Old 02-07-2013, 10:34 PM   #1
JayTeeEye
Member#: 346332
Default 02 WRX Boost Dropped
This is my first post on NASIOC so bear with me. I have a 2002 Subaru WRX, pretty stock except for:
- K&N Cold Air Intake
- Vishnu Sub Zero ECU
- Stock Turbo
- Stock Exhaust
- No BOV
I usually have my turbo at 7psi. This is how i bought the car, I haven't messed around with the ECU yet. I've never had any problems with the turbo, it's always been consistantly running 7psi without drop offs. But today the boost would only go up to 4psi. When I was WOT it would stay at 4psi and it wouldn't taper off. Idle is around 10 hg. When the rpm's get up to around 3200, i hear a high pitched whistle (not the regular turbo spool, it's a different noise). Also, this is a daily driver, so considering that most mechanics are closed on the weekend, is it bad if I continue to drive it until i can take it in, or will i damage the turbo? Please help me try to diagnose this so i can relax a little
Jesse
JayTeeEye is offline   Reply With Quote
Old 02-08-2013, 10:33 AM   #2
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Hey Jesse,
How many miles are on the car? do you have any check engine lights?
Mike
GrimmSpeed is online now   Reply With Quote
Old 02-08-2013, 11:43 AM   #3
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Sounds like you have a boost leak.
That being said, 7 psi is WAY TOO LOW for stock. You should be making 12-14 psi stock, so there has been a bigger problem for awhile. Along with that, the VISHNU ECU might be hurting your car severely.
Old 02-09-2013, 11:02 PM   #4
JayTeeEye
Member#: 346332
137xxx and no check engine lights. I think my boost control solenoid might be messed up. I'm gonna try going with a 3 port solenoid with a tune, and i'll see what happens. I'll get the boys at me local Vex performance shop to take a gander at it.
Old 02-09-2013, 11:54 PM   #5
wrx1392
Member#: 342331
2003 wrx
blue
i would bet money the stock tubo to TMIC hose has a split in it ,and your turbo hoses to your EBC is not right ...7psi is the sring pressure in the waste gate actuator. agreed you should be getting 10 -12 psi in stock form.
wrx1392 is offline   Reply With Quote
Old 02-10-2013, 12:20 AM   #6
BadSubie123
Member#: 343907
2002 Impreza Wrx
Rally Blue
Glad I read this. Having the same issue with only mod a drop in filter
BadSubie123 is offline   Reply With Quote
Old 02-11-2013, 06:22 PM   #7
JayTeeEye
Member#: 346332
Yeah, 7 psi is the wastegate pressure so im not sure what the problem is. I took it in to a shop and they said that after basic diagnostic testing, i don't have a boost leak because it holds the vacuum as it should, the only problem is not reaching peak boost. They said they can probably find out what's wrong with it by tomorrow. And BadSubie, I'll let you know as soon as i do.
Old 02-11-2013, 06:37 PM   #8
DZXN
Member#: 306186
2002 Subaru WRX
Do you know what vac your car should be sitting at idle? Mine sits at 16-18inHg @ 4500 feet. Might want to do a real boost leak test. Is your local shop a Honda/all other JDM shop? Search DIY boost leak test and spend $20 at the hardware store. If they didn't pressure test you have no idea if you are leaking or not. Or find a Subaru shop to have the test done.
DZXN is offline   Reply With Quote
