Old 01-29-2013, 03:58 PM   #351
marios03wrx
Member#: 33593
2002 WrX-ShAgNwAgOn
No motor No Trans :-(
Originally Posted by abrumlev View Post
I'm looking to dump my OG green for a td06 sl2 20g.
Hoping for 20# in the range of 3500-3700, 320whp on 93 on an aging 120k mileage shortblock. Sound reasonable?
You have a pm kind sir..
Mario
marios03wrx is offline   Reply With Quote
Old 02-03-2013, 01:39 PM   #352
Boostedbob
Member#: 336241
08 Sti
OPB
Hey guys, found out my vf48 on my 08 sti is on its way out and have decided on purchasing the Td06sl2 20g with the 8cm hotside. Question is will I need to upgrade my coolant line and oil feed line to the turbo or will it mate up, or does kinagawa supply new lines?
Want to get everything before the purchase of the turbo so I won't have any downtime.
Boostedbob is offline   Reply With Quote
Old 02-04-2013, 03:20 AM   #353
gabedude
Member#: 10108
07 STI
60Trim spun rod bearing
Kinugawa turbos include all lines and necessary hardware for installation (even the gaskets). They also come with a SS oil feed line with the correct restrictor size for the Kamak CHRA.
The WHP numbers posted above are very conservative. A TD05SH-16G can make 350 AWP on 93 octane with a catless turboback.
I would think it would be very easy to crack into the 400 AWHP range with a TD06SL2-20G on 93 octane. It is very similar to the older FP Green.
gabedude is offline   Reply With Quote
Old 02-04-2013, 08:01 AM   #354
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
Take a look at my math and tell me where I can improve the formula so I can go through it and correct the WHP numbers.
Old 02-04-2013, 09:21 AM   #355
V8 GTFO Lesbic WGN
Member#: 191212
2007 FXT-5MT E85 20G
TD06SL2 Kinugawa
I was just looking at the hardware yesterday and the vacuum lines and fittings look better than OEM, the lines have a dual coating to resist oil and seem to be made of silicon, the hose compression fittings are the same as OEM, attention to detail on this turbos is just ridiculous, pisses me off how ignorant people are calling these turbos EBay just because they are $500+ less than a Blouch.
V8 GTFO Lesbic WGN is offline   Reply With Quote
Old 02-04-2013, 09:42 AM   #356
Boostedbob
Member#: 336241
08 Sti
OPB
Thanks gabe! Yeah I'm looking at 400, I'm sure ill be able to push more but ATM on the stock tmic. Did all the other supporting mods plus built bottom end.
It's good to know that the parts kinagawa supplied with there turbo look to be better then oem.
Excited to see what the car will do with E85. Certainly made the vf48 come to life.
Old 02-04-2013, 10:06 PM   #357
gabedude
Member#: 10108
07 STI
Right on. They are also sold here. So what the owner lists items on ebay as well.
Old 02-04-2013, 10:14 PM   #358
gabedude
Member#: 10108
07 STI
Yup, Kinugawa makes a very nice install kit. They do not bother grinding off part numbers or painting the turbo, etc. They just stamp the turbo with the correct plate (some are ghost painted Kinugawa on the compressor housing. Sorry, did you want a crinkle red with that? Go to Home Depot and buy some high temp texture paint for $10.
Old 02-04-2013, 11:00 PM   #359
waspdawg02
Member#: 267861
2008 WRX Sedan
Just ordered the SL2 20 G for my 08 WRX. Looks like everything will line up. I will be sure to post my dyno results on here..... I'm like a kid on christmas eve.... Cant wait for this thing to get here. I'm gona schedule my tune tomorrow!
waspdawg02 is offline   Reply With Quote
Old 02-11-2013, 09:06 PM   #360
Omegared99
Member#: 277965
2007 WRX
Grey
Ok after reading and reading and searching this post im gonna pull the trigger and buy Kinugawa probaly just an 18G and get a STi TMIC. I have a 2007 WRX running AP stage 2 with Perrin Tune. Im in GA sand getting to a reasonable tuner is like pulling teeth so i may go with an E-TUNE. Till i can get time of from the army to get a protune. I think also i will purchase a 3port EBCS but of course will not install till tune time. Im figuring i cant just run a a COBB 18G MAP. So can someone point me in a direction maybe a link.
Omegared99 is offline   Reply With Quote
Old 02-11-2013, 09:40 PM   #361
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
^ DOOO Eeeeeeiiiit!
sense of nature is online now   Reply With Quote
Old 02-11-2013, 10:57 PM   #362
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
Just get a Phaton etune, that's what I am doing when I finish the install on the 07 FXT, tired of the Stage 2 Cobb OTS Map (4 years now).
Here is my Kinugawa journal (link)
Old 02-12-2013, 12:32 AM   #363
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
+1
I like the quality of them, and they make good power too.
Old 02-12-2013, 12:35 AM   #364
EvileyeZ88
Member#: 233501
07AD 337/335SAXWAGON
99 outback sport
Originally Posted by Junior2JZ View Post
+1
People still underestimate these turbos, even mods on this very site.
I think Kinugawa and kamak sales are going to explode in the next few years.
~Evil
EvileyeZ88 is offline   Reply With Quote
Old 02-13-2013, 01:54 PM   #365
powerls
Member#: 74322
06 STI basic build
TD06SL2 8cm2 20G
sorry for the poor photo quality. I'm certainly happy with the 349HP/349Trq figures, I do wish that it would have spooled a bit faster. Hill at Agile mentioned that I'm currently limited by my stock IC and exhaust.
Dynapack Dyno
EJ257
STI TD06SL2 20G 8cm housing w/IWG @19psi
Custom AP Tune
850cc
3in no cat DP
stock STI exhaust
stock STI TMIC
TGV Deletes
Forged Pistons
Stock STI Rods
Perrin Inlet Hose
Crawford AOS
powerls is offline   Reply With Quote
Old 02-13-2013, 02:35 PM   #366
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
What are your IDCs? I have 750cc and suspect will not be sufficient.
Old 02-13-2013, 03:09 PM   #367
Boostedbob
Member#: 336241
08 Sti
OPB
Dynapack Dyno
EJ257
Custom AP Tune
850cc
3in no cat DP
stock STI exhaust
stock STI TMIC
TGV Deletes
Forged Pistons
Stock STI Rods
Perrin Inlet Hose
Crawford AOS
Good looking dyno plot very smooth bet she pulls hard!
Old 02-13-2013, 03:37 PM   #368
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Dynapack Dyno
EJ257
Custom AP Tune
850cc
3in no cat DP
stock STI exhaust
stock STI TMIC
TGV Deletes
Forged Pistons
Stock STI Rods
Perrin Inlet Hose
Crawford AOS
Is that spool up the same on the street? What gear on that pull? Pump gas? Maybe he should play with AVCS some.... And you should get a better flowing catback
FuJi K is online now   Reply With Quote
Old 02-13-2013, 07:35 PM   #369
powerls
Member#: 74322
06 STI basic build
TD06SL2 8cm2 20G
I'm not exactly sure what my IDCs are at, but I wouldn't use anything less than 850cc for 20G's. I'm sure other people may disagree, but since I had to buy new injectors anyway, I figure go big or go home (within reason mind you )
power is great! top end power is scary, still I wish the spool was a bit better
spool is more or less the same, maybe a 200 rpm difference. 4th gear pull on 93oct. I was really trying to not get a 3in catback, since the cops are looking to pull me over already, but sadly I think I will have to make the jump.
Like I said, overall, very happy with the car. I still wonder if I should have gone with an 18G variant vs. a 20G variant. I really miss the peppiness of the VF39, but the top end power is awesome on my SL2-20G
Old 02-13-2013, 09:32 PM   #370
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
What boost controller?
Old 02-13-2013, 10:04 PM   #371
powerls
Member#: 74322
06 STI basic build
TD06SL2 8cm2 20G
Just an AP tune
Old 02-13-2013, 11:38 PM   #372
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Just an AP tune
So my guess is you're on the stock boost controller.....
Old 02-13-2013, 11:42 PM   #373
powerls
Member#: 74322
06 STI basic build
TD06SL2 8cm2 20G
you are correct. sort of a build on a budget and I didn't really see the need for an aftermarket BCS
Old 02-14-2013, 10:07 AM   #374
nate_fisher
Member#: 270482
2011 turbotek fxt
[email protected] 4eat xt record?
A 3 port will get you better spool and better control for around $100 but you would have to retune for it again. I maxed out my id1000 and 300lph pump on the same turbo on e85 around 23psi so i would think 750cc would be cutting it close on pump gas. I will be hardwiring the pump to lower them a bit with the dw hard wire kit which is something you could do to stretch out the 7500cc a bit.
nate_fisher is offline   Reply With Quote
Old 02-14-2013, 10:26 AM   #375
abrumlev
Member#: 197920
2005 Legacy GT
ABP
Yeah sounds like you're missing a couple parts that would really make a significant difference. Grab an EBCS and 3" catback, you should see a good bit of pickup on spool/boost control up top. I really want to know what this turbo does as I'm strongly considering picking one up to replace my og fp green.
abrumlev is offline   Reply With Quote
FS : Kinugawa Td05 20G Turbo + Boost Gauge. Fit Subaru thenic123 Engine/Power/Exhaust 15 06-08-2011 07:02 PM
VF39 vs HTA68 vs Blouch TD0518G 8 cm dmcutter Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 103 03-11-2010 01:41 PM
NEW 1 Bar / 14.5PSI Blouch Turbo Wastegate Actuator NEW 1 Bar / 14.5PSI Blouch Turbo dexterous Engine/Power/Exhaust 6 02-14-2010 07:55 PM
Blouch Turbo Budget Series Turbos Blouchturbo Engine/Power/Exhaust 18 06-05-2009 04:07 PM
fullrace GT3076 1.5 Scroll vs Blouch DOM III vs FullRace Twinscroll GT35R azn_ryder02 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 58 04-06-2009 10:29 PM
