Old 02-09-2013, 10:19 PM   #1
teefivetee
Member#: 296046
2005 sti
Default oil leak?
Hey guys. Few months back did all the seals when I did my timing belt. Just did the o ring on the oil cooler 1000 back. Checked oil it was like 50 percent full. Is it really possible I burned that much off? No hard driving either. I use rotella 5w40. I don't see any visible leaks so I'm left Co fused at this point.
Btw. No blue smoke or any weird smoke of the exaust. Just thought I'd add that too
teefivetee is offline   Reply With Quote
Old 02-10-2013, 11:05 PM   #2
teefivetee
Member#: 296046
2005 sti
Bump?
Old 02-10-2013, 11:10 PM   #3
lavid2002
Member#: 226864
You check the oil level before you primed the system + ran it?
Top it off and make sure you get an accurate reading and try again. I bet there is an error somewhere.
Old 02-10-2013, 11:25 PM   #4
teefivetee
Member#: 296046
2005 sti
Always checked it after I let it sit overnight. I topped it off. It's stayed full now for two days. I suppose I'll keep an eye on it. Not too sure where it could be leaking from
Old 02-12-2013, 03:29 AM   #5
Cois32
Member#: 294755
2004 Impreza WRX
WRB vf39'd
well it would either leaking externally or burning within the engine.
Cois32 is offline   Reply With Quote
