Old 03-25-2010, 12:28 PM   #76
Evil Imports
Member#: 14732
+ 13 B8
I used the same Y as this, but it was cheaper, I bought it from a ford lighting performance place, i am sure you will be able to find it cheap,
http://www.coleparmer.com/catalog/pr...u=3062023&pfx=
Evil Imports is offline   Reply With Quote
Old 09-03-2010, 11:15 AM   #77
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
on page 3 in post 58 Slorice posted a pic DB must have posted of the fuel pump setup. in the pic there is a Y fitting connected to the pump assembly, and a second one to the right by itself with fuel hose connected on each end.
Does the kit come with that second Y fitting too? If so what is it for?
Thanks in advance.
rexworx is offline   Reply With Quote
Old 11-01-2010, 08:40 PM   #78
russian89
Member#: 230956
Guys,
I am looking at a design project for fitting a brushless fuel pump directly into a subaru fuel tank
Still keeping many of the OE items.
The small single pump will flow 280ltrs @ 5 bar pressure, is fully compatible with Ethanol and Methanol
Any ideas comments before I start !!
Rob.
russian89 is offline   Reply With Quote
Old 11-01-2010, 08:50 PM   #79
sube-trex
Member#: 97577
2001 IS 300
Originally Posted by SloRice View Post
Oh, can I get the makeshift Gatorade catch can!
sube-trex is offline   Reply With Quote
Old 11-02-2010, 11:23 AM   #80
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
That pump has got to be loud right there.
06rexwagon is offline   Reply With Quote
Old 11-17-2010, 02:29 PM   #81
rexworx
Member#: 103232
^^^ Im pretty sure thats the fuel filter buschur gives you with the kit.
Old 11-18-2010, 02:38 AM   #82
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
David has said some improvement for the pump will be coming out shortly that should increase output. Here is a chart for the flow data on the EVO X pump which david has said that the subaru setup flows extremely similar to.
project_skyline is offline   Reply With Quote
Old 11-18-2010, 08:45 AM   #83
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
So realistically the pumps are good for the 310-350 L/hr range on most Subaru applications. It isn't too common for guys to push over 35 psi, though some do
Did he mention which pumps he used in creating this graph?
Old 11-18-2010, 09:05 AM   #84
rexworx
Member#: 103232
+1 on which pumps he used...
Old 11-18-2010, 09:33 AM   #85
mtcs
Member#: 180640
2000 Drag RSTi
8.96 @ 163
When I got my buschur double pumper, I had the same question. Apparently the walbro 342 (Subaru walbro) sucks ass. So in the kit they include two universal walbro pumps. These universal walbros flow a ton more than the walbro Subaru 342s ever could
mtcs is offline   Reply With Quote
Old 11-18-2010, 09:43 AM   #86
Homemade WRX
Member#: 33782
96 bastard child
well I know that the walbro inline 255's curb stomp the in-tank Subaru 255 (342).
Are you saying that other intank walbro 255s (didn't know they were mechanically any different) flow better at higher pressures?
Old 11-20-2010, 01:59 AM   #87
mtcs
Member#: 180640
2000 Drag RSTi
8.96 @ 163
The intank universal walbro have a much larger discharge port than the GS342 pumps do. So it's able to flow a lot more fuel.
In the past, I tried to hookup two intank gs342s and it didn't go too well. No comparison between the 342 and universal. Universal is a ton better. That's why that is all that Buschur uses in their double pumpers.
Old 01-11-2012, 05:58 PM   #88
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
any updates on this setup? I am thinking about running this in my car e85 500+whp
medamullet is offline   Reply With Quote
Old 01-12-2012, 07:13 AM   #89
Pacobeagle
Member#: 8775
2010 "Zed" 1000
Orange/White
dumb question, but could someone simply use a stock pump and add a 342 for a mild build? I wonder how much hp that would support.
Pacobeagle is offline   Reply With Quote
Old 01-12-2012, 08:01 PM   #90
fastblueufo
Member#: 212154
02 billet crank
pauter rods, pt5857, E85
I made mine out of the stock setup for around $150
fastblueufo is offline   Reply With Quote
Old 01-13-2012, 12:33 PM   #91
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
AWESOME soap dispenser!
ride5000 is online now   Reply With Quote
Old 01-14-2012, 08:51 AM   #92
Pacobeagle
Member#: 8775
2010 "Zed" 1000
Orange/White
Now that's funny!
Old 01-14-2012, 04:43 PM   #93
fastblueufo
Member#: 212154
02 billet crank
Kmart special speciaKmart
Old 02-09-2013, 04:35 PM   #94
casper64
Member#: 178083
2004 545 awhp, sti
blue
Have a Nice Day?
Well this is good dual pump set up,but wat about the fuel line will it be able to handle the extra fuel.
casper64 is offline   Reply With Quote
Old 02-13-2013, 12:14 PM   #95
mtcs
Member#: 180640
2000 Drag RSTi
8.96 @ 163
If I remember correctly, dave made over 600whp on this pump on his mustang dyno with stock hardlines.
Old 02-13-2013, 01:06 PM   #96
meat_WRX
Member#: 96919
2004 sti
black
yes they will
meat_WRX is offline   Reply With Quote
Old 02-15-2013, 10:17 PM   #97
casper64
Member#: 178083
2004 545 awhp, sti
blue
Originally Posted by meat_WRX View Post
yes they will
Well thats good to know, now I can proceed.
Thanks.for the info.
FS: BRAND NEW Buschur Racing Modded Walbro 255l Fuel pump blowbyu24 Engine/Power/Exhaust 19 03-02-2007 12:53 PM
Buschur Racing High Output Fuel Pump Dasani Engine/Power/Exhaust 1 02-28-2007 10:00 AM
Buschur Racing High Output Fuel Pump Dasani TXIC Private Classifieds 3 02-28-2007 09:56 AM
Anyone have dyno results of Buschur racings modded 255l fuel pump blowbyu24 Built Motor Discussion 6 02-26-2007 12:32 PM
alternative to intank dual walbro fuel pumps tino Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 09-18-2005 09:34 PM
