Go Back   NASIOC > NASIOC Technical > Factory 2.5L Turbo Powertrain
Old 02-10-2013, 09:31 AM   #1
rob2012subiewrx
Member#: 343582
2012 wrx
black
Default crazy knock sensor readings
just put catless dp and a q300 catback on flashed it to stage 2 lwg for hfc since they dont have one for catless and cylinder 2 and 4 are reading like 25 knocks and 1 and 3 are both 7 the car is a 2012 wrx with only 5k on it
rob2012subiewrx is offline   Reply With Quote
Old 02-10-2013, 10:14 AM   #2
bluemax189
Member#: 137405
are you hearing any knocking or rattling at all? could be something is hitting somewhere or something isnt bolted up all the way. might want to post a log in the engine management and tuning section too.
bluemax189 is offline   Reply With Quote
Old 02-10-2013, 10:27 AM   #3
Tripintaz
Member#: 245218
2013 STI Limited
Ice Silver
If you are looking at the knock counter per cylinder on the AP then stop then you are just worrying yourself for nothing. Fine Knock Learn and Feedback Knock are where you should be concerned.
Old 02-10-2013, 10:28 AM   #4
rob2012subiewrx
Member#: 343582
2012 wrx
black
no knocking only rattling i hear is the exhaust hitting my heat shield from time to time i wanna do a log but i my stock bcs isnt working so it will spike to high im mostly staying out of boost too
Old 02-10-2013, 10:28 AM   #5
rob2012subiewrx
Member#: 343582
2012 wrx
black
okay those are 0 so i guess its good thanks
Message Board Statistics All times are GMT -4. The time now is 10:19 PM.
