Old 02-11-2013, 05:47 PM   #126
mhoerath
Member#: 131379
2003 354 [email protected] rpm
justablue hatch
somewhere nasioc there's a spec the hub is bad or good depending on inside diameter. sorry cannot remember where. might even be this thread.
mhoerath is offline   Reply With Quote
Old 03-19-2013, 05:44 PM   #127
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Originally Posted by txl146 View Post
Thanks - pin that came with replacement axle (EMPI) has no tapered end. Both ends look identical.
I don't know if you figured this out or not, it's a little late now, but the holes for the roll pins on these axles are drilled OFF CENTER... If you can not get the pin past the 1/4" point, you have to pull the axle off the stub and rotate it 180* and put it back... then it slides right through like it should...
I thought I might add this for any future reference..(I don't know why I'm posting this in a rear wheel bearing replacement thread, but there it is)
Old 05-11-2013, 04:07 PM   #128
CNY_Dave
Member#: 354655
I have a bit of advice, it might just be my wariness about applying force through the balls for install-
There is an adapter in the HF kit that will push on the outer race but will not push on the inner race. I use this to get the bearing in to the point where the adapter bottoms on the outer part of the housing, then I remove the tool and use the old outer race cleaned up with the bearings removed to push it the rest of the way. The housing is larger than the race until after the snap ring groove, so it does not get stuck.
I think some of the early second failures are from putting the install force through the balls and inner race.
A trick for a stuck race on the hub is to take a stick or mig welder and run a bead on the race, it'll pop right off.
Standard install info on any snap ring (it might have been said already) is to put the sharper edge against the part of the groove it holds force against, in this case towards the outside.
CNY_Dave is offline   Reply With Quote
Old 06-10-2013, 10:01 AM   #129
cdmurp02
Member#: 354226
2004 Impreza Outback
Blue/Gray
I found the Subaru publication that is referenced by motohippy and downloaded it from here:
http://www.ludicrous-speed.com/autom...za/fsm/Others/
(just right click the "Wheel Bearing Installation Guide.pdf" and hit save link as)
There's also this Endwrench PDF I found that seems to be the same (but with color pictures):
http://file.seekpart.com/keywordpdf/...6104638203.pdf
In the publication it says you're supposed to check the bearing housing for out-of-roundness. The guides don't say anything about checking the hub (except maybe checking the splines inside for pitting and debris). You're supposed to use a bore-hole gage and check the inside diameter of the bearing housing two times--once in the vertical, and once in the horizontal. If the bore hole measurements are different from each other by more than 0.02 mm you're supposed to replace the housing.
I didn't bother when I did this since I don't have a bore hole gage and my calipers don't do hundredths of millimeters.
cdmurp02 is offline   Reply With Quote
Old 06-12-2013, 09:14 AM   #130
cdmurp02
Member#: 354226
Blue/Gray
The MSA that motohippy references has a specification to check the bearing housing. It does not give any specs on how to check hub though. Is that what you're talking about?
I did this too! No mention of this at all in the walk-through, and I was scratching my head trying to figure out how to get the bearing in the rest of the way without pushing on the inner races.
Another tip for anyone wanting to do this: I was not able to rent a bearing splitter from any auto parts store like autozone/advance/o'reilly etc., but they had everything else: slide hammer, 2/3 jaw puller, hub flange for slide hammer, and seal driver. I was able to get the old bearing race off of the hub with just the 2/3 jaw puller and a little bit of ingenuity. The bearing splitter would have made the job a lot easier though.
In case there are folks out there wondering if they can do this repair, like myself before I attempted this: I have almost no experience working on cars and this repair was very doable. I know how to use tools, but I've never so much as done a brake job. This took me about 5 hours from start to finish. So, for those that might be a little on the edge just make sure you take your time, get the subaru MSA along with this walk-through and you'll be fine. It really beats taking your vehicle to the dealer/shop and shelling out $400-500 and not having a car for a week.
Old 06-12-2013, 10:25 PM   #131
Rick in Pa
Member#: 359312
Default How far to press in hub?
There is an adapter in the HF kit that will push on the outer race but will not push on the inner race....
Thanks for this, great suggestion. Tried it today and it worked like a charm. 1 wheel down & 1 to go.
I'm wondering about the part of the writeup that says to install the hub just past the inner edge of the race. Elsewhere on the web I see advice to drive it flush with the end of the bearing. Any opinion on what's the best way to go there?
Rick in Pa is offline   Reply With Quote
Old 06-13-2013, 06:41 AM   #132
mhoerath
Member#: 131379
justablue hatch
yes, the post described an out of round spec for the housing.
A good practice is to note position before taking apart, and re install same way. The hub spindle is flush with the end of the bearing.
Old 09-23-2013, 03:57 PM   #133
ADaughen
Member#: 333348
2000 Forester S
STM
Any idea how to get the bolts out of that ABS Ring? Dealership wants $120/front and $90/rear and my fronts are seized up solid. Two of the bolts were stripped, probably from the prior owner who had the bearings done.
ADaughen is offline   Reply With Quote
Old 09-23-2013, 04:46 PM   #134
motohippy
Member#: 225882
2000 OBS
'88 BMW K75S
I've generally had decent luck using bolt extractors on stripped out allen heads. (disclaimer: never on the tone rings, mine came right out) One thing to be careful with if you try the extractors---if they break off in the bolt head, you're pretty much screwed as they're harder than any drill bit I've ever used. You also might be able to drill the heads off the screws to get the tone ring off of the hub.
motohippy is offline   Reply With Quote
Old 09-24-2013, 10:48 AM   #135
ADaughen
Member#: 333348
2000 Forester S
STM
Update: After soaking them in penetrant overnight, I was able to get them off with an extractor set. Thanks, saved me $120+. I used the 2nd biggest easy out, a 10mm socket with a rachet, and a pry bar and busted 4 of the 5 loose. #5 wasn't biting so I ended up drilling through the bolt head and used pliers to remove the threaded portion from the ring.
I have 170k miles on my Forester. It appears the inner seal failed. Also looks like prior "mechanic" used a punch to push the old race out vs a press or the HF bearing press kit when they replaced the bearing prior. I can only imagine what he used to press the new one in...
Old 01-22-2014, 06:03 PM   #136
Hah72215
Member#: 77815
2002 WRX WAGON
Just finished the front wheel bearings using the Harbor Freight kit and everything worked great! Good write up.
Hardest part was pulling the hub using the slide hammer on one of my wheels that just wouldn't let go. Finally sprayed some PB blaster on the front and back side of the bearing and it broke loose.
Autozone is getting back a pretty wasted slide hammer though. My forearms are toast.
Hah72215 is offline   Reply With Quote
Old 01-23-2014, 12:32 AM   #137
Jaime2
Member#: 379537
2005 WRX
Default Improvising
Just took my rear bearings off today... I didn't have the quite the right tools, so here's what I had to do:
I didn't have a slug small enough to allow the bearing to pull up far enough past the lip of the hub, so I had to push it the last half inch with this jury-rigged setup. BTW, they couldn't have made the lip of the inner race any smaller - it's really hard to get a three-jaw puller to grip them.
Jaime2 is offline   Reply With Quote
Old 03-18-2014, 05:24 PM   #138
RS19
Member#: 344525
2001 Impreza RS
Erotic Blue
Would this work for a 03 WRX Wagon
RS19 is offline   Reply With Quote
Old 03-18-2014, 07:02 PM   #139
mhoerath
Member#: 131379
justablue hatch
yes it will.
Old 03-19-2014, 11:29 AM   #140
CNY_Dave
Member#: 354655
The cheap harbor freight bearing splitter works too.
Old 07-08-2014, 08:56 AM   #141
no694terry
Member#: 220816
98 Forester S/t
heart breaker
I used this thread to help me change mine last night. I went through 2 salvage yard hubs in the last year so this time i decided to just buy the new tapered bearing style bearing and do it myself and not need to do it again.
I borrowed a bearing splitter and a two arm puller, and the guy I borrowed tools from gave me a tip to remove the outer race from inside the knuckle. He told me to weld around the inside of the race, let it cool and it will slide right out. Well almost, i welded the inside of the race and i was able to push it out with a screw driver. Then i just used a peice of thread rod, some washers and the old race to push the new bearing into the hub. Took 3 hours start to finish including a trip to the store for the 3 seals.
no694terry is offline   Reply With Quote
Old 07-08-2014, 09:28 PM   #142
mhoerath
Member#: 131379
justablue hatch
My bearings have always been tapered roller bearings...pls tell me what the new style is? BTW used to live in Upper St Clair, PA.
Old 07-26-2014, 05:04 PM   #143
motohippy
Member#: 225882
2000 OBS
'88 BMW K75S
I think he's referring to the old-old style bearings that were used before the current tapered bearings were introduced...not sure when the change happened
Old 08-31-2014, 11:53 AM   #144
Snowphun
Member#: 1800
WRX /WRX/Cooper S
awd/awd/fwd
Can anyone comment on how to change out the grease in new bearings before install? Seems like I need to push out the plastic retainer to get to the bearings. Once cleaned and repacked do I reassemble with the plastic sleeve?
Thanks.
Snowphun is offline   Reply With Quote
Old 08-31-2014, 12:37 PM   #145
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Thanks.
Yes, replace the retainer. It's only purpose is to keep the bearing together for installation. It slides out of place by the hub, when it is pressed in.
Remember to make sure all the original grease is gone prior to using another type.
Sent from my iPhone using NASIOC
Bikelok is online now   Reply With Quote
Old 12-05-2014, 11:43 PM   #146
bekks
Member#: 407944
1998 Forester
Got everything out and everything is back into the knuckle, but off the car. My question is also about the #2 seal (inside of inner side). Someone else asked about it around the middle of this thread. I cannot get it to sit flush against the inner bearing race, so it is essentially doing nothing. I'm wondering about the necessity of it though. The outside inner seal should keep anything out. Anyone recall if they were able to have it sit flush against the bearing? I'm pretty sure it was crooked before I pulled the original one out, but that may have happened through the process of removing the hub.
Great thread.
bekks is offline   Reply With Quote
Old 08-17-2015, 08:46 PM   #147
ebeard
Member#: 428310
Using this walkthrough. Working on a 2002 obs, have the HF front wheel drive puller set up but i can't get the race to budge. Have used well over two feet of breaker bar with no luck. Anyone else run into this problem?
Edit: have tried some heat as well
ebeard is offline   Reply With Quote
Old 08-17-2015, 11:44 PM   #148
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Make sure the tool is resting on the race and not the race stop (a small lip that's actually part of the knuckle). It can be hard to see if it's all a bit greasy.
Old 11-24-2015, 01:02 PM   #149
boomerz
Member#: 427960
2002 Impreza TS
white
JUst did this other day wasnt bad .... a few trips to hf and parts store to rent the slide hammer due to mine broke. No more annoying humm while cruzin
boomerz is offline   Reply With Quote
Old 03-04-2016, 08:05 PM   #150
SwagonGF4
Member#: 441515
Second subie, probably my 12th car. Anyway, I am curious on input on whether I should either replace the bearing using the existing hub on the car or get the entire assembly from a salvage yard. My reasoning for this is 1) cost efficiency 2) simplicity of repair. Of course, I wont have a new bearing but I think this is a good approach considering I plan on doing a disc brake swap within the next year. Thoughts?
SwagonGF4 is offline   Reply With Quote
comments on DIY rear wheel bearing replacement Carbon888 Tire & Wheel 4 12-19-2006 12:58 AM
Anyone know a good place to get a rear wheel bearing replaced for a good price evoq007 New England Impreza Club Forum -- NESIC 13 06-30-2006 07:22 AM
rear wheel bearing replacement nosajh9 Brakes, Steering & Suspension 0 01-03-2006 02:34 PM
rear wheel bearing replacement cptomes Service & Maintenance 8 01-04-2005 10:33 AM
Rear Wheel Bearing Replacement? Bob O Mid Atlantic Impreza Club -- MAIC 8 06-06-2002 09:43 AM
