Old 01-24-2013, 07:56 PM   #1
xXRaMpAgEXx
Member#: 279825
2004 Impreza WRX
Default 04 wrx vf39 6k rpm sputter
Ok so car is 04 wrx with 72k miles well maintained, just did spark plugs recently.
Mod list
Vf39 low miles
565cc sti pinks
Catless turbo back exhaust & uppipe
Cobb intake
Turbo inlet
Process west tmic
Cobb vf39 base map
After turbo swap it ran an pulled fine. Recently it started sputtering at 6k rpm. If its in neutral it won't do it but if it is in gear it will. Car has 4eat.
xXRaMpAgEXx is offline   Reply With Quote
Old 01-24-2013, 09:43 PM   #2
quickshot
Member#: 160846
2002 WRX Wagon Stg 2
Bump-o-mundo
quickshot is offline   Reply With Quote
Old 01-24-2013, 09:47 PM   #3
Dakota D
Member#: 293894
2006 wrx sti
cgm
did you gap your plugs?have you ever replaced your fuel filter?,how do the datalogs look?
Dakota D is offline   Reply With Quote
Old 01-24-2013, 10:04 PM   #4
xXRaMpAgEXx
Member#: 279825
2004 Impreza WRX
My friend did the spark plugs a few weeks ago. Don't know if he gapped them. And fuel filter is a good question. Haven't data logged, what should I be looking for?
Old 01-24-2013, 10:16 PM   #5
Smurftastic
Member#: 243697
02 | BLOD Founding
Member | TopScoob 031
When was the last time you changed your coil packs? This is a common culprit of this issue.
Smurftastic is offline   Reply With Quote
Old 01-25-2013, 01:42 AM   #6
xXRaMpAgEXx
Member#: 279825
2004 Impreza WRX
I have never changed the coil packs.
Old 01-25-2013, 04:57 PM   #7
michael_wrx
Member#: 130041
2004 WRX
Java Black
Collapsing turbo inlet?
michael_wrx is offline   Reply With Quote
Old 01-25-2013, 09:07 PM   #8
xXRaMpAgEXx
Member#: 279825
2004 Impreza WRX
Wouldn't that have always been an issue?
Old 02-09-2013, 02:32 AM   #9
axleon2
Member#: 154117
2004 WRX
JBP
A friend of mine had the same issue with the same mods, replaced the coil packs and it solved the issue...
axleon2 is offline   Reply With Quote
Old 02-10-2013, 05:39 AM   #10
tobyjr
Member#: 275084
1996 Impreza WRX
Sounds like plugs or coil packs. Have those checked first then go from there.
tobyjr is offline   Reply With Quote
