Old 02-10-2013, 11:18 PM   #1
boeingdrew
Member#: 122063
08 STi
Default Downpipe Removal w/ EWG
I'm trying to swap my stock downpipe on for smog purposes. Right now I have a catless DP & Dom 2.5 w/ EWG (amongst others). Now I was able to get the TMIC off + all turbo/dp bolts off UNTIL I got to the one on the very bottom.
Once I looked underneath there is literally zero room to torque a wrench, much less a ratchet down there. Even with PB blaster there is no way in hell I could get any sort of leverage on it.
Does anyone have a recommendation on how to approach that last freaking bolt? Is there a way I can get to it without removing the EWG? It's driving me nuts!
boeingdrew is offline   Reply With Quote
Old 02-11-2013, 12:07 AM   #2
WhatTurboLag?
Member#: 243992
2006 WRX TR
Take off ewg. I gotta every time the dp comes off
Old 02-11-2013, 12:13 AM   #3
boeingdrew
Member#: 122063
08 STi
Cool, thanks for the reply man! Not quite the best news, but I guess that confirms it for me.
Do you know of any kind of writeup for removing the ewg? Want to make sure I'm not creating more work for myself....
Old 02-11-2013, 12:28 AM   #4
WhatTurboLag?
Member#: 243992
2006 WRX TR
Isit a 2 bolt or vband? Tou just need to remove the wastegate itself not the whole up pipe.
Old 02-11-2013, 12:42 AM   #5
boeingdrew
Member#: 122063
08 STi
I'm pretty sure it was a 2 bolt. So just release those two bolts, take of the wastegate and I should have enough room to operate for the rest of the DP install?
Old 02-11-2013, 01:17 AM   #6
I--RIDE--BIKES
Member#: 279176
2006 Sti
SGM
You are correct.
I--RIDE--BIKES is offline   Reply With Quote
Old 02-11-2013, 09:46 AM   #7
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I have taken off my downpipe dozens, and dozens of times with the EWG still installed. Just use a closed end wrench from up in the engine bay (reach down around the turbo). There shouldn't be any issue getting the DP out with the EWG still in place.
