Welcome to the North American Subaru Impreza Owners Club Monday May 30, 2016
Old 02-07-2013, 11:26 AM   #1
shiplemw
Member#: 203905
Default Terrible MPG from 23mpg to 10mpg. Suggestions?
I searched and found plenty of threads regarding terrible fuel economy. This is a bit different. I've been seeing 20-23mpg for the past several years with this vehicle ('05 STI, stage 2). I consider this normal with my daily drive of 70+ miles, mostly highway. With no noticeable change to my driving habits or my drive I'm now in the 10mpg area on this tank. I don't warm my car up for longer than 30-45 seconds in the morning before my commute. Spark plugs were changed ~10k miles ago with no signs of fouling, car idles well, no white smoke, tires / wheels are in good condition, alignment was done ~10k miles ago, oil consumption ~1/2Q every 1k miles and there are no check engine lights. The only recent things are that a.) I unhooked the a/c belt because the idler was squealing and I had not had time to get parts and b.) yesterday I diagnosed the aftermarket springs in my front struts are moving so I need to take them off and re-install. Any ideas or other things to look at?
shiplemw is offline   Reply With Quote
Old 02-07-2013, 11:51 AM   #2
Dave D.
Member#: 130990
06 Red Ltd.Wagon
20g-xtr 427/427 JJtuned
Does it correlate exactly with the AC belt removal?
If so, it's the only variable I can see. Put it back on and see what happens.
Old 02-07-2013, 11:53 AM   #3
WMCCook29
Member#: 152685
2016 Forester XT
I would start by checking the front O2 sensor.
WMCCook29 is offline   Reply With Quote
Old 02-07-2013, 12:01 PM   #4
MaddMax
Member#: 9264
2016 BMW M235i 6MT
Do you have a way to watch your AFR and O2 sensor values? Something as simple as the Torque app would do this.
I don't know how long you've owned the car, but a 15-20% drop in fuel economy will happen if you live an area that has a real winter. Secondly, if you do a lot of snow driving, that too will suck out MPGs.
Regardless, you MPGs are way low. If it was in the 15-17mpg range, I'd say that's the way it goes especially running Stage II. Seeing that you've got a tune, I'd check to make sure there's not some tune setting that causing an overly rich condition during normal driving. A lot of these tunes richen the AFR quite a bit above 3000rpms compared to stock and if you drive in these rpm ranges, then you're mpgs are going to suffer.
MaddMax is offline   Reply With Quote
Old 02-07-2013, 12:06 PM   #5
KOJAK-02-WRX
Member#: 208052
2004 SGM FXT-6speed
*SOLD* 02 PSM WRX
Not sure it would cause that much issue but try cleaning MAF sensor.
KOJAK-02-WRX is offline   Reply With Quote
Old 02-07-2013, 12:24 PM   #6
shiplemw
Member#: 203905
It didn't exactly correlate to the removal of the belt. I thought about putting it back on but with the reduction in loading it should get better if only by a tiny amount, not worse. Something to try though.
I've never done this. I'm assuming there is a test where a certain voltage should be seen at idle, etc? Any more details?
I've had the car for 5 years, ~100k miles. No major dips in fuel economy like this. I have romraider and can log some data and potentially compare it to previous results.
That's a simple one I'll try that tonight.
Old 02-07-2013, 12:40 PM   #7
WRXSD
Member#: 136539
2005 WRX Wagon
CGM Stg. 2
WRXSD is offline   Reply With Quote
Old 02-07-2013, 12:59 PM   #8
shiplemw
Member#: 203905
Originally Posted by WRXSD View Post
Shouldn't a CEL come on for a failing O2 sensor?
Old 02-07-2013, 04:44 PM   #9
WRXSD
Member#: 136539
2005 WRX Wagon
CGM Stg. 2
Maybe for a sensor that has completely failed, but not one that has started to sense incorrectly. I've seen plenty of these threads with the same problem. I'm not going to say I'm 100% sure, but it is a cheap (and overdue) maintenance item.
Old 02-07-2013, 04:46 PM   #10
Leafy
Member#: 330625
2006 WRX
Is the car slower? If it is slower and with poor fuel economy, I'd be checking compression.
Old 02-07-2013, 05:20 PM   #11
Karlot
Member#: 339923
2006 Impreza WRX STi
grey
lol you got 23mpg???? damn dude i only got 18 on a stage 2 on my 06sti, and that's if i am out of the pedal.
Karlot is offline   Reply With Quote
Old 02-07-2013, 05:38 PM   #12
CarverHouseRally
Member#: 315692
2005 WRX STi
Same, 23 seems hard to believe.
CarverHouseRally is offline   Reply With Quote
Old 02-07-2013, 06:03 PM   #13
Leafy
Member#: 330625
2006 WRX
Not that hard. With my stage 2 not dialed in I got 26 on an all highway run. Normal use right now is around 12-15 because of that pesky 1.5 mile commute to work in the winter.
Old 02-07-2013, 06:07 PM   #14
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
This...
Usually, if there is a sudden drop in mpg, it has to do with a faulty o2. Also check for vacuum leaks.
Old 02-07-2013, 06:15 PM   #15
shiplemw
Member#: 203905
I usually get between 270-300 miles / fillup (~12-13 gal). Like I said highway miles, it's flat and I cruise 70.
I'll do a test on the O2 sensor tonight if I can. Might have to wait until the weekend.
Old 02-07-2013, 09:36 PM   #16
DerekB707
Member#: 220114
07 2.5i EJ257 6MT
Rotated BW S200sx-56
I've gotten 24mpg on the highway using my CC at 70mph on stage 2 many times, but touch the gas pedal and it drops pretty fast. Not sure if you have an Acess Port, but checking all the things people are recommending here is pretty easy using one.
DerekB707 is offline   Reply With Quote
Old 02-08-2013, 02:10 AM   #17
esteve
Member#: 28716
2006 STI
Wow, so almost all highway driving and you're only getting 10 mpg now? With a 50% drop in fuel economy, I'm surprised there aren't any signs of trouble. Has the oil consumption been at 1/2 quart per 1K miles for a long time or just recently? I would also say check for any fuel leaks but you'd notice the odor.
esteve is offline   Reply With Quote
Old 02-08-2013, 08:39 AM   #18
danger1138
Member#: 279525
04 rex luger!
That o2 is only for 2.5l sti's correct, so would that fit my hybrid which has a 2.5L block? Confused.. Or should i go with a sensor made specifically for an 04 2.0L wrx?
danger1138 is offline   Reply With Quote
Old 02-08-2013, 10:47 AM   #19
danger1138
Member#: 279525
04 rex luger!
Im also thinking of switching to a new o2 since my car has 153k on odometer but 15k on built motor. I believe previous owner never changed it either.. My car eats gas like a mother*****r.
