Old 02-11-2013, 10:10 PM   #1
stsdude2
Member#: 307161
2008 wrx
Default Car idle bogs down when coming to a stop.
6/10 times when I come to a stop or I'm in stop and go traffic my idle bogs down to like 500 rpm or less and goes back up. It also bounces between like 750 and 1100 when warming up when it's like a quarter of the way there. And the last weird issue is sometimes when I'm in stop and go traffic and I put the clutch in and hit the brakes, the rpm sticks at like 2k n slowly goes down.
This car has every bolt on and the engine is brand new, 2011 sti block, Cobb pro tuned.
I don't know if I am having a tune issue or if something else is going on with the car.
stsdude2 is offline   Reply With Quote
Old 02-12-2013, 07:28 AM   #2
marcymarc
Member#: 112861
2013 STi sedan
my 2012 does this stock.. i figured it was just the crappy stock tune on it?!?
subscribed!
marcymarc is offline   Reply With Quote
Old 02-12-2013, 05:33 PM   #3
stsdude2
Member#: 307161
2008 wrx
Anyone know anything? I already checked my intake manifold gaskets for leaks and found nothing.
Old 02-12-2013, 05:33 PM   #4
guroove
Member#: 129833
2005 Forester XT
Obsidian Black Pearl
Have your tuner raise the idle by 50 to 100 rpms. Problem solved!
guroove is offline   Reply With Quote
Old 02-12-2013, 05:40 PM   #5
stsdude2
Member#: 307161
2008 wrx
It doesn't solve it if it keeps bogging down to like 500rpm. It shouldn't even do it. It's been adjusted before
Old 02-12-2013, 05:56 PM   #6
nmlittlebigman
Member#: 321409
2003 Big Effing Van
7.3L powerstroke diesel
delete
Last edited by nmlittlebigman; 02-12-2013 at 09:23 PM. Reason: noticed he said new motor
Old 02-12-2013, 06:00 PM   #7
guroove
Member#: 129833
2005 Forester XT
Check alternator output, battery, grounds, etc. A lot of things can cause this actually.
Old 02-12-2013, 08:35 PM   #8
dave07
Member#: 291349
2013 Mustang GT
This. There is an option on the Cobb AP that you can bump up the idle RPMs. I did this and problem solved!
dave07 is offline   Reply With Quote
Old 02-12-2013, 09:11 PM   #9
scoobasaurusrex
Member#: 255114
2007 wrb wrx wagon
93oct vf43 ewg
This. When I got my car, turning the lights on and off, the AC, the radio, etc. would all make the car bog and want to die. PO mangled the wiring on the gaugest that were in the car and it screwed everything up
scoobasaurusrex is offline   Reply With Quote
