Old 02-08-2013, 12:49 PM   #1
WpgUberu
Member#: 163619
Default About pulling a trailer
Hey guys, last summer I bought a new quad and an aluminium triton trailer. I don't have the dimensions on me but it's a tad bit wider than my 2003 wrx about 8 or feet long. Anyways, if I load just one quad or 2 sidebyside and balance it right so it's not putting a lot of pressure on the rear struts and not too far back to pull up, I seem to only get up to about 80 km/h comfortably. If I go the speed limit 100 on the highway it's fine but I have a bit of constant boost. I know with diesel trucks like my buddys with no load he has constant boost, I just want to make sure this is ok or will that blow the motor and or turbo? If not then I won't worry about it but any advise would be great, thanks.
PS there is no wobble or pulling.
WpgUberu is offline   Reply With Quote
Old 02-08-2013, 01:09 PM   #2
Heedlessone
Member#: 254130
1993 LS1 RX7
It won't blow the turbo or the motor.
Heedlessone is offline   Reply With Quote
Old 02-08-2013, 01:14 PM   #3
WpgUberu
Member#: 163619
Ok, from what I remember it was between 5 or so psi. It sure uses a hell of a lot more gas lol.
Old 02-08-2013, 01:16 PM   #4
Jack
Add Lightness
Member#: 13699
2007 Lotus Elise
(From General)
Bad choice for towing. The wheelbase is very short, which ain't good. Take it from me....I pulled my 1600 pound racecar on a 900pound open aluminum trailer with a Wrangler and it sucked. I went to a Yukon XL. Also, with the enclosed trailer, you are pulling a ton of air drag. You will wear your car out doing this.
Old 02-08-2013, 01:18 PM   #5
68Cadillac
Member#: 95901
Hauled over 2000 miles cumulative.
Popup is a Viking 1906 Epic model. 1503 lb tow weight empty. On the heaviest haul we probably packed ~500 lb of food, clothing, wood, beding, chairs, and supplies in the trailer and a family of four plus dog in the car.
You can start to haul just about any weight trailer with any car. The real question is: can you stop it? I run 2005 Legacy GT calipers and rotors and the H6 rear brake upgrade.
You have to mind the tongue weight. Too much and you can't steer or brake safely. For me that means packing the dense heavy stuff in the back of the trailer. I even disconnect the 45lb RV battery and pack it the back of the trailer to help.
68Cadillac is offline   Reply With Quote
Old 02-08-2013, 01:19 PM   #6
WpgUberu
Member#: 163619
Ummm this isn't enclosed, it's open no sides, the wheel base is the same width as the car.
Old 02-08-2013, 01:21 PM   #7
WpgUberu
Member#: 163619
Old 02-08-2013, 01:44 PM   #8
WpgUberu
Member#: 163619
As long as you guys say I won't blow the motor i'll just monitor everything and fluids and go with that then
Old 02-08-2013, 01:54 PM   #9
WpgUberu
Member#: 163619
Ok, found the dimensions, width is 6.6feet and 12.5 feet long, 8" tires.
Old 02-08-2013, 03:41 PM   #10
Napalm3nema
Member#: 263954
2014 EVO X / 05 WRX
Wicked White / Blue
Just stack an equal weight of the quad's and trailer on the front of the car / top of the car using lead bricks or bundles of rebar.
Balance FTW!
Napalm3nema is offline   Reply With Quote
Old 02-08-2013, 03:49 PM   #11
Scanyland
Member#: 282593
1996 Subaru Legacy
The way those quads are loaded I feel like that is still alot of drag.
Scanyland is offline   Reply With Quote
Old 02-08-2013, 05:30 PM   #12
nhmtns
Member#: 94283
'05 OBXT
Min bil är svart
There's your problem. That's wicked fast.
nhmtns is offline   Reply With Quote
Old 02-08-2013, 05:48 PM   #13
Web Foot STi
Member#: 39086
2004 STi
Do you have trailer brakes?
You want ~10% of the trailer weight to be on the hitch. With brakes you have a 2,000# GVW allowance. You do not want the tail wagging the dog. It's no fun at all.
Web Foot STi is offline   Reply With Quote
Old 02-08-2013, 05:54 PM   #14
Web Foot STi
Member#: 39086
2004 STi
He is talking klicks per hour. I'm assuming he is from the great white north. 62mph isn't that fast.
Old 02-08-2013, 08:17 PM   #15
some dude
Member#: 100300
06 WRX
CGM
So constant boost for extended periods of time. Is the heat dissipation good enough to keep temps constant and within operating range? I would imagine the turbo will heat up after 30 min of constant boost. Def burn off any moisture in the oil system.
some dude is offline   Reply With Quote
Old 02-11-2013, 08:40 AM   #16
WpgUberu
Member#: 163619
I guess I could hook up my tatrix cable and monitor levels that way to right? As long as it's all good then I won't worry.
