Old 06-15-2012, 11:50 AM   #151
Broggie90
Member#: 308726
2008 Wrx
Red
Originally Posted by ah2049 View Post
The clear tube is the line going to my gauge:
Sweet! Thanks alot man!
Broggie90 is offline   Reply With Quote
Old 06-15-2012, 12:23 PM   #152
draco159
Member#: 204121
2005 WRX Wagon
Broggie90, I have mine connected differently. I will get you a pic later this afternoon. Mine is teed off of the intake manifold on the front passenger side.
EDIT: Found a pic on another forum. See image number 2 here. I ran a boost hose from my gauge directly to this T. He has is going through the passenger side only because that is where the driver sits.
Boost gauge hose routing
draco159 is offline   Reply With Quote
Old 06-15-2012, 12:26 PM   #153
ah2049
Member#: 261863
2015 Focus ST
OW
Not a problem.
ah2049 is offline   Reply With Quote
Old 07-26-2012, 01:46 AM   #154
devlin0311
Member#: 304958
2006 the best one
black
I have the greddy informeter ver. 1.7 and I set it to read intake manifold pressure basically using my obd to read off boost instead of using the boost sensor. Is this an accurate way of reading boost ? Do I still need to get the boost sensor?
devlin0311 is offline   Reply With Quote
Old 08-21-2012, 12:01 PM   #155
enjoilife1991
Member#: 322400
03 WRX 360whp
i plan to go catless within the next month and was wondering if getting a wide band a/f gauge would be a good idea
enjoilife1991 is offline   Reply With Quote
Old 09-08-2012, 11:07 PM   #156
Mr. SUAVE
Member#: 96893
hello i have question. when your key is in *on* position do you have a warning light on your oil pressure gauge? is this normal? because I have a Greddy oil pressure gauge and when my key is on *on* position my warning light is on...
thanks
Avelino
Mr. SUAVE is offline   Reply With Quote
Old 09-09-2012, 09:31 AM   #157
Prosport Gauges
Member#: 124196
Yes, if you plan on tuning
Prosport Gauges is offline   Reply With Quote
Old 09-09-2012, 09:33 AM   #158
Prosport Gauges
Member#: 124196
thanks
Avelino
Yes, it will show a warning because with the key on only their is no oil pressure, so the gauge "thinks" there is a problem.
Old 10-02-2012, 02:43 PM   #159
nepbug
Member#: 328631
2008 FXT
Originally Posted by shackdaddy View Post
I clicked on the hyperlink for the vdo website above and when I did a search for a clock on their site it took me to the international division which was in French and worst of all it didn't list any prices or methods to order one.
Here's a better VDO link to look at their automotive gauges.
http://www.vdo-gauges.com/
nepbug is offline   Reply With Quote
Old 11-30-2012, 05:33 PM   #160
DoomsdayFAN
Member#: 320580
For me, I'd like to add the three gauges, but it's just a matter of where. I really like the A pillar mount, however it seems a little too "out in the open" for my tastes. While I love the look it while sitting in the driver's seat, I've never really thought to highly of it seeing it on other (random) people's cars. It just comes across wrong to me for some reason.
But I am not a fan at all of the steering wheel mount. I just do not like the look or location of it at all.
I'm not a fan of the glove box mount, even less so than I am a fan of the steering wheel mount.
I do sorta like the center-dash board mount, but with the stock clock and temp read-outs up there, I don't see any room for gauges.
Realistically, based on what I'm comfortable with, I think the A pillar mount is my best bet. There are a lot of pros I can think of, and only really one con. So maybe I'll just suck it up and go with that. And although tinting front windows in cali is forbidden, maybe I'll just do that to mask the pillar mount a bit. IDK.
DoomsdayFAN is offline   Reply With Quote
Old 01-28-2013, 04:22 PM   #161
Da_Conk
Member#: 338596
02 WRX Sedan
Blaze Yellow
Default boost wiring help
ok so just installed a prosport boost gauge and oil temp (missing harness for power on oil temp so haven't wired it)
The wiring for the boost is driving me crazy. It doesn't read (brand new sensor) and is possessed.
I tapped my clocks power.
The gauge never shuts off.
Does not read.
I don't know how but with headlights on and wipers or turn signals on the gauge fluctuates (like maxes out then goes back down) makes no sense to me cause I tapped the clock.
Flashes with my alarm (locking / unlocking car)
To the point where I'm gonna take it to a shop to have them fix the wiring up.
Da_Conk is offline   Reply With Quote
Old 01-28-2013, 04:33 PM   #162
Prosport Gauges
Member#: 124196
Or just give us a call so we can walk you through the wiring connections. You have it wired up wrong and should not be using the clock wiring as that is a dimmable circuit.
Old 01-28-2013, 05:40 PM   #163
Da_Conk
Member#: 338596
02 WRX Sedan
Blaze Yellow
Thanks for the contact! You guys can be looking forward to a call from me soon, names Nick.
I'll also be ordering the harness soon.
Haha I was following a guide I found online and they had tapped the clock, oh well can't take everything on the internet as truth.
Old 01-29-2013, 08:09 AM   #164
Prosport Gauges
Member#: 124196
Ha... no you cannot...
As always come right to the source, we will fix you up
Old 02-12-2013, 03:34 PM   #165
subie bro
Member#: 327229
2005 Wrx
Hello, I need help. I bought a LC-1 widebad for my 05 wrx and I have no clue how or where to tap my ignition power wire, and headlight (dimm). If anyone could help me wire this that would be great feel free to pm me.
-cole
subie bro is offline   Reply With Quote
Old 07-09-2013, 08:47 AM   #166
CrownRoyal
Member#: 205320
2013 WRX Sedan
Ice Silver
How much would it be to have a shop install a boost and oil pressure gauge?
CrownRoyal is offline   Reply With Quote
Old 11-15-2013, 11:04 PM   #167
Phlurry02
Member#: 351629
2002 WRX Sedan
Midnight Black
one quick question. my girlfriend ordered me a Prosport Air/Fuel Ratio gauge with me not knowing and basically reading this its useless. If i were to order a Wideband O2 like this one
http://www.ebay.com/itm/AEM-Wideband...2fc8b9&vxp=mtr
would this work with the prosport gauge? or is there any cheaper ones online that would work? If not then i can return it.
Phlurry02 is offline   Reply With Quote
Old 11-15-2013, 11:44 PM   #168
Web Foot STi
Member#: 39086
2004 STi
Any A/F probe will not read correctly in the up pipe. You have to mount it in the down pipe, and yes you need to weld in a mounting boss. The Prospot sensor will be fine if mounted in the right spot.
(It has to do with back pressure from the turbo.)
Web Foot STi is offline   Reply With Quote
Old 11-15-2013, 11:50 PM   #169
Phlurry02
Member#: 351629
2002 WRX Sedan
Midnight Black
correct me if im wrong but if mounted in the right spot on the downpipe i wouldnt have to purchase this wideband o2? and it would read accurately?
Old 11-15-2013, 11:57 PM   #170
Web Foot STi
Member#: 39086
2004 STi
I don't know about mixing and matching parts, but IIRC the Prosport is a wide band system.
Do you have oe of these: http://prosportgauges.com/wideband_AFR_Gauge.aspx
Simple search. The kits come with the weld in bung
Old 11-16-2013, 12:27 AM   #171
Phlurry02
Member#: 351629
2002 WRX Sedan
Midnight Black
no she got me this one : http://prosportgauges.com/amber-whit...tio-gauge.aspx
this one is just for the lights. guess its useless.
thought i would be able to just order the 02 end : http://prosportgauges.com/bosch-wide...sor-17025.aspx
and just use it with this gauge, but i guess not. Might as well return it and get an EGT gauge or Oil pressure gauge.
Old 11-16-2013, 12:39 AM   #172
Web Foot STi
Member#: 39086
2004 STi
You should send Prosport an e-mail and ask them. They might work together.
Old 11-16-2013, 12:44 AM   #173
Phlurry02
Member#: 351629
2002 WRX Sedan
Midnight Black
Will do! thanks for the help!
Old 11-19-2013, 03:40 AM   #174
gift008
Member#: 374016
Default Thanks
Thank you very much
gift008 is offline   Reply With Quote
Old 11-26-2013, 09:19 PM   #175
thescreensavers
Member#: 333820
2013 WRX Limited
How are maddad guages overall, I search and found some negatives but can't get a good overview of them.
Are there any other gauges that match the 08+ Wrx cluster?
I know podi is making some but interested in getting the guage in the near future
thescreensavers is offline   Reply With Quote
Uppipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 382 08-24-2016 02:10 AM
Pulley FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 116 08-01-2016 10:03 PM
Downpipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 322 05-18-2016 02:47 PM
Wheel FAQ: Read if you are thinking of buying some! Unabomber Newbies & FAQs 134 09-02-2015 04:05 AM
