Old 11-27-2012, 09:40 AM   #151
M45
Member#: 333446
2013 Impreza SL CVT
Old 11-27-2012, 09:55 AM   #152
M45
Member#: 333446
2013 Impreza SL CVT
actually - it's looking like you don't really need to jack the car up to change the oil. this guy just gets the car on some 2x4s and reaches under there.
http://blogs.insideline.com/roadtest...il-change.html
does this seem like it's pretty doable? I'm wondering if he's reaching from the front or from the side to get to the drain...
Old 11-27-2012, 09:58 AM   #153
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Originally Posted by M45 View Post
I'm sure those would be fine, as long as they're installed on a jack stands with a deep "U" as specified earlier. The deep "U" straddles the pinch weld.
Old 11-27-2012, 10:02 AM   #154
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
That's fine, and would be even easier with a Fumoto valve installed. But I like to crawl under my car as part of the oil change process in order to look around for leaks, and inspect hoses, suspension parts, CV boots, brake lines, and so on.
Just part of my process that I don't want to eliminate by not sliding under the car. FWIW.
Old 02-08-2013, 09:13 PM   #155
M1wod00
Member#: 346408
2013 Outback
Default M1wod
I purchased a 12 pack of filters and washers from Subaruonlinarts.com. I believe the cost was around $75.
M1wod00 is offline   Reply With Quote
Old 02-23-2013, 04:15 PM   #156
PDX_Scubie
Member#: 346793
2002 RS swap WRX
fumoto valve or quick oil drain valve which i think is what there company calls them now, but its deeefinetly the way to go. First time doing the oil change i accidentally over filled but a 1/4 quart and jus throw a small pan under it, flip the lever, let it drain for 5-10 secs, click it back. Done. I can do full oil change in 10 - 15 mins depending how long it takes to drain since its a smaller hole its draining from. but no having to replace crusher washer.
PDX_Scubie is offline   Reply With Quote
