Old 02-08-2013, 01:10 AM   #1
Stanley072.5i
Member#: 204266
Default Wiring Guages
so i have the ATI center gauge pod for my 2011 wrx. i am getting the fuse taps so that i can just wire in 3 guages (boost, EGT, Wideband A/F)... power, accessory, headlights...etc. should i be concerned with wiring all the power wires together and putting them in to one fuse tap thats going to go in my fuse box? i know that my AEM digital A/F gauge only takes 1.3 amps to run and assuming that the other ones are equal if not less then the A/F gauge. So since all of the guages combined will probably not exceed the 10amp fuse will it be ok???
Stanley072.5i is offline   Reply With Quote
Old 02-08-2013, 12:18 PM   #2
Stanley072.5i
Member#: 204266
Bump***
Old 02-08-2013, 02:05 PM   #3
tmburke
Member#: 342345
2008 WRX Hatch VF-52
SSM
There's no way 3 gauges would be more than 10amp, I'd guess they'd be less than 3amp. You're totally fine.
tmburke is offline   Reply With Quote
Old 02-08-2013, 02:23 PM   #4
S1CkWrx
Member#: 325249
2012 wrx
dgm
kinda curious about this too. so it is okay to pigtail for example a boost gauge with a AEM UEGO wideband on the same fuse connections?
S1CkWrx is offline   Reply With Quote
Old 02-09-2013, 12:14 PM   #5
S1CkWrx
Member#: 325249
2012 wrx
dgm
bumpp..
Old 02-10-2013, 09:38 AM   #6
tmburke
Member#: 342345
SSM
YES! It's fine
