Old 02-11-2013, 04:00 AM   #1
furiouswrx
Member#: 283048
2011 WRX Ltd Hatch
Post PSA: Subaru blue OEM oil filters recalled due to leaking gaskets
I haven't seen this anywhere on the Service and Maintenance forum..which is alarming to me.
Subaru is recalling some of their blue OEM 15208AA12A engine oil filters due to possibility of leaking at the O-ring gasket. Please see the PDFs below for the official information.
If you purchased any blue OEM oil filters between July 1, 2012 and December 15, 2012, check their date codes. Heck, check all of them anyway just to be safe.
The date code format is FYJJJS where:
F is the facility (S = Canada, A = USA)
Y is the last digit of the year (1 = 2011, 2 = 2012, 3 = 2013)
JJJ is the Julian date code (Google it if you are curious)
S is the factory shift number (1 = 1st shift, 2 = 2nd shift, 3 = 3rd shift)
Filters NOT part of the recall, which are OK:
-If the date code begins with S1 or S2
-If the date code begins with A2291x or higher (where x is 1, 2, or 3)
-If the date code begins with A2290x or earlier AND is adjacently marked with a dash + a number or initials indicating that it passed secondary inspection. You can see an example of this in the Subaru PDF.
-(Case Quantities) If the case packaging has a date code of 777
Filters recalled, which may leak:
-If the date code begins with A2290x or earlier (where x is 1, 2, or 3) AND has no other adjacent markings or a single white dot adjacent to the date code.
Example of recalled filter, which I purchased in October 2012.
Specifics about how you will exchange both installed and unopened oil filters can be found in the Dealer Letter below.
PDF: Fram's Recall Notice (Official Site | Mirror)
PDF: Subaru's SNET Dealer Letter (Official Site | Mirror)
I happened to purchase 6 of the affected filters. 1 is installed on my car right now.
furiouswrx is offline   Reply With Quote
Old 02-11-2013, 04:24 AM   #2
Yeeman19
Member#: 8
Chapter/Region: HIIC
Ice Silver Metallic
Thanks for the warning. Just checked my stock of filters and they're ok.
Yeeman19 is offline   Reply With Quote
Old 02-11-2013, 04:44 AM   #3
Schikane
Member#: 337700
2013 WRX
Ice Silver Metallic
Thanks. I guess I have 11 filters to check when I get home.
Schikane is offline   Reply With Quote
Old 02-11-2013, 04:49 AM   #4
i guess ill just buy the wix 57712 and forgetabout the garbage blue filters
Old 02-11-2013, 10:42 AM   #5
HeroCrank
Member#: 301089
2013 Toyota Tundra
Rock Warrior
Good info thank you.
Old 02-11-2013, 11:03 AM   #6
bottles
Member#: 311522
Icy Silver Metallic
Im still using my free oil changes, would my dealer notify of this? They have been the only people changing my oil since I have had my WRX Feb 2012.
bottles is offline   Reply With Quote
Old 02-11-2013, 12:07 PM   #7
furiouswrx
Member#: 283048
2011 WRX Ltd Hatch
The Subaru letter says that this recall does not apply to filters installed at the dealership. It only applies to filters purchased at the dealer parts counter or through an online wholesaler.
I don't understand how that works though, because I see service and parts staff at two of my local dealerships getting filters from the same cases.
Old 02-11-2013, 12:16 PM   #8
07VTRex
Member#: 179023
07 CGM WRX TR
Dom 1.5xtr + PPG's
i guess what they are trying to say is all filters at dealership have already and will be checked prior to any service work. They already are aware and have removed them from their stock. You need to be worried if you ordered these from a vendor/dealer before the recall was made aware. thats jsut how i interepretted it
07VTRex is offline   Reply With Quote
Old 02-11-2013, 12:20 PM   #9
pezcore
Member#: 178045
06 WRX
Gotta watch out for those 3rd shift workers, lol
pezcore is offline   Reply With Quote
Old 02-11-2013, 12:22 PM   #10
Schikane
Member#: 337700
2013 WRX
Ice Silver Metallic
Hey! I'm one of those third shift workers.
Old 02-11-2013, 12:28 PM   #11
ixwrxxi
Member#: 334215
2015 Forester
Thanks for the info
ixwrxxi is online now   Reply With Quote
Old 02-11-2013, 12:35 PM   #12
bottles
Member#: 311522
Icy Silver Metallic
Defiantly Good to know, Thanks!!!
Old 02-11-2013, 02:08 PM   #13
subiedude676
Member#: 241369
2012 2.0i Premium
Ice Silver Metallic
Glad i have a stockpile of the black filters!
subiedude676 is offline   Reply With Quote
Old 02-11-2013, 04:29 PM   #14
Jayp5150
Member#: 308768
2012 WRX Hatch PBP
2012 Ralliart
I noticed a drop of oil on the bottom of my filter at last change (about 3 weeks ago). No collection on the splash guard, though. Makes sense now. I just figured I didn't tighten it properly.
I guess I have to crawl under there and look. Yay...
Thanks for the info.
Jayp5150 is offline   Reply With Quote
Old 02-12-2013, 01:25 AM   #15
esteve
Member#: 28716
2006 STI
OP, thanks for the heads up. How many miles do you have on the filter now? That's some scary chit that the affected filters will fail within 300 miles (at the latest)!!
I just checked my stock, all are S2 (made in Canada) so I lucked out. I've got over 3K miles on the installed filter so I figured it was ok. I already had a close call with a cracked pickup and don't want anymore oil surprises.
This reminds me of the guy on the forums recently who had the dealer do an oil change on his new WRX and soon afterwards he had a big oil leak from the filter causing engine damage. The dealer told him there was an issue with the filter and we were all BS, the tech must've double-gasketed the filter or something. Well, I guess the dealer wasn't BSing after all.
esteve is online now   Reply With Quote
Old 02-12-2013, 04:18 AM   #16
garzdos
Member#: 333423
2012 WRX Hatch
Dark Gray Metallic
OMGHi2U
Great heads up!
Getting under my car tomorrow to check on this...I bought my last filter 3 days too early (December 12)! My local dealer said they did have to pull a few filters but didn't have too many of the bad ones...hope I bought a good one! I'm over 300 miles by far and haven't lost any oil so I figure I'm good...
garzdos is offline   Reply With Quote
Old 02-12-2013, 04:49 AM   #17
Double_Rs
Member#: 345305
2007 STI
Great heads up. I will be ordering a 6 pack soon. I know its well after the recall date, and I'm probably good, but you can never be too careful.
Double_Rs is offline   Reply With Quote
Old 02-12-2013, 12:21 PM   #18
crabsandwich
Member#: 337442
2013 WRX Limited 5DR
Guess I'll be jacking the car up tonight. At least if I have to pull the bad filter off the car they will reimburse me for a quart of oil I've had mine on for approx 400 miles
crabsandwich is offline   Reply With Quote
Old 02-12-2013, 12:51 PM   #19
SubLGT
Member#: 207528
2005 Legacy GT
Deja vu from 2005! Then it was a gasket problem on the white oil filter
http://forums.nasioc.com/forums/showthread.php?t=864075
SubLGT is offline   Reply With Quote
Old 02-12-2013, 01:23 PM   #20
meebs
Member#: 3251
2009 WRX Hatch
i guess ill just buy the wix 55712 and forgetabout the garbage blue filters
57712?
meebs is offline   Reply With Quote
Old 02-12-2013, 06:50 PM   #21
C4RBON_F1BER
Member#: 208507
'15 BRZ
I just bought three filters today, all made after the recall. But they were all made on 3rd shift.
What happens on third shift, stays on third shift.
C4RBON_F1BER is offline   Reply With Quote
Old 02-13-2013, 06:47 PM   #22
furiouswrx
Member#: 283048
2011 WRX Ltd Hatch
I had about 200 miles on the oil when I changed the oil filter last night (reusing the same oil). I checked the oil level before every trip just to be safe.
There was oil visibly pooling on the underbody cover and an oil droplet collecting on the bottom of the filter. Also oil dripping down nearby surfaces. Maybe about 1/16 quart in total.
Also to clarify, the 1-qt dealership oil reimbursement is liquid reimbursement, not monetary reimbursement, and you must provide a copy of an oil receipt for them. They gave me 1 quart of SM GF-4 Subaru Synthetic 5W-30.
Additionally, you must take off any installed recalled filter before they exchange it as a defective product through the service department - necessitating two trips to the dealer, unless you have a non-recall or different brand filter handy to swap it out with. YMMV at your dealer - maybe they can figure out how to do a refund on oil you did not purchase from them.
Old 02-13-2013, 10:56 PM   #23
esteve
Member#: 28716
2006 STI
Wow, furiouswrx it looks like you changed the filter just in the nick of time.
Old 02-14-2013, 12:09 AM   #24
lionken07
Member#: 13660
16 BRZ Limited 6MT
04 WRX 5MT
so if I'm looking at this right A30121 which was made in 2013 is good? If only we can still pick up the black ones at the dealership...
lionken07 is offline   Reply With Quote
Old 02-14-2013, 12:16 AM   #25
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
Thanks for the heads up.
Bishop is offline   Reply With Quote
