#26 |
Member#: 268354
NESIC
Vehicle:02 WRX 05 LGT Slow Automatics |
I'm soo confused as to what you're getting to. Bumping base pressure?
#27 | |
Member#: 193757
MWSOC
Vehicle:2006 XTI Limited OBP, Junior tuned |
A bigger pump (like the walbro 465) with a larger 10-12 gauge re-wire through the OEM FPC will help maintain a constant voltage at the 33, 66 and 100% pump duties, a FPR (like the Aeromotive 1000) to set the base pressure higher like 50 psi and you can increase the flow rate of any injector. If you do this you can decrease the IDC's for the given injector. Now improve VE by means like the Killer B Holy Header and head work, PnP of the intake manifold, piston design...etc....and then you will make more power at lower rpm's and make more over all because you are wasting less power through parasitic loss! You make more with less! Less is more Capish? |
#28 | |
Member#: 268354
NESIC
I thought what you were saying is 'Take a stage 2 STi, tune it, check IDCs. Now take that same car, slap on ONLY a header, retune, IDCs will drop'. I just dont see that happening ![]() |
#29 |
Member#: 193757
MWSOC
It would lower the IDCs at the same power output and it'll make more power and probably use less fuel doing it.
#30 | |
Member#: 268354
NESIC
But the header has the potential to flow even more air if you'd like (or can), thus using more total fuel. |
#31 | |
Member#: 193757
MWSOC
#32 |
Member#: 182375
SWIC
Vehicle:08 Sti Wrbm |
Jesus. If only all my arguments were solved so easily lol
#33 |
Member#: 193757
MWSOC
#34 |
Member#: 256898
Tri-State
Vehicle:2011 WRX Limited Flat Black |
#35 |
Member#: 263782
Vehicle:2011 WRX STi Satin White Pearl |
#36 |
Member#: 193757
MWSOC
"Safe" is a little bit of a loaded question to ask a tuner or anyone for that matter! I mean your car is not that old, not sure of the mileage but I'm sure you cared for it. I'm sure you know the rest!!
#37 |
Member#: 263782
Yup i kinda ment le ess likely to blow.
I know a bad tank of gas and the engine can take a poop... Im only @ 15k miles |
#38 |
Member#: 193757
MWSOC
#39 | |
Member#: 18113
MWSOC
Vehicle:01 2.5rs-t brp |
#40 |
Member#: 271525
Vehicle:07 STi 424whp/382wtq GT3076 |
If you make the primaries larger than the exhaust port you'll just slow the gases down.
#41 | |
Member#: 68647
MAIC
Vehicle:07 STI Rotated 35R Jorge Tuned |
#42 |
Member#: 311652
Good power, plan on getting this Swaintech coated when I switch to e85. Pumps, injectors, ect already ordered.
#43 |
Member#: 338211
E. Canada
Vehicle:2011 wrx blue |
jesus lord the price on this thing....what if it cracks....congratz on the power
#44 | |
Member#: 193757
MWSOC
I've cracked other el headers and blown out flex joints in Grimm x and up pipes which they warranted. These are very burly and made from 321 SS so you won't crack them. I'm sure they would warranty them if for some reason you did. |
#45 |
Member#: 313311
MWSOC
Vehicle:2012 WRX 5 Door Plasma Blue |
#46 |
Member#: 198281
MAIC
Vehicle:2005 WRX/STi WRB of course |
^ that's true
