Welcome to the North American Subaru Impreza Owners Club Monday August 3, 2015
Old 01-22-2012, 05:25 PM   #1
staticchmbr
Member#: 140108
2000 impreza OBS
silver/titanium
Default does it matter where an exhaust resonator is placed?
i have an 04 wrx .. fully catless. when the boost kicks in, it gets a bit raspy. my exhaust consists of a catless up pipe, 4" turboxs downpipe, 3" turboxs straight pipe/stealthback mid and 2.5" turboxs axleback.
i already bought a 3" straight through resonator, so my question is, does it matter how far forward or backward i mount the resonator? my idea was to take the turboxs catless straight pipe, cut it, and mount the resonator up front there.. is this a dumb idea? should i just mount it toward the back of the midpipe instead?
staticchmbr is online now   Reply With Quote
Old 01-22-2012, 05:31 PM   #2
drewmob
Member#: 214192
2003 WRX
No it doesn't matter just put it where it'll fit
drewmob is offline   Reply With Quote
Old 01-22-2012, 05:39 PM   #3
mod maniac
Member#: 300551
2&4 fxt & fxt sti
Fullers Garage
2nd that
Old 01-24-2012, 10:48 AM   #4
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
it helps to locate it in the exhaust pipe.
ride5000 is online now   Reply With Quote
Old 01-24-2012, 12:12 PM   #5
wrxlaunch
Member#: 181298
2015 WRX Limited
Lightning Red
Huh..
wrxlaunch is online now   Reply With Quote
Old 01-24-2012, 12:12 PM   #6
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
I came here to post this.
Psychoreo is online now   Reply With Quote
Old 01-24-2012, 01:20 PM   #7
staticchmbr
Member#: 140108
2000 impreza OBS
silver/titanium
damn, i thought it got mounted on the roof... hmmm.. must rethink my car building abilities lol
Old 02-10-2013, 11:33 PM   #8
redrexmeister
Member#: 111692
04 wrx wagon
did you eventually install the resonator? did it help to make it quiet?
redrexmeister is offline   Reply With Quote
Old 02-10-2013, 11:53 PM   #9
IheartAWD
Member#: 329962
resonator sucks, get a couple glasspacks
IheartAWD is offline   Reply With Quote
Old 02-11-2013, 01:44 AM   #10
mod maniac
Member#: 300551
2&4 fxt & fxt sti
Fullers Garage
I installed a glasspack on one of my loud exhausts and it did nothing.
Old 02-11-2013, 01:59 AM   #11
paulpat
Member#: 237145
02 WRX
12 FXT
The engineer in me says it matters because how pressure waves resonate through pipes and it will probably be .001%
paulpat is online now   Reply With Quote
Old 02-11-2013, 02:30 AM   #12
nhat
Member#: 140163
03 STi
hellaflunctional
Even if it does matter, there's only 1 spot a resonator can be placed on our exhaust systems.
nhat is offline   Reply With Quote
Old 02-11-2013, 07:44 AM   #13
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
When they designed the car, they calculated the wavelength and the amplitude of the vibration of the exhaust past the flex point (the donut), there is some kind of resonance, which creates the droning and raspiness, then they determined the location of the resonator, but adjusted it due to packaging.
So yes, it needs to be where the factory placed it.
If you weld it into the axleback, it may have a different effect.
If you still have the flex point with the donut, but weld the resonator upstream of the donut, it may have a different effect as well.
Old 02-11-2013, 09:23 AM   #14
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
well if we're talking about resonant effects (and i don't disagree that we should) then changing the diameter of the pipe anywhere along its length will also change the frequency and/or optimal location.
Old 02-12-2013, 12:26 AM   #15
moxynoff110
Member#: 346776
Yes it does matter but there are many variables that dictate where it should go. Thats why we leave it up to reputable companies to engineer a nice sounding exhast. I would just put it somewhere in the midpipe and see how it sounds.
moxynoff110 is offline   Reply With Quote
Old 02-12-2013, 06:28 AM   #16
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
aftermarket exhaust companies engineer the optimal placement of a resonator?
not likely!
most can barely get welds to last 5 years.
Does it matter where I mount the inline fuse? Jsunn Car Audio, Video & Security 25 11-14-2009 11:44 PM
Does it matter where I get my mortgage through? tacomaprime Off-Topic 4 10-07-2008 08:37 PM
Does it matter where I have paint color matched? IllNastyImpreza New England Impreza Club Forum -- NESIC 2 04-29-2008 02:28 PM
Does it matter WHERE you went to college? R1ckyB0bbyyy Off-Topic 44 01-12-2008 05:20 AM
