Old 02-11-2013, 09:46 AM   #1
imac6471
Member#: 309481
2011 OBSwirl WRX
2004 FXT "Tucker"
Default Jdm motor in 97 outback
My replacement motor is arriving today from Foreign Engines Inc. Ill be installing it this weekend and had a few questions.
1. Should i replace the head gaskets?
2. Anyone have experience with Foreign engines before?
3. Anything i need to look out for as far as install goes?
imac6471 is offline   Reply With Quote
Old 02-11-2013, 12:00 PM   #2
ImNOrobo
Member#: 255716
Itsa bugeye 04, V9
RHD and it makes me smile
What year motor, or version if you prefer. Estimated km on said motor?
Check out the ej207 owners thread in the 2.0 liter section. Tons of info in there. Usually people replace the timing belt with the gates kit and spark plugs. They don't usually crack the motor open unless needed.
Mine was a super clean and very low km motor. I didn't replace anything but the spark plugs and the idle air control valve since that was bad. I have 10k miles on the swap with quite a few 8500 pulls and no issues so far.
Good luck with the swap.
ImNOrobo is offline   Reply With Quote
Old 02-11-2013, 05:12 PM   #3
imac6471
Member#: 309481
2011 OBSwirl WRX
2004 FXT "Tucker"
Its a 97 ej25d. Estimated milage is 50k miles. I have to change some stuff to comply with emissions. I also purchsed the gasket kit which includes, intake and exhaust, cam seals, crank seal, oil filter, timing belt and valve cover gaskets. Im hopin all goes smooth but I except to run into a snag somewhere cause thats just the nature of the beast. No 8500 pulls in this one though, just a simple daily haha
Old 02-11-2013, 09:24 PM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
If you search for "JDM EJ25D" in this forum, the Legacy forum, and the Normally Aspirated Powertrain forum you'll find a number of threads about people using those engines.
A couple examples:
http://forums.nasioc.com/forums/show....php?t=1243518
http://forums.nasioc.com/forums/show....php?t=1726807
http://forums.nasioc.com/forums/show....php?t=1749870
As you'll find in those threads, I did not do the head gaskets, but I did all of the seals that you mentioned in the post above. I also used the wiring harness, all the sensors and accessories from my old engine because I knew they were all functioning properly.
All in all it should be pretty straightforward.
Old 02-11-2013, 09:55 PM   #5
imac6471
Member#: 309481
2011 OBSwirl WRX
2004 FXT "Tucker"
A couple examples:
Exactly what i should have done in the first place, thank you!
