Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 02-07-2013, 09:38 PM   #1776
stevejones19
Member#: 275250
2006 WRX
Go FMIC then put it where the TMIC is
stevejones19 is offline   Reply With Quote
Old 02-07-2013, 09:55 PM   #1777
Smurftastic
Member#: 243697
02 | BLOD Founding
Member | TopScoob 031
You know... it's funny you say that... because I used to have a FMIC... but a FMIC on a TD04 with 15/16 PSI is really just kind of... we'll just say laggy.
... maybe the next step in this build is doing a rotated setup... someday.
Smurftastic is offline   Reply With Quote
Old 02-09-2013, 06:36 PM   #1778
Dpwhitehead1
Member#: 139996
2004 IS 300
Originally Posted by Big-Sexy907 View Post
Anyone know where I can find a m10x1.0 IF tee? I can't seem to find one and the vendor referred to in the forums is no longer in business.
This is for linking the rear brakes into the ABS delete I'm working on.
Blammo, found it.
http://www.technafitstore.com/FEAMLE...-p/319-31b.htm
how much of a bitch is it to remove abs?
I'm definitely interested in getting rid of the box and lines under the hood.
Dpwhitehead1 is offline   Reply With Quote
Old 02-12-2013, 04:13 PM   #1779
granny
Member#: 283145
1997 LEGASTi Wagon
Instagram-@grannywagon
Any of you guys with shaved bays daily drive your car? How does the bondo hold up? I would think it would crack pretty fast. Thinking of doing it and using fiber glass filler so it would be a little stronger.
granny is offline   Reply With Quote
Old 02-12-2013, 07:01 PM   #1780
Jackie leggs
Member#: 249794
02 WRX wagon
atomic orange pearl
Why would body filler crack? As long as you use the correct amount and proper surface prep it should last forever.
Jackie leggs is online now   Reply With Quote
Old 02-12-2013, 10:21 PM   #1781
Smurftastic
Member#: 243697
02 | BLOD Founding
I daily drive my car. There is risk of any filler used along the strut column seams cracking.
Old 02-12-2013, 11:20 PM   #1782
03sportwagon
Member#: 252943
2003 wrx sport wagon
I dont know if this has been brought up but how do you move the abs stuff and where do you put it?
03sportwagon is offline   Reply With Quote
Old 02-12-2013, 11:23 PM   #1783
granny
Member#: 283145
1997 LEGASTi Wagon
I am very experenced in collision and repair and never had problems with any of my work cracking but filler can and does crack. I'm more worried about the top of the strut towers. Coilovers aren't easy on anything.
Yeah I think I'm gonna do most of the work with sheet metal and fill in any small improfections with fiber glass filler. That's the strongest way I can think of unless any of you guys have other suggestions.
Old 02-13-2013, 12:23 AM   #1784
Jackie leggs
Member#: 249794
02 WRX wagon
atomic orange pearl
I too am experienced in the automotive collision and repair field. That's why I said use it in moderation aka enough to cover what's needed. The less you use, the less of a chance you have to cracking.
I agree that the area of the strut towers would be likely to see more stresses. I personally would use a metal filler in these areas.
Old 02-13-2013, 10:20 PM   #1785
under0athh51189
Member#: 193959
2001 Lexus IS300
05 Wrx AW 18x9.5 WFC#295
Check out ChaseBays.com for their abs delete Kit. Mine will be here this week along with fender lines, overflow, clutch line, grounding Kit and powersteering Kit. I'll have an install thread up as soon as I do it all.
under0athh51189 is offline   Reply With Quote
Old 02-13-2013, 10:49 PM   #1786
subarutah
Member#: 248428
2006 STI
FROZEN GREY
I heard there was some issues with the chasebays abs delete kit. This was awhile ago though so it might be fixed
subarutah is offline   Reply With Quote
Old 02-13-2013, 11:24 PM   #1787
under0athh51189
Member#: 193959
2001 Lexus IS300
Yeah they fixed it I thought the same.thing but I called and spoke with them and its all fixed. Should be good to go. We'll see when I install mine
Old 02-13-2013, 11:26 PM   #1788
Smurftastic
Member#: 243697
02 | BLOD Founding
Really looking forward to your thread
Old 02-13-2013, 11:51 PM   #1789
seascooby
Member#: 133535
06 limited - mine
ww evo 8 - hers
there were tons of issues with it... i went through the whole ordeal finally just made my own ****.....7 months later
seascooby is offline   Reply With Quote
Old 02-14-2013, 01:12 AM   #1790
Big-Sexy907
Member#: 59057
2004 Impreza, STi.
Yep, building my own instead, way cheaper and I know it'll work.
Big-Sexy907 is offline   Reply With Quote
Old 02-14-2013, 07:18 AM   #1791
under0athh51189
Member#: 193959
2001 Lexus IS300
I guess we'll see when I get mine. It may cost more but its easier and u get get everything u need. I'll post my thread when im done
Old 02-15-2013, 04:40 PM   #1792
under0athh51189
Member#: 193959
2001 Lexus IS300
Stuff just arrived and looks great
Old 02-15-2013, 09:11 PM   #1793
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
How do you know you will get everything you will need if you havent done it yet?
Im with others, buying premade kits for things like this simply limit the ability of the final product to be exactly what you want. You are limited to what ever the thoughts and ideas were of who ever built the kit.
Token-Negro is offline   Reply With Quote
Old 02-15-2013, 09:11 PM   #1794
seascooby
Member#: 133535
06 limited - mine
ww evo 8 - hers
to save you a speed bump...
take that res down to a hardware store and grab some stuff to extend that push rod to the brake pedal. since it's a universal wilwood piece it won't reach even with the pedal down to the floor.
Old 02-19-2013, 01:49 PM   #1795
wrxadam05
Member#: 84070
2015 Fiesta ST - E30
500whp GRB STI
Good luck, LMAO.
wrxadam05 is offline   Reply With Quote
Old 02-19-2013, 03:26 PM   #1796
dub c
Member#: 145069
Keep It Sleazy
Cool, I've been looking at a few Chase Bays products.
Post up your progress.
dub c is offline   Reply With Quote
Old 02-19-2013, 08:40 PM   #1797
under0athh51189
Member#: 193959
2001 Lexus IS300
Will do as soon as I start the install
Old 03-03-2013, 10:41 PM   #1798
Dpwhitehead1
Member#: 139996
2004 IS 300
How's it going?
Also any words yet on deleting the abs from the cars?
Old 03-04-2013, 02:29 PM   #1799
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
Originally Posted by boostdprotegelx View Post
How's it going?
No difference in driving lol i did a few 160mph pulls and the car stopped great. Lol
D Money is offline   Reply With Quote
Old 03-04-2013, 06:31 PM   #1800
Dpwhitehead1
Member#: 139996
2004 IS 300
Loo I meant on how it's done
washed engine bay, now car won't start CEL on pinoy_boy204 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 42 06-08-2010 10:12 AM
spilled oil in engine bay bugeye4life Newbies & FAQs 8 06-03-2010 04:51 PM
07 ABS actuator and all Engine bay lines TraviST185 Suspension/Brakes/Handling 1 04-08-2009 09:38 AM
06 STi attempted wire tuck, polished manifold, samco hoeses, baller custom intake reallyslow Member's Car Gallery 34 06-19-2007 02:11 PM
Wiring TT and keeping engine kill feature sssp Electrical & Lighting 2 08-16-2004 12:58 AM
