Old 09-14-2012, 08:16 PM   #1
neb_subi
Member#: 329049
04 sti
PSM (unfortunately)
Default TGV delete aftermath??
I deleted my tgv's today, bought them off of another member and installed them. Now it runs kinda choppy like a misfire but the codes haven't popped up for it yet.
neb_subi is offline   Reply With Quote
Old 09-14-2012, 08:20 PM   #2
quazimoto
Member#: 70395
Ok............cool story....
Old 09-14-2012, 09:12 PM   #3
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
Probably have a vacuum leak
Old 09-14-2012, 09:31 PM   #4
StealthTL
Member#: 206912
2006 Forester XT
New gaskets all round, or just re-used the old?
StealthTL is offline   Reply With Quote
Old 09-14-2012, 09:31 PM   #5
bluepearlrex12
Member#: 310184
2012 WRX
Blue Pearl
Need a tune
bluepearlrex12 is offline   Reply With Quote
Old 09-14-2012, 09:35 PM   #6
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
probaly all the above, go to revolutions and have Adam hook you up.
scby rex is offline   Reply With Quote
Old 09-14-2012, 09:48 PM   #7
neb_subi
Member#: 329049
04 sti
PSM (unfortunately)
Ya I've used new gaskets. I'm thinking its needing a tune?
Old 09-14-2012, 09:49 PM   #8
neb_subi
Member#: 329049
04 sti
PSM (unfortunately)
But Idk it shouldn't be running rough should it?
Old 09-14-2012, 10:23 PM   #9
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
You have a vacuum leak. You missed one of the 900 vacuum fitting connections...it happens. Check every fitting. Same thing happened to me as I missed the one that goes under the throttle body.
Old 09-14-2012, 11:07 PM   #10
mikeydrives1
Member#: 262117
2001 Forester
STi II type M
Tune. period.
mikeydrives1 is offline   Reply With Quote
Old 09-15-2012, 03:34 AM   #11
CobbsSTI
Member#: 245242
2005 STI
E85 Power
Vacuum leak. Get a tune as well.
CobbsSTI is offline   Reply With Quote
Old 09-15-2012, 09:44 AM   #12
neb_subi
Member#: 329049
04 sti
PSM (unfortunately)
Yes plan to get e85 tune as soon as I get injectors.
But the vacuum leak could be a possability as I did have to pull up on the maifold as i put the tgv in
Old 09-15-2012, 10:48 AM   #13
Member#: 51961
2005 STi
2012 WRX
Originally Posted by bluepearlrex12 View Post
Need a tune
Originally Posted by mikeydrives1 View Post
Tune. period.
You don't need a tune for TGV deletes (other than to turn off the codes, and to make sure the extra flow hasn't push you into untuned regions of your map at WOT). Do people forget we run a MAF-based fueling system?
Old 09-15-2012, 11:19 AM   #14
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
People read too far into the "everything you do needs a tune" part of NASIOC.
Old 09-15-2012, 12:41 PM   #15
neb_subi
Member#: 329049
04 sti
PSM (unfortunately)
I figured out the problem that one of the injectors wires came out of the plug.
Old 09-15-2012, 09:48 PM   #16
synolimit
Member#: 225225
11 WRX
335HP, 394TQ, 93 VF52!!
Did that too first time I did air pump or something. Never touched them but somehow plug on 4 got loose. Drove 2 hours to the tuner and just thought the roughness was normal with the check engine etc. sounded like a 3 cylinder but never dawned on me till tuner checked the spark timing and saw 4 was off. Wasted over half a tank of gas too in that short drive. Live and learn.
synolimit is offline   Reply With Quote
Old 09-15-2012, 11:46 PM   #17
JhnBrackett
Member#: 42460
Thank you for updating what the solution was. Vacuum leak was a great diagnosis though. Get a tune was on the verge of retardation. Only thing you should notice from this swap is a slightly rougher idle at cold startup.
JhnBrackett is offline   Reply With Quote
Old 09-16-2012, 04:36 PM   #18
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Glad to hear you got it figured out.
I'd be surprised if you noticed a rougher idle, even in cold starts.
It's a reasonable theory based on what the TGVs (better atomization) and when (my LGT only has them active at startup (some later models use them more)) but I have yet to hear of a first-hand report from someone who did cold starts with them, did a swap, and did cold starts without them.
One of the guys at LegacyGT.com, who lives in Canada and uses a block heater in the winter, said his car still started and idled just fine with the TGVs removed, even in the winter.
There was a time (and maybe it's still true) that TGVs were a USDM-only thing (or at least, they weren't used in JDM cars). So I'm pretty sure they're strictly for post-startup emissions.
And you don't need a tune for them.
And people create vacuum leaks while doing the delete all the time, so that was my guess too.
Old 09-16-2012, 04:38 PM   #19
NSFW
Member#: 140444
05 Stage Free LGT
Yeah, since those rubber seals wear out all the time...
Old 09-16-2012, 04:43 PM   #20
Member#: 51961
2005 STi
2012 WRX
Rubber? OP has an 04 STi, there are no rubber seals in the TGV/manifold area.
Old 09-16-2012, 06:25 PM   #21
WhatTurboLag?
Member#: 243992
2006 WRX TR
this, and its ****ing annoying.
what MAF?
(im sd )
WhatTurboLag? is online now   Reply With Quote
Old 02-11-2013, 12:26 PM   #22
Booggieman62
Member#: 169266
06 WRX TR
Subi Blue
Im getting ready to do the tgv delete i was going to do all the porting myself. Is there anything i need to know i watched a couple videos on YouTube looks pretty easy. But that's YouTube.
Booggieman62 is offline   Reply With Quote
Old 02-11-2013, 03:12 PM   #23
neb_subi
Member#: 329049
04 sti
PSM (unfortunately)
You dont need to take the whole manifold out. Just unbolt from tgv and pull old ones put and rebolt the fuel rails to it
