Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC
Old 02-08-2013, 02:26 AM   #1
tibug
Member#: 273906
2006 VTECAccordVTEC
Also it has VTEC.
Default I need a friend with a lathe
I need to have grooves cut into the outer circumference of aluminum tubing to use snap rings in. Life is so unfair.
Specifically, I would like a piece of 3/4" diameter metal rod with a groove for a snap ring at one end. The rod doesn't need to be more than 1-2" in length. I need it for testing purposes, and if it works out then I would like to commission someone to make a small run of a final product. The final product would be 2" in length, 3/4" diameter, and would have 3-4 snap ring grooves at one end, spaced about 3/16" or 1/4" apart. Depending on price, I'd probably want 25-50 of them to start. Final product material would be aluminum or brass.
tibug is offline   Reply With Quote
Old 02-08-2013, 02:27 AM   #2
Mr_Hox
Member#: 118789
I just went from
six to midnight...
Really? REALLY?
Mr_Hox is offline   Reply With Quote
Old 02-08-2013, 02:31 AM   #3
TrickNipple
moon moon
Member#: 86213
Originally Posted by Mr_Hox View Post
Really? REALLY?
Yes, REALLY! His life is rough.
TrickNipple is offline   Reply With Quote
Old 02-08-2013, 02:32 AM   #4
dr_wheel
Member#: 60106
I eat pieces of
** like you for breakfast
Here you go. Enjoy!
dr_wheel is offline   Reply With Quote
Old 02-08-2013, 07:53 AM   #5
tibug
Member#: 273906
2006 VTECAccordVTEC
Also it has VTEC.
Really? REALLY?
5
Old 02-08-2013, 01:17 PM   #6
JonnyV2889
Member#: 197384
2006 WRX Ltd
Not sure where you are. If you want to drive it to nh...hah
JonnyV2889 is offline   Reply With Quote
Old 02-08-2013, 04:34 PM   #7
tibug
Member#: 273906
2006 VTECAccordVTEC
Also it has VTEC.
I could send the material to you if necessary. Specifically, I would like a piece of 3/4" diameter metal rod with a groove for a snap ring at one end. The rod doesn't need to be more than 1-2" in length. I need it for testing purposes, and if it works out then I would like to commission someone to make a small run of a final product. The final product would be 2" in length, 3/4" diameter, and would have 3-4 snap ring grooves at one end, spaced about 3/16" or 1/4" apart. Depending on price, I'd probably want 25-50 of them to start. Edit: And the final material would preferably be aluminum or brass.
I will edit the original post to include this information...I wrote that post at 2am and I was.
Old 02-10-2013, 10:19 AM   #8
tibug
Member#: 273906
2006 VTECAccordVTEC
Also it has VTEC.
Anybody?
Old 02-10-2013, 11:14 AM   #9
JonnyV2889
Member#: 197384
2006 WRX Ltd
Pm'd you
Old 02-10-2013, 03:03 PM   #10
b1aze
Member#: 284003
2010 Alpine 135i
I could lend a hand. Where are you located? I have access to a machine shop in Marlborough, MA and can surely help you out.
b1aze is offline   Reply With Quote
Old 02-10-2013, 04:12 PM   #11
tibug
Member#: 273906
2006 VTECAccordVTEC
Also it has VTEC.
I'm in northeastern CT near UCONN. JonnyV2889 has gotten in contact with me, but if that falls through I'll be sure to give you a message. I don't actually need to be there with you; if it came down to that, I could send you the metal to use or you could buy it and charge me for it. Anyway, I really appreciate the offer!
Old 02-11-2013, 08:08 AM   #12
b1aze
Member#: 284003
2010 Alpine 135i
Sure thing. As long as you give me dimensions of the clip location and such, it shouldn't be a problem.
