Old 02-03-2013, 10:27 PM   #376
yamahaSHO
Member#: 73932
2005 STi BROtuned
2004 S2000
Originally Posted by casper64 View Post
I am runing to atmosphere with no issues, -20 on the gage at idle.
PCV won't have an effect on the engine vacuum provided you've sealed off the line under the TB.
Old 02-04-2013, 12:01 AM   #377
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
Downfall to vented catch cans is the layer of oil that covers the engine bay at all times. Really sucks cleaning all the time
Old 02-04-2013, 12:29 AM   #378
Nuke209
Member#: 108089
NF Performance
Run the vent under the car. Done
Old 02-04-2013, 01:30 AM   #379
yamahaSHO
Member#: 73932
2005 STi BROtuned
2004 S2000
Or into a can with a filter... Or like I've done in the past; a Gatorade bottle.
Old 02-04-2013, 12:29 PM   #380
C J
Member#: 132587
2006 JrTuned STi
[email protected]
So do I have any negative effects on my engine by venting to atmosphere? If not ill just vent to a cheapo catch can and be done with it.
C J is offline   Reply With Quote
Old 02-04-2013, 12:35 PM   #381
yamahaSHO
Member#: 73932
2005 STi BROtuned
2004 S2000
No.
Old 02-04-2013, 02:54 PM   #382
02rex62
Member#: 215004
02 Rex
I wanna go fast!!!!!
Exactly what I did! Just put a filter on the catch can it'll help prevent oil residue in ur engine bay
02rex62 is offline   Reply With Quote
Old 02-05-2013, 05:53 PM   #383
C J
Member#: 132587
2006 JrTuned STi
[email protected]
Ordered a catch can, ended up going with this...if for some reason I decide I don't really like venting the pcv I am not out a whole lot of money.
Old 02-05-2013, 06:40 PM   #384
Layvon
Member#: 195711
STi 04/05/06/07
Is that threaded on the end for 3/8 npt or something like that?
Old 02-05-2013, 06:43 PM   #385
C J
Member#: 132587
2006 JrTuned STi
[email protected]
yea it is threaded 3/8" NPT on each side. Thinking just a couple 90s with hose barb on the end. I wanted to mount it above the pitch mount but not sure it'll fit after looking in the engine bay.
Old 02-05-2013, 06:58 PM   #386
Layvon
Member#: 195711
STi 04/05/06/07
That's where mine is. Get creative
I hammered out a screw piece of.steel from my old bumper beam and drilled two holes in it, then painted black haha
Old 02-05-2013, 07:08 PM   #387
C J
Member#: 132587
2006 JrTuned STi
[email protected]
Is there a picture in your thread?
Old 02-05-2013, 08:36 PM   #388
Layvon
Member#: 195711
STi 04/05/06/07
Not specifically of that. Ill take one in a sec. Fishing wires through dash at the moment.
Old 02-05-2013, 09:17 PM   #389
Layvon
Member#: 195711
STi 04/05/06/07
Looking at it from up top
Back side of motor
Next time the motor comes out I'd like to upgrade to stainless an lines and go around the back side of motor
Old 02-05-2013, 10:10 PM   #390
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Is that an unwrapped twin scroll up-pipe I see?
Old 02-05-2013, 10:28 PM   #391
Layvon
Member#: 195711
STi 04/05/06/07
Correct!
Old 02-05-2013, 11:33 PM   #392
C J
Member#: 132587
2006 JrTuned STi
[email protected]
Hey thanks Layvon.
Another question for you drag racers out there...
So I am ordering a Clutch Masters FX400 4 puck with hirev pressure plate after Junior suggested it.
My question is what are your thoughts on the lightweight flywheels? I have been reading a few threads and it seems like 99% of the guys who are running a lightweight flywheel seem to say they are difficult to launch? However I have been told that some of these aggressive clutches have release issues due to the heat from a good launch and don't like to release off the stock steel flywheel.
Right now I can launch the car consistently every single time, never bog, never have a problem and I really don't want to get away from that.
Thoughts?
Old 02-06-2013, 12:45 AM   #393
kellygnsd
Member#: 32669
LINK G4 hybrid STi
I ran a 14lb. flywheel in my last iteration on the wrx 5-speed and I have a 12lb. FW on the STi but the STi hasn't been on the road yet. I loved the 14lb'er in the WRX though.
Old 02-06-2013, 09:32 PM   #394
C J
Member#: 132587
2006 JrTuned STi
[email protected]
Put the new wheels/tires on today...not the best fitment but should be good for traction.
Old 02-06-2013, 09:41 PM   #395
Layvon
Member#: 195711
STi 04/05/06/07
RPF1s look good no matter what
Nice clean garage too. My walls seem to be closing in on mine. Need to get rid of some ****.
Old 02-11-2013, 07:24 PM   #396
C J
Member#: 132587
2006 JrTuned STi
[email protected]
Might be a stupid question but are all 04-07 STi flywheels considered a single mass flywheel?
Old 02-11-2013, 08:13 PM   #397
creative wrx
Member#: 141754
04 stock wrx ;)
z31 project, passat dd
Other way around if I'm not mistaken all STi's are dual mass clutches.
creative wrx is offline   Reply With Quote
Old 02-11-2013, 08:23 PM   #398
C J
Member#: 132587
2006 JrTuned STi
[email protected]
From my understanding all 04-07 and probably newer STi's are all single mass flywheels. The older WRXs before 2006 used a dual mass flywheel.
I picked up a sti flywheel years ago just so I would have an extra one to resurface prior to tearing mine apart but to this day have never done a clutch on an STi. Anyways I ordered a clutch today which specified the use of a single mass flywheel and wanted to double check that is what I have. From what I can tell this is a factory STi flywheel...
Old 02-12-2013, 07:14 PM   #399
C J
Member#: 132587
2006 JrTuned STi
[email protected]
So I am going to weld in the new bung for my GM IAT sensor and curious about where you guys recommend placement. I know you want it as close to the throttle body as possible but I am wondering if it is on the turbo side of the intercooler pipe that the sensor might suffer some kind of heat soak? Here is a picture for reference, I might be able to squeeze it into the inside bend of the pipe but does it matter if the sensor is on a radius like that?
Old 02-12-2013, 07:48 PM   #400
Layvon
Member#: 195711
STi 04/05/06/07
Do you retain a functional hood scoop? If so, would it be blowing on it?
It appears that it would be right where the hood scoop pushes air onto, suggesting that it will push air back from the IAT sensor. It is of my opinion you'd be fine.
Edit - I saw the picture on post 9. I think that would be right where the old intercooler would be so I think you'd be good to go.
Also - Did your car require any special ramps to get onto that trailer with out bottoming out? I'm hauling my car to P&L next week and want to make sure to think ahead.
2007/2008 STI = Same R180 ? experts please! Team Scream Transmission (AT/MT) & Driveline 9 05-21-2013 03:02 PM
2006 Forester E85 / Mustang Dyno PoZeR Proven Power Bragging 8 06-29-2011 03:51 PM
FS : 2006 Aspen White STI (Ready for E85 conversion) biker921 Private Vehicle 'For Sale' Classifieds 0 08-08-2010 10:43 AM
Cheap quiet RCA's please? Experts, please contribute. ebeck Car Audio, Video & Security 20 11-29-2004 01:22 PM
