Old 02-07-2013, 12:27 PM   #26
04ScoobyWtf
Member#: 287974
I just use wd40 and put everything in bags
04ScoobyWtf is offline   Reply With Quote
Old 02-07-2013, 04:07 PM   #27
kakarot09
Member#: 182375
08 Sti
Wrbm
what did you end up doing for bearing clearances?
I use WD-40 also.
kakarot09 is offline   Reply With Quote
Old 02-07-2013, 07:59 PM   #28
romanlynch
Member#: 126684
02 wrx
PLATINUM silver baby
The rods will be at .0017 but the mains are a little different story. .0014, .0017, .0016, .0018, .0024 as they sit now. I really dont feel like buying a whole set of std size to fix #5 so I'll see how this treats me. The std size would bring that down to .0014 as all the bearings will be +.001 clearance.
romanlynch is offline   Reply With Quote
Old 02-07-2013, 08:49 PM   #29
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Swap a half shell from the .0014 and .0024 bearings.
Old 02-08-2013, 12:26 AM   #30
romanlynch
Member#: 126684
02 wrx
They're the same bearing, how would that change it?
Old 02-08-2013, 01:38 AM   #31
kakarot09
Member#: 182375
08 Sti
Wrbm
5 is a thrust bearing.... How would you swap it anyway?
Interesting. I had .007 .009 .008 .001 .0017 or something like that. Not looking at the sheet right now. Anyway thrust bearing was much looser. Also found out today that my block was not machined round for the pistons
Old 02-08-2013, 02:34 AM   #32
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Originally Posted by kakarot09 View Post
5 is a thrust bearing.... How would you swap it?
Ah good point.
If it was not, it would work. If they were the same bearing they would measure the same, right?
Old 02-08-2013, 07:16 AM   #33
romanlynch
Member#: 126684
02 wrx
I'm kind of worried about that too. I haven't been able to find a torque plate yet and I refuse to pay $350+ to use it once.
Abooth - if it was 1-4 or a rod bearing then yea I could just use a +.001 halve and a std halve.
