2800 / 3200 / 3600 / 4000 RPM cells. Both ROMs have 0 at 4000 RPM and above, which will force open loop
- Throttle % switch is 33% / 25% / 23% / 13%/ 0% for JDM. USDM is 70% / 70% / 70% / 70% / 0%
Much less throttle is needed to put it in open loop. Delays are also 0 on version 8 and several hundred counts on USDM.
- Load based switch to OL is based on injector pulse width. This will translate to a g/REV load for a given injector.
JDM is 5.5 / 4.86 / 4.32 / 3.26 / 0
(these would be equivalnet to 7.2 / 6.39 / 5.68 / 4.28 / 0 on 420cc injectors used in EJ205)
USDM is 5.63 / 5.63 / 5.63 / 5.63 / 0
so this is only lower than USDM at 3200 - 4000 RPM (which is a freeway cruise RPM range on the JDM 6-speed)
If you are running a JDM transmission, the car is going to be very easy to put into open loop on a highway cruise. USDM transmissions will still be easier to put into open loop than the USDM ROM, but you'll att least be at an RPM where you won't do it too easily.
The version 8 open loop fuel map is overall a bit leaner though. Probably due to AVCS. it richens from 14.7 to 13s more gradually than the USDM ROM does, but goes from 13s to 11s more quickly.
these differences were probably the most interesting to see when I had my first look at the version 8 ROM last week. The throttle and load transitions are much lower than the USDM setup. This is sure to cost some economy. The engine design with larger piston to deck clearance is simply not setup for economy either.
Old 02-10-2013, 02:43 AM   #5641
Strtsol1109
Member#: 342259
what clutch master cylinder/slave cylinder should i use on a ej207 with a six speed?
Strtsol1109 is offline   Reply With Quote
Old 02-10-2013, 03:51 AM   #5642
kpluiten
Member#: 120273
06 WRBWRXWGN
The engine type has exactly zero impact on the clutch master and slave cylinder you run. That is completely transmission dictated.
Old 02-10-2013, 01:51 PM   #5643
johnfelstead
Member#: 856
2005 JDM STi
I used to see 20psi at 3400rpm on my stock JDM STi with a VF37 in 4th.
Current engine has 31psi @ 3800rpm, 20psi @ 3200rpm on an Owen TS turbo producing 540 FtLb @ flywheel on a Chevron Motorsport TMIC in 4th.
johnfelstead is offline   Reply With Quote
Old 02-10-2013, 03:34 PM   #5644
amroof
Member#: 211224
2005 Saabaru
Who knows
Are you on stock internals still?
Im currently at 25 psi on stock vf37 and i love the way this thing feels. Granted it would feel a lot better if my car didnt come in at 3855 lbs with me in it!
Also klear I get anywhere from 11-20mpg on my v9 207. But I cant seem to keep my foot out of it so im closer to the 11 all the time.
amroof is offline   Reply With Quote
Old 02-10-2013, 03:47 PM   #5645
simon021
Member#: 157532
2002 MY03 EJ207 E85
I'll be very interested in seeing your results. I ordered up my Dom 1.5XT-R w/10cm on friday, hoping to have it installed by the end of the week.
My last VD log showed 331 hp/390 tq on E85 with the VF37. It would be nice to crack 400hp, but honestly not concerned with how much power I make as long as it pulls all the way to redline, I'll be happy.
I'm seeing ~16-18 mpg with E85. Typically there is some asshattery involved in each tank of gas.
Old 02-10-2013, 03:53 PM   #5646
kpluiten
Member#: 120273
06 WRBWRXWGN
I REALLY want to hear more about this turbo. I'm going to play around with my VF36 for a while, but come upgrade time, you have my interest.
Can you give more details on the setup? Stock manifolds? Stock 207? Cost?
Old 02-10-2013, 04:23 PM   #5647
johnfelstead
Member#: 856
2005 JDM STi
I wouldnt want to push that much torque out of a stock motor, the rods and pistons wouldnt like it, i'd expect you would be lifting the heads too.
Top end is stock, heads, cams, valves, inlet plenum etc. Bottom end is a 2.1 using Mahle 2618 pistons, manley rods and stock ej257 crank, stock block, oil pump. I converted it to RCMS 14mm/12mm Group A studs to handle the boost, using Cosworth head gaskets. EcuTek 800cc injectors, stock twin scroll headers and uppipe. It's a relatively cheap forged build really, you could stick with a 2.0 litre and save on the cost of a crank.
Engine is mapped using EcuTek with the stock MAF in a larger induction kit.
Engine bay is pretty stock looking.
Old 02-10-2013, 05:06 PM   #5648
johnfelstead
Member#: 856
2005 JDM STi
I use the car as my daily driver, plus compete in sprints with it in the MLR/22B Sprint series, which is a competition for Subaru's and EVO's in the UK. I won two rounds and came 2nd in 3 rounds in the S2 class for modified road/track cars. The car is a full weight JDM STi. The year was a development year to get to the turbo spec i now have, going from aprox 420BHP/440lbft to 480BHP/540lbft by the end of the year.
Bit of fun footage of it can be seen at 3:25 and 4:06 in this (you also get to see Andy Forrest's 3.3L 1000BHP classic in this one from Blyton Park
2:57 and 2:42-3:03 is me from Oulton Park rally circuit, which has the grip levels of gravel!
2:24 and 3:00 3:10 and 3:28 is from MIRA proving grounds
I finished the season 2nd despite missing two rounds, the winner was also using the same turbo as mine for the last two rounds on a stock 2.0 Spec C engine in an MY03 Spec C.
Old 02-10-2013, 07:24 PM   #5649
Torquey
Member#: 175334
2003 Impreza WRX
JDM v8 EJ207 WRB
^^ NICE videos man... thanks a lot for sharing!
The white GC @ 3:35 on the first video ... sounds SOOO different than any other car on that clip!! And that $&*^ was moving too!
Torquey is offline   Reply With Quote
Old 02-10-2013, 07:34 PM   #5650
johnfelstead
Member#: 856
2005 JDM STi
That is Andy Forrest's 3.6 litre twin turbo H6 he uses mainly on the drag strip. It has just over 1000BHP, was running about 800BHP that day. That car does 0 - 202mph in 15 seconds and 8 second 1/4 miles, it's fully road legal.
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
