Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC
Old 02-08-2013, 02:26 AM   #1
tibug
Member#: 273906
1831 Conestoga Wagon
My oxen all died.
Default I need a friend with a lathe
I need to have grooves cut into the outer circumference of aluminum tubing to use snap rings in. Life is so unfair.
Specifically, I would like a piece of 3/4" diameter metal rod with a groove for a snap ring at one end. The rod doesn't need to be more than 1-2" in length. I need it for testing purposes, and if it works out then I would like to commission someone to make a small run of a final product. The final product would be 2" in length, 3/4" diameter, and would have 3-4 snap ring grooves at one end, spaced about 3/16" or 1/4" apart. Depending on price, I'd probably want 25-50 of them to start. Final product material would be aluminum or brass.
tibug is online now   Reply With Quote
Old 02-08-2013, 02:27 AM   #2
Mr_Hox
Member#: 118789
I just went from
six to midnight...
Really? REALLY?
Mr_Hox is offline   Reply With Quote
Old 02-08-2013, 02:31 AM   #3
TrickNipple
A L I M I T
Member#: 86213
Disrespect whole OT
Originally Posted by Mr_Hox View Post
Really? REALLY?
Yes, REALLY! His life is rough.
TrickNipple is offline   Reply With Quote
Old 02-08-2013, 02:32 AM   #4
dr_wheel
Member#: 60106
I eat pieces of
** like you for breakfast
Here you go. Enjoy!
dr_wheel is offline   Reply With Quote
Old 02-08-2013, 07:53 AM   #5
tibug
Member#: 273906
My oxen all died.
Really? REALLY?
5
Old 02-08-2013, 01:17 PM   #6
JonnyV2889
Member#: 197384
2006 WRX Ltd
Not sure where you are. If you want to drive it to nh...hah
JonnyV2889 is offline   Reply With Quote
Old 02-08-2013, 04:34 PM   #7
tibug
Member#: 273906
My oxen all died.
I could send the material to you if necessary. Specifically, I would like a piece of 3/4" diameter metal rod with a groove for a snap ring at one end. The rod doesn't need to be more than 1-2" in length. I need it for testing purposes, and if it works out then I would like to commission someone to make a small run of a final product. The final product would be 2" in length, 3/4" diameter, and would have 3-4 snap ring grooves at one end, spaced about 3/16" or 1/4" apart. Depending on price, I'd probably want 25-50 of them to start. Edit: And the final material would preferably be aluminum or brass.
I will edit the original post to include this information...I wrote that post at 2am and I was.
Old 02-10-2013, 10:19 AM   #8
tibug
Member#: 273906
My oxen all died.
Anybody?
Old 02-10-2013, 11:14 AM   #9
JonnyV2889
Member#: 197384
2006 WRX Ltd
Pm'd you
Old 02-10-2013, 03:03 PM   #10
b1aze
Member#: 284003
2010 Alpine 135i
I could lend a hand. Where are you located? I have access to a machine shop in Marlborough, MA and can surely help you out.
b1aze is offline   Reply With Quote
Old 02-10-2013, 04:12 PM   #11
tibug
Member#: 273906
My oxen all died.
I'm in northeastern CT near UCONN. JonnyV2889 has gotten in contact with me, but if that falls through I'll be sure to give you a message. I don't actually need to be there with you; if it came down to that, I could send you the metal to use or you could buy it and charge me for it. Anyway, I really appreciate the offer!
Old 02-11-2013, 08:08 AM   #12
b1aze
Member#: 284003
2010 Alpine 135i
Sure thing. As long as you give me dimensions of the clip location and such, it shouldn't be a problem.
Message Board Statistics All times are GMT -4. The time now is 08:31 PM.
