Welcome to the North American Subaru Impreza Owners Club Friday March 6, 2015
Old 08-19-2011, 07:00 PM   #1
Pinned
Member#: 152707
Default Where to buy noltec camber/caster plates?
I can't seem to find them anywhere. Performance shock had them for around $100-$150, but they appear to be gone now.
Anyone have a lead on these or a similar design for a reasonable price?
Pinned is offline   Reply With Quote
Old 08-19-2011, 07:15 PM   #2
fastwrx25
Member#: 126441
03 bugeye
you are right...they aren't on ebay anymore....that sucks.
they were so freaking cheap.
Old 08-20-2011, 02:38 AM   #3
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
They were cheap because Noltec is gone/doesn't make them anymore. There's no more to be had and as far as I know, no one really makes something similar.
Old 08-20-2011, 02:09 PM   #4
Back Road Runner
Member#: 60082
2004 Forester STI
They are on eBay, but they are an on-again, off-again type of item. You'll see a bunch of sets show up for a couple months. Then you'll see it completely void of any for a month or two. It's weird. However, eBay is the only place they show up, so that's the only place you can look for them. If you can exercise patience, there will be more up later.
Old 08-20-2011, 03:09 PM   #5
nhat
Member#: 140163
03 STi
hellaflunctional
any of you guys know where to find replacement bearings? i've got a pair of noltecs that need new bearings so i can sell them
if anybody wants them as is, pm me.
Old 08-20-2011, 05:04 PM   #6
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
I looked at this. They're a weird-assed non-standard bearing size. I managed to find one company in China that lists that size (obviously where the Noltec bearings came from). Minimum buy was something like 100,000 bearings and I get 5 bearing-spam emails a day from china now.
Old 08-20-2011, 05:09 PM   #7
nhat
Member#: 140163
03 STi
hellaflunctional
fantastic news. so i guess they're going in the scrap heap... unless someone wants them.
Old 08-20-2011, 06:32 PM   #8
Pinned
Member#: 152707
I may be interested, I'd have to look into the bearing thing a bit.
Williaty, do you have any info on the particular size?
Old 08-20-2011, 09:21 PM   #9
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
No, I measured it almost two years ago now. All I remember was that it was a modified version of a dash 12 sized bearing that had an unusual OD and thickness.
Old 08-21-2011, 04:22 AM   #10
Pinned
Member#: 152707
Gotcha, well thanks for the info so far. If it was a simple matter of turning the outer housing of the bearing down on a lathe I wouldn't have much trouble getting that done. Any idea if it would be possible?
Maybe I'll have to look into some other camber plates, but these seemed like by far the best option for maximum camber and caster in one piece.
Old 08-21-2011, 04:34 AM   #11
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
I remember that I thought about having the outer race turned down and there was some reason that I didn't think it'd work. I don't remember if the race ended up too thin or what.
If you have access to metalworking equipment, your actual best option would be to buy the GTWorx plates and then "copy" the top plate except place the sliding grooves for the carrier farther aft in the plate. So your camber adjustment would be just like the GTWorx plates themselves but you'd get extra caster from placing the carrier farther aft in the plate.
Old 09-02-2011, 10:56 PM   #12
Pinned
Member#: 152707
Interesting thought. I have friends with access to machinery, but I don't have the skill to use any of it. So I don't think I could ask any of them to machine me something that complex during their down time at work.
Are there any other options for affordable camber plates or were the noltecs really it? There are some super cheap plates on ebay, some even appear to be noltec-esque in design. Are these simply a bad idea?
Old 09-03-2011, 12:20 AM   #13
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Yeah, there's several details of a camber plate that are difficult to get right. I'd be HUGELY suspicious of anything under $300 and $400 is a more realistic price point.
Old 09-03-2011, 12:31 AM   #14
OK Houston
we have an Uncle
.............sold
Uncle Scotty is online now   Reply With Quote
Old 09-03-2011, 01:19 AM   #15
OK Houston
we have an Uncle
PM'd you
Old 09-04-2011, 04:04 AM   #16
Pinned
Member#: 152707
I have a set of NEW IN BOX 'street' plates that I'd sell.....pm me
PM sent.
Old 09-04-2011, 09:22 PM   #17
Pinned
Member#: 152707
Well, I should be receiving some noltec camber plates courtesy of Uncle Scotty. Thanks man!
Old 02-12-2013, 11:48 AM   #18
mikescar
Member#: 214832
If anyone cares, I have a set of NOLTEC Camber Caster plates and have found a replacement bearing at www.vbx.com GE20ES-2RS is the part number.
20mm x30mm x 16mm are the dimensions that I used.
mikescar is offline   Reply With Quote
Old 02-12-2013, 05:27 PM   #19
Pinned
Member#: 152707
Good info. I may have to order some preemptively, I like these camber plates a lot so it would be good to have spares.
Old 02-13-2013, 01:10 AM   #20
OK Houston
we have an Uncle
your link is bad....it points to a political website
Old 02-13-2013, 01:14 AM   #21
OK Houston
we have an Uncle
http://www.vxb.com/ballbearings.html...Fad_QgodmXQA1w
http://www.vxb.com/page/bearings/PROD/kit643
the above links seem to work and are correct if the provided part number is correct
Anyone want some Noltec camber/caster plates? DrBiggly South East Region Forum 19 06-09-2004 02:17 PM
Noltec camber/caster plates - what's wrong with this picture? zosima Brakes, Steering & Suspension 8 05-07-2004 12:46 PM
Noltec camber/caster plates. BzY Private 'For Sale' Classifieds 2 04-22-2004 03:43 AM
NJ: Noltec camber caster plates Cosworth Private 'For Sale' Classifieds 3 03-15-2004 12:26 PM
wtb: Noltec camber/caster plates EZar Private 'Wanted' Classifieds 0 09-16-2003 05:17 PM
