Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 02-10-2013, 12:09 AM   #1
gamma1232
Member#: 249493
2005 STi
Default Engine temp gauge spiked on H in cold weater
I have a 2005 STI that spiked its engine temperature gauge today. Its ~20 degrees out and I was on the highway cruising with traffic when I noticed. I turned to heat on full blast to try and help alleviate some of the heat, but it was blowing cold air. When I plugged my scanner in, the live data for the engine temp said the coolant was 250 degF, but that didn't seem right based on the heat barely working. So I decided to pop the radiator cap off and there was no pressure in the system....If my coolant was actually at 250 wouldn't I have some pressure in the cooling system?
Both my cooling fans are cycling on....does this sound like a bad thermostat or just a bad coolant temp sensor? Im pretty sure my water pump is good, only has 15k miles on (recently replaced).
gamma1232 is offline   Reply With Quote
Old 02-10-2013, 12:11 AM   #2
h00z0r
Member#: 212540
Did you check your coolant level? Also, it's possible the heater core hose blew out, thus no heat
h00z0r is offline   Reply With Quote
Old 02-10-2013, 12:12 AM   #3
gamma1232
Member#: 249493
2005 STi
coolant level is good, the reservoir is full
Old 02-10-2013, 12:12 AM   #4
gamma1232
Member#: 249493
2005 STi
also with the heat, it got better once I was back in the city and not driving at highway speeds. but when I was driving above 25 MPH the heat would die again
Old 02-10-2013, 01:08 AM   #5
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
Bubble in the cooling system or a bad thermostat.
Old 02-10-2013, 10:56 AM   #6
Cathexis
Member#: 335445
2012 WRX - BLK STIG
Stg. 2 - 287whp/317wtq.
In a 2005 car, shouldn't the thermostat fail in the open posistion?
Cathexis is offline   Reply With Quote
Old 02-10-2013, 11:16 AM   #7
The Salami Dealer
Member#: 338381
check for a coolant leak somewhere.. this weather can really dry and and crack rad hoses.. specifically look under the top rad house out of the coolant crossover pipe for signs of leakage
The Salami Dealer is offline   Reply With Quote
Old 02-10-2013, 11:23 AM   #8
grknss
Member#: 44592
2004 WRX STI
Platinum Silver Metallic
Yes OEM do.
grknss is offline   Reply With Quote
Old 02-10-2013, 02:12 PM   #9
h00z0r
Member#: 212540
Eggroll is likely right, try burping the system
Old 02-11-2013, 09:03 AM   #10
LIChuck
Member#: 266122
2007 WRX Limited
UGM
The system froze up and the coolant wasn't circulating, add antifreeze.
LIChuck is offline   Reply With Quote
Old 02-11-2013, 10:34 AM   #11
tatoodhye
Member#: 108268
Strange- this happened to my friend in the same exact car. This was back many years but he experienced the same thing when i was with him. I havent talked to him for a while but if I can- ill try to find out for you
tatoodhye is offline   Reply With Quote
Old 02-11-2013, 04:20 PM   #12
gamma1232
Member#: 249493
2005 STi
I burped the system this weekend. It looked full when I started (i.e. the radiator was full) but I ran it with the cap off and it ended up taking like 1/2 a gallon of coolant from all the air that escaped. Hopefully that does the trick.
Thanks for all the responses.
Old 02-11-2013, 06:34 PM   #13
BraveSTi
Member#: 262030
I'd say the thermostat chit the bed.
BraveSTi is offline   Reply With Quote
