Old 02-01-2013, 02:07 PM   #1
jazzy_JAE
Member#: 283942
2008 Impreza WRX STI
Default Help!! Gauge lights aren't working
I was replacing the LEDs in my gauges, (fuel, temp, speedo, and tach) and when I was putting in the last bulb I heard a small tick, and then all the lights went out.
The open door light, cel, brake, and all the other lights work, but for some reason the fuel, temp, speedo, and tach don't light up.
I checked the fuses, and they're all good. Does anybody know what could have happened?
Thanks for the help
jazzy_JAE is offline   Reply With Quote
Old 02-01-2013, 09:54 PM   #2
jazzy_JAE
Member#: 283942
Bump. Wanna try to exhaust all my options before I turn to buying a new cluster
Old 02-06-2013, 02:48 PM   #3
WhiteCastleSwag
Member#: 331383
2002 Impreza OBS
Im having the same issue but mine happened while trying the fog light mod. My illumination just doesnt work but everything else is fine. I checked fuses and that wasn't it. PITA at night.
WhiteCastleSwag is offline   Reply With Quote
Old 02-06-2013, 05:10 PM   #4
jules97
Member#: 342996
1997 Impreza Outack
Dark Blue/Silver
Default me too!
I'm having the same problem except for me I wasn't even doing any mods. One day I just got in my car and NONE of my gauge or dash lights are working! At night, I hope I'm going the speed limit. I checked all fuses and they are fine. What do I do next?
jules97 is offline   Reply With Quote
Old 02-06-2013, 10:25 PM   #5
bobob729
Member#: 279362
2002 Subi WRX
Siver
why dont you guys check to seee if you have power from the light switch itself when you turn it on
bobob729 is offline   Reply With Quote
Old 02-09-2013, 02:44 PM   #6
jazzy_JAE
Member#: 283942
Power to the knob that turns the lights on correct? Or something else
Old 02-09-2013, 06:39 PM   #7
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
I think there is a fuse inside the cluster for the illumination circuit and you may have blown that fuse out. If the illumination for the other lights like for the HVAC area, radio, and clock still can be adjusted then the illumination control module is ok and I would suspect the fuse in the cluster is the problem.
Cougar4 is offline   Reply With Quote
Old 02-10-2013, 01:52 PM   #8
jazzy_JAE
Member#: 283942
That's what I've heard, but I can't seem to get the cluster apart enough to check if its replaceable. I found a cluster on eBay for $79, so I'm going to replace mine, and have Subaru adjust it
Old 02-19-2013, 02:17 PM   #9
Preludicrous
Member#: 334356
2006 2.5i Wagon
SRR
Question... Why are you guys doing electrical/wiring mods with your battery connected? I understand the ignition switch controls a majority of the current flow in the vehicle, but still...
Preludicrous is offline   Reply With Quote
Old 02-20-2013, 09:24 PM   #10
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
[scotty]DING DING DING[/scotty]
Old 02-27-2013, 01:21 PM   #11
Insteezy
Member#: 345057
my cluster lights are super faded and only work in some spots. Do i just need new lights or something?
Insteezy is offline   Reply With Quote
Old 02-27-2013, 03:28 PM   #12
Cougar4
Member#: 53443
Winestone
I would tend to say the light adjustment control has some dirty/bad spots on it.
