Old 12-31-2009, 01:25 PM   #1
skwirnmn
Member#: 231356
09 2.5i
black
Default front sway bar size on impreza 2.5i
was just curious what the stock sway bar sizes were. just a guess but if the front sway was say, 20 mm, and the rear was 15 mm, then to acheive nuetral-steer i would want to upgrade the rear sway to 20 mm? im a complete noob at this and was just wondering. i have some pretty nasty understeer on my 09 impreza and was wondering what it would take to get to nuetral, or possibly over steer, beyond adding a negative camber and messing with toe and caster. any help is greatly appreciated. my impreza is a DD but i still make agressive turns and experience loads of understeer in it.
skwirnmn is offline   Reply With Quote
Old 12-31-2009, 02:40 PM   #2
chazly413
Member#: 151079
2005 2.5RS RBP
too many friction losses
Front is 20mm stock. I don't think the new Imprezas come with a rear sway bar.. I have a 20mm rear sway bar and I love it.
chazly413 is offline   Reply With Quote
Old 12-31-2009, 03:21 PM   #3
The Minx
Member#: 210214
08 Impreza 2.5i
DGM with a hint of dirt
chazly413 is right, the new 2.5i don't have a rear sway bar, that's one thing you can add to get better handling. Getting a stock wrx rear sway bar should be good for starters. I'm not sure what size the front sway bar is.
The Minx is offline   Reply With Quote
Old 12-31-2009, 04:52 PM   #4
EdHilario
Member#: 137398
2004 Impreza 2.5RS
It should be 19mm
EdHilario is offline   Reply With Quote
Old 01-01-2010, 01:04 PM   #5
kevin 5150
Member#: 21774
kevin 5150 is offline   Reply With Quote
Old 01-03-2010, 08:43 PM   #6
skwirnmn
Member#: 231356
09 2.5i
black
wow.. didn't know this, thank you for the help. am i correct that to acheive perfect nuetral steer the front sway and rear sway bar sizes should be the same?
Old 01-03-2010, 09:20 PM   #7
chazly413
Member#: 151079
2005 2.5RS RBP
If the car were 50-50 weight distribution and the spring rates were the same and everything, maybe, but it's not perfectly neutral. Basically, it's not that simple.
Old 01-04-2010, 11:42 AM   #8
GHK
Member#: 103886
2005 WRX
Originally Posted by kevin 5150 View Post
Didn't know regular imprezas don't have rear sway bar.
GHK is offline   Reply With Quote
Old 01-04-2010, 01:23 PM   #9
aclver1
Member#: 114177
2004 Impreza 2.5rs
70 Datsun Fairlady
Only the 08-09 don't have rear sway bars but all previous years did.
aclver1 is offline   Reply With Quote
Old 01-04-2010, 03:01 PM   #10
suub07
Member#: 163702
2007 impreza 2.5
UGM
my 07 2.5i had a 12 mm wet noodle in the rear. went to a 24mm adjustable, and love it
suub07 is offline   Reply With Quote
Old 04-07-2011, 02:37 PM   #11
wcolbyb
Member#: 267907
thank you, i have a 2002 WRX and want to give my 20 mm sway bars to my buddy with a 2007 NA impreza. what size are the front 2007 impreza sway bars? adn do you know if my WRX ones will fit on his? thanks
wcolbyb is offline   Reply With Quote
Old 04-07-2011, 04:07 PM   #12
Millhouse_5
Member#: 269208
95 JDM STI RA
08 2.5i Sedan
Ive been looking into this a bit lately as i will be getting one soon.
if your looking to upgrade your front bar without modification to your piping, the only bars (that ive been able to find) that will fit the 08+ na are the rallitek 22mm front and one single na specific 22mm whiteline adjustable bar (BSF35Z).
Neither are going to be a super dramatic handling difference but it should be noticeable
now the rear bar will be a quite drastic difference seeing as there just isnt one. Either get one off a WRX or STI if your looking for the cheap route or get some after market bar if you want to go a little stiffer or just want something shiny and new. Any 08+ should fit fine
Millhouse_5 is offline   Reply With Quote
Old 07-26-2011, 02:54 AM   #13
04jmpreza
Member#: 128822
2004 2.5RS Slushbox
Pacifica Blue Pearl
if you get big bars make sure your endlinks can handle it. im not familiar with the new subies but the older ones had plastic endlinks that could snap. also, make sure to reinforce the mounts on the rear. the rear bar on my '04 is still the biggest difference of anything i have put on my car, and the only stock things on it are wheels control arms and motor mounts. btw, if you remove weight from the front, it will help reduce understeer, without inducing oversteer. for example, deleting fog lights or A/C. good luck and safe motoring!
04jmpreza is offline   Reply With Quote
Old 12-14-2011, 04:39 PM   #14
bradze
Member#: 103208
2011 Outback
Azurite Blue
what size is the rear swaybar on an '11?
bradze is offline   Reply With Quote
Old 12-15-2011, 12:12 AM   #15
GrundleJuice
Member#: 165749
It's a meaty 0mm
Old 02-11-2013, 02:27 PM   #16
Levelout109
Member#: 346694
Subaru Banner 2011 2.5i sway bars?
I have a 2011 Subaru 2.5i (non-turbo), I'm trying to figure out what the best sway bars, front and back, I should put on it. Also, I was wondering how difficult the job would be to do it myself? Any help would be appreciated, thank you.
Levelout109 is offline   Reply With Quote
Old 02-11-2013, 02:40 PM   #17
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
I would suggest using a setup that has understeer, aka a front bar that's larger than the rear sway bar. As for size, brand, and endlinks, I suggest you research which you should get. The install is fairly simple and shouldn't take more than an hour for the front and rear. Just make sure to install them while the car is on ramps or the ground so that the suspension is under load.
Old 02-11-2013, 04:19 PM   #18
Levelout109
Member#: 346694
now heres a tricky one, where do they even sell sway bars for the 2.5i, not the wrx or sti?
Old 02-11-2013, 04:52 PM   #19
isotopesope
Member#: 265783
2008 wrx
Niner ROS 9
http://www.rallitek.com/RalliTEK-Fro...08-2010/p-4385
http://www.rallysportdirect.com/Whit...2mm-Adjustable
Old 02-11-2013, 08:04 PM   #20
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
Don't bother in changing the front. Its already a decent one and to find a proper one that fits will costs for minor gains if any
On the rear sway, pre-2008, a rear sway upgrade was a god thing and very cheap. Most n/a impreza had 13mm bar and going to 20mm bar was great to make it neutral balance
On new suspension on 08+ impreeza, its different. Multi-link suspension and all. I went to whiteline adjustable bar and wasn't big improvement
Check James Wilson thread. He added a still bar on his 2012 impreza and was cheap upgrade. For your 08+ impreza. Could be a decent upgrade with extra parts needed to install rear bar
Robin2 is offline   Reply With Quote
Old 08-05-2015, 02:38 PM   #21
tootin_newton
Member#: 427409
2007 2.5i
I have an 07 2.5i and I am looking to get an 02 wrx rear sway bar. Do I need to get new bushings to fit it or will my stock bushings fit?
tootin_newton is offline   Reply With Quote
Looking for sway bars for a 2007 2.5i Wagon nuggetWRX Brakes, Steering & Suspension 15 05-13-2008 10:04 AM
Front Sway bar sizes mr_subaru_rs Brakes, Steering & Suspension 13 04-16-2008 03:23 PM
'99 RS stock front sway bar size? yamahito Brakes, Steering & Suspension 4 07-18-2006 10:29 PM
MY 00 GC8 front sway bar size pistoffjstr Brakes, Steering & Suspension 2 05-18-2003 08:49 PM
front sway bar size psaeko Brakes, Steering & Suspension 1 03-06-2002 09:01 AM
