Welcome to the North American Subaru Impreza Owners Club Saturday May 30, 2015
Old 02-08-2013, 10:43 AM   #1
JR_
Member#: 344802
2013 Impreza WRX STi
Default CEL code p2432 help!
After installing my hella supertones I had a CEL code pop up. It was p2432 which is secondary air injection system air flow/ pressure sensor circuit low. I used the relay provided and also connect a inline 20 fuse. It pops on every now and again and I have to keep deleting it with my access port. Any ideas of what it is?
JR_ is offline   Reply With Quote
Old 02-08-2013, 10:48 AM   #2
EvileyeZ88
Member#: 233501
07AD 337/335SAXWAGON
99 outback sport
Has nothing to do with the horns.
Its one of the air pump valves going bad.
Figure out if they are stuck open or closed. If closed pull the fuse and have someone tune out the code.
If stuck open get one or two block off plates (depending on model) and slap em on the valves, tune the codes out.
You can go one step further and remove the system if you like, but its a fair bit of work.
Here is a thread with a lot of information about the issue.
http://forums.nasioc.com/forums/show....php?t=1209260
Hope this helps
~Evil
EvileyeZ88 is offline   Reply With Quote
Old 05-12-2013, 03:48 PM   #3
Deviancekicksin
Member#: 80300
05 STi
So my moms car just threw this CEL (06 Wrx)...
Seeing as how it's bone stock, not AP tuned or anything how can I fix this without having to tune the CEL off? Easy fix?
Deviancekicksin is offline   Reply With Quote
Old 05-12-2013, 07:40 PM   #4
Cathexis
Member#: 335445
2012 WRX - BLK STIG
Stg. 2 - 287whp/317wtq.
That leaves only one option, right? Fix the problem. Replace the faulty air pump valve.
Cathexis is offline   Reply With Quote
Old 05-13-2013, 12:04 AM   #5
Deviancekicksin
Member#: 80300
05 STi
I suppose but I don't even know where to start hah. I'm not too mechanically inclined bit feel like I could do this. Screw it, if I try and screw up oh well ;-)
Old 05-13-2013, 12:07 AM   #6
Cathexis
Member#: 335445
2012 WRX - BLK STIG
There is a youtube video on nearly everything, lol! I don't think you could screw it up, no fabrication or anything.
Old 05-13-2013, 12:15 AM   #7
Deviancekicksin
Member#: 80300
05 STi
Thanks man. I just need to find the part (which I think I did)... Oof $500 ;-( expensive Mother's Day gift.
Old 05-13-2013, 05:54 AM   #8
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
no....no ya dont have to do all that
there is a HUGE thread here on this issue
the 06 is easy and cheap......and is different than the 07
Old 05-13-2013, 01:15 PM   #9
Deviancekicksin
Member#: 80300
05 STi
The thread you're talking about is linked in this thread... It's about the removal of the air pump and if it's safe... I don't want to delete it. I want to replace it.
And if you're talking about a different thread link me! ;-)
Old 07-12-2013, 11:47 AM   #10
Kraj81
Member#: 361484
2006 Impreza WRX
My car according to the previous owner did not have any mods, I don't see any. However she stated they changed the cat converter and ever since the CEL light and the cruise control light has been on (with the cruise control light blinking). I did a "stage 1" ECU flash last night and it seemed to have worked but this morning they came back on. So I plugged in the AP and the codes are as followed...
P1410
P2444
P2432
Should I be worried? Is it a simple fix or seeing that I've never worked on cars before, is it wiser to take it to a dealer/autoshop?
Kraj81 is offline   Reply With Quote
Old 09-20-2013, 02:00 PM   #11
AKFOWLER
Member#: 366222
2011 subaru WRX
lightning red
Its something with you're fuel injection or your
Secondary air injection system switching valve is stuck open. Sometimes they rust and get stuck.
There are 2 of these. One under your intercooler and one under the intake manifold.
AKFOWLER is offline   Reply With Quote
