#1 |
Member#: 310505
MWSOC
Vehicle:2005 Legacy GT |
Just recently my car has been running rich and I can tell by the amount of smoke coming out of the exhaust form unburnt fuel. Around the same time, my EGT gauge stopped reading anything. I read around and found out about the 2.2k resistor mod that supposedly fools your computer into thinking that it is getting a signal. The confusing bit to me was that they also say its a thermocouple and I know that thermocouples work by outputing a small voltage which is then converted to a temperature. If that is the reason, why would a resistor imitate a voltage being there?
#2 | |
Member#: 282614
NWIC
Vehicle:2006 Wrx sti Black pearl |
#3 |
Member#: 310505
MWSOC
It has been tuned, just started running rich and thought it may be related to the EGT not showing up now. It could be just a broken wire to the gauge, more or less wondering why a resistor would be able to replace the EGT sensor when it is outputting a voltage.
#4 |
Member#: 316415
Vehicle:2006 WRX WRB |
Also interested in the answer to this!
#5 |
Member#: 332416
SCIC
Vehicle:2002 WRX Bugeye Silver |
its to small to be a thermocouple...It doesnt produce millivolts...It senses Temperature and thats it..
#6 |
Member#: 330625
NESIC
What? Thermocouples are tiny, its literally 2 wires of dissimilar metals bonded together. And the voltage differential between two dissimilar metals is related to their temperature. I find it hard to believe that there is a thermoresistor that is cheap to make that could function in the required temperature range.
