Old 05-13-2003, 10:50 PM   #1
yellowrxo2
Member#: 13454
02 wrx
yellow
Default will WRX header fit the new age STI
I have the HKS headers laying around, would anyone know if I can use it on the ej2.5t ( I guess) on the new STI?
yellowrxo2 is offline   Reply With Quote
Old 05-14-2003, 11:03 PM   #2
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
Most likely yes. The layout is the same on the motor.
mr2guru is offline   Reply With Quote
Old 05-15-2003, 10:55 PM   #3
yellowrxo2
Member#: 13454
02 wrx
yellow
wooh yummy, thanks for the info. Next Q, will the ECU replacement be compatible with my current "strader perfromance" type.
Old 05-16-2003, 10:51 AM   #4
Imprezd
Member#: 3357
Is this going on your 2.5Rs or on a STI ? If so.. you'd probably loose power due to the fact the manifold was redesigned on the STI.
Imprezd~
Imprezd is offline   Reply With Quote
Old 05-18-2003, 02:08 AM   #5
yellowrxo2
Member#: 13454
02 wrx
yellow
My auttronics ecu is for the 02 wrx but thinking to use it on the STI. This ECU converts the MAF to MAP sensor signal. My concern is the board layout and the drive by wire setup on the new STI.
Will WRX rotors fit the Baja Stock setup? billzebub Baja Forum 6 03-04-2008 05:59 PM
Will WRX pedals fit the Legacy? JLow03 Legacy Forum 2 11-24-2004 08:58 PM
Will WRX parts fit the STI? DwithBoost Factory 2.5L Turbo Powertrain 4 06-10-2004 04:01 PM
Please post a pic for the New age STi seats SONofSAM Member's Car Gallery 13 07-20-2002 11:02 PM
Will our rims fit the new WRX? Gambit Brakes, Steering & Suspension 3 10-27-2000 09:57 AM
Message Board Statistics All times are GMT -4. The time now is 06:43 PM.
