Old 01-31-2013, 05:28 PM   #51
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
^They arnt helping at all?
Old 02-09-2013, 05:17 PM   #52
DJIMPREZA
Member#: 1199
1994 Supra+1K, 22b
alike, 07STI
3th time pushing coolant on the same CNC sleeved block it has been teared apart twice, decked it twice (10 ra all the time) using half inches studs, although this block has been 10 10 sec passes and some nitrous it should had held together longer, its a minor leak there, so small the coolant passes the CO chemical test and of course all sort of leak down tests at different pressure/temperatures, it only shows burbles and coolant in excess at the overflow tank (losing coolat slowly) a few seconds after you step on Boost.
we have built 10 sleveed block the lst year, all US sources, one locally, seen 10 more from other guys, no one ever has lived that long so we can say the thousands expent in the process were OK, its simply cheaper and less frustrating to use a bare new block do a few passes under 30 psi on a knock free tune, and when it pops after a while just get a new stock one, and if you like to have it for long periods, keep a very conservative tuning afr and timing wise for the street and low boost (under 500whps may say)
thats the 2.5 nature, too bad the 2.0 was forgotten by us... it would have been another history without the head gasket sealing issues, maybe difficult to get that much spool/torque/power band, as the Ej doesnt rev high enough for a street 9 or 10 sec 2.0...
Time for the evo world and fight with drivetraing problems instead of head gaskets....or
its time for CNC guys to build what the rally guys uses to keep the cylinder pressures in place
http://www.rogerclarkmotorsport.co.u...productID=1234
http://www.rogerclarkmotorsport.co.u...productID=1233
http://www.rogerclarkmotorsport.co.u...productID=1238
DJIMPREZA is offline   Reply With Quote
Old 02-09-2013, 11:33 PM   #53
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
8, 9, 10s without coolant problems... Few of those aren't sleeved either.
P&L will be releasing the block bracing run in both the 8 second cars soon. No sleeves and trapping 165mph
Old 02-10-2013, 08:30 AM   #54
DJIMPREZA
Member#: 1199
1994 Supra+1K, 22b
alike, 07STI
We dont have coolant problems on stock blocks, and or just 1 sleeved block that has been kept on low boost, (up to 25) just 10 sec passes, but when running 35 psi a a 150 nos shot the stock block liners doesnt live that much,
We just dont believe on sleeved subaru blocks, we even had one o ringed that never sealed as the mls gasket couldnt flow around the ring, a total disaster, we have seen many braces at this board, and they cant stop the liners to crack, or what type of bracing are you taliking about? like the wrc bushings and o rings?
Old 02-10-2013, 12:56 PM   #55
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
You said you haven't seen any low 10s Subaru that don't push coolant.. I was pointing out that they happen to exist.
46psi thought the stock liner and 133-134 1/8th, with no problems the whole season. Your 35psi and 150shot could be making more cylinder pressure for lots of reasons and breaking the motors. Not the liners fault
If you oringed a sleeved motor and it didn't seal, then you made some bad measurements.... Again not the motors fault
Lots of pictures and theories get posted on forums, some never get tested, some get tested and never post the failed results. P&L has been testing theirs for 2yrs and I think they are finally ready to move into production. It works
Old 02-10-2013, 02:40 PM   #56
DJIMPREZA
Member#: 1199
1994 Supra+1K, 22b
alike, 07STI
Not only on the nitrous sleeved block we had issues, remember we have 9 sec to 10 sec street cars that meet the track occasionally, they dont have the long life spam needed for a complete season and or drive on the street at 160+mphs, so up to a point a can say they exists too, but not for so long for such the labor headache and price..
Your 46 psis on the stock liners? what studs? ethanol? what head gasket? wire/oringed? I dont think that possible in the long run on a stock bare block, the stadistics say so, you may be talking that yours has the PL bracing and supported the 46 psis---
what are we talking here, block guard machinned out?
Do you have some pics? where could we find some extra info about what we consider a glorious fix to the ej25 head gasket sealing/stock liners cracking problem?
Old 02-11-2013, 02:06 PM   #57
ckyguy68
Member#: 316296
2006 STIROID
[email protected] on 29psi
Well-put, Jr
ckyguy68 is offline   Reply With Quote
Old 02-11-2013, 08:57 PM   #58
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
46psi is on the OEM LINERS, P&L BIG BOY STUDS and PUMP e85. Dont know what HG they use and ringed.
This car that I tune
No pics available as of yet. It works though, 1000000% sure of it for the last 2 seasons without a single liner/piston/rod/HG failure.
This year we are switching to bigger injectors and a E based race fuel called FTW. Shooting for the 7s
Old 02-11-2013, 09:30 PM   #59
DJIMPREZA
Member#: 1199
1994 Supra+1K, 22b
alike, 07STI
very nice car!!, we are definately insterest in this engineered magical product and we would love to see it and test it before anymore expectations we can make out of it, 46 psi on stock liners is a awesome acomplishment for a aluminum subaru boxer with such a bore on the ej25...
Last Block dropped a sleeve again, for the 2nd time, incredible how a CNC machinist well known could do such a work, to drop the sleeves once is a hit an miss, but after decking the block flat out again and then drop again??
I am really sick at this, so, my frustrations are obvious with the subaru boxer engine trying to play and keep up with big boys (high boost territory and 9 sec full wieght cars)
Old 02-12-2013, 12:01 AM   #60
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
Nothing left to test, been testing it for 2 yrs with both a 6spd and a auto, both have trapped over 160mph. Now you just wait for it to be released
If you are using Dartons, you may want to check the cut on the base of the sleeve vs the cut in the block base for receiving. . Measure the angles, maybe you are using one that is not the same as the sleeve itself..
Just for ****s, we have run over 35psi on unsleeved motors plenty of times. My own wagon went 107-09 1/8th with stock sleeved, **** even a stock motor with no orings or anything. No frustrations, just fun for the most part.
Old 02-12-2013, 12:05 AM   #61
...CHUCKLES...
Member#: 149674
2006 LimitLess STI
SGM
What machinist are you using?
...CHUCKLES... is offline   Reply With Quote
Old 02-12-2013, 08:27 AM   #62
tachrev
Member#: 115260
04 WRX
205/22E Hybrid w/ VF39
Hey, if he's already blowing up uber high dollar sleeved blocks, it would be a lot cheaper and easier to just run stock sleeve blocks and see how they last.
tachrev is offline   Reply With Quote
Coolant is disapearing with no signs of leaks!! boostinscooby Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 20 06-19-2007 12:37 AM
WRX spitting coolant, but no sign of leaks MT_WRX Service & Maintenance 19 07-25-2005 04:35 PM
Preventing Head Gasket Failures chrispy Legacy Forum 1 04-18-2004 09:07 PM
Head gasket failure in 99 Forester oshkasmum Canada Region Forum 9 03-12-2004 03:12 PM
regarding '99-'02 2.5s: With extended warr., do we hope for head gasket failure? dingo dave Warranty Issues & SOA Problems 15 03-09-2004 02:49 PM
