Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 01-11-2013, 10:03 AM   #376
oharao2
Member#: 229802
2008 WRX STI
Originally Posted by Bobert540 View Post
Any pics or install tips on how to use stock bracket?
First i compared where the brackets sat on the factory HU. I wanted to make sure it sat flush or close to flush on the Bezel like the OEM HU. I forget which holes on the Pioneer 4400 i ended up using but when attaching the brackets the top guides sit flush on the top of the Pioneer 4400 as they had on the OEM. And after moving the brackets around a few times they ended up just about spot on to where they had resided on the OEM HU. I think if you use any other bolt location on the Pioneer 4400 the HU will end up hitting the Scosche Frame or the JDM/TomTom Bezel.
After the allignment I just unscrew the bolted on harness from the factory HU. And attached it to the 4400 using the longer screws that come in the box with the Pioneer 4400. There are two sets of bolts in the 4400's box and I used the ones that looked just like the factory ones (but longer). (the factory bolts dont work. I tried) After that it just bolts in using the screws that had held the OEM HU in place.
oharao2 is offline   Reply With Quote
Old 01-11-2013, 11:46 AM   #377
outnspace
Member#: 340609
Default Pioneer AVH-P4400BH with Factory SubWoofer Upgrade
I just got this HU (Pioneer AVH-P4400BH) and am really looking forward to putting it in using all the great info you guys have posted here.
The 2012 Impreza I have came with all speaker upgrades, including the Tweeters, Door Speakers, and Subwoofer. It uses the Factory CM621UB Head Unit.
The speakers seem fairly decent and I'd like to be able to keep all of them for the new Pioneer HU.
Has anyone had any success or pointers in how to hook up the SubWoofer to the Pioneer? It seems to be a non-amped woofer. The Pioneer instructions say that if you use a 2 Ohm (70W) sub, that you should not hook up the rear speakers and instead use only two wires from those to hook up the Sub. But this doesn't seem right because the factory Head Unit drives both the rear speakers and the Sub.
Is there a way to hook up the Sub from my Pioneer so that I can keep all four door speakers and the sub? I would like to do this without installing an Amp.
Any suggestions or advice are much appreciated!
outnspace is offline   Reply With Quote
Old 01-11-2013, 12:37 PM   #378
oharao2
Member#: 229802
2008 WRX STI
There are sub rca's on the back of the hu. They have a SW etched next to it. There are three sets of rca outputs on the left hand side and the sub outputs are the bottom set.
Old 01-11-2013, 02:44 PM   #379
outnspace
Member#: 340609
Do you know if the factory SubWoofer has RCA plugs that go into this output? I'm looking at the install document for that
(link here: http://techinfo.subaru.com/proxy/663...H630SFJ000.pdf)
But I don't see anything connecting to the SubWoofer. Do I need to make an RCA adapter coming from the sub that plugs into those HU plugs?
thanks!
Old 01-11-2013, 04:02 PM   #380
oharao2
Member#: 229802
2008 WRX STI
thanks!
Aw shoot. Yeah i think you have to get a special harness for the factory hook up. I should have read your post more carefully. Sorry I think if you pm SVXdc (nasioc name) David Carter (real name) or email him (its on the site i pasted below) he can help you out.
Here is his website http://ae64.com/Ordering.htm
Hes a tad slow to reply but hes there and he gets you out your stuff promptly. Not that i thought was slow but some people have wondered if he still is out there.
Old 01-11-2013, 05:29 PM   #381
outnspace
Member#: 340609
Just heard back from him. For anyone else with this question, the answer is to use his 16-pin adapter, which plugs into factory on one side and has RCA jacks on the other for plugging into the HU RCA jacks. He can also add wires in that adapter for the parking brake and reverse signals, so it makes it very easy to hook up to your new HU.
That adapter along with the 20-pin adapter make it an easy hookup. Of course you'll have to follow the directions, but it is not too difficult.
I bought all the cables I needed from him and I highly recommend him to anyone else taking this on. He's been extremely helpful all along the way.
Old 01-11-2013, 05:58 PM   #382
nightdown fox
Member#: 309636
2015 STI LE
WRB on Gold!
^this, just bought stuff from him today for this unit. Highly recommend him!
nightdown fox is offline   Reply With Quote
Old 01-11-2013, 07:24 PM   #383
RockyMtnGT
Member#: 127953
2016 STI Limited
Lapis Blue
Here's a shot of my Radio with the stock bracket on it. And one of it installed with the 'jdm' trim. While it was working at least...
RockyMtnGT is offline   Reply With Quote
Old 01-11-2013, 11:39 PM   #384
oharao2
Member#: 229802
2008 WRX STI
Im pretty sure those are the same mount pts on the 4400 i used for my install.
Old 01-12-2013, 04:19 AM   #385
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
(link here: [Subaru P/N H630SFJ000 -- Impreza 5-Door 10" Powered Subwoofer, made by Kicker])
thanks!
outnspace's Subwoofer is the new one made by Kicker for Subaru. It has a built-in amp, and a T-harness that taps the front speaker channels from the HU. Connection-wise, it's very similar to Subaru's older under-seat subs. To use it with an aftermarket HU, your only option is to connect it the same way -- inserted between the car's factory radio harness and the power/speaker harness that connects to your HU. See more information in this post (includes a link to a long thread on IWSTI that has more info and pictures about the Kicker sub).
My 16-pin harness is to retain use of your car's factory 3.5mm stereo aux jack with an aftermarket HU. The parking brake and reverse gear signals are only present on the factory aux harness in 2012-up Imprezas (not WRX or STI yet), Crosstreks, and certain 2011-up Foresters.
SVXdc is offline   Reply With Quote
Old 01-15-2013, 01:50 PM   #386
RockyMtnGT
Member#: 127953
2016 STI Limited
Lapis Blue
Whelp my AVH-P4400 just flat died on me driving home tonight. The buttons on the front still light up, but the screen will not come on and the unit itself beeps faintly twice every few seconds like some kind of error code??
I pulled it completely out and checked all the wires, which I soldered and shrink wrapped myself. Checked the fuses as well but no dice- it won't do anything other than light up and beep at me. I am completely at a loss?
I can't find a reference for these units 'beeping' anywhere, not even in the manual. Unit has been flawless until today...Anyone have any ideas on what else it might be?
I just had to replace our main TV in the house for a couple thousand bucks so this is not good timing at all!
TIA!
Just an update to this- It's officially dead. I had it bench tested at CarToys...So I popped the stocker back in for now. Man it sounds like hell. I tweaked the factory underseat sub's gain UP a bit which helped somewhat...
I'm going to submit a warranty claim and then sell it cheap so keep an eye out if your interested - haha.
I'm going to wait for the AVIC-x950bt to be available and pop that in. To be honest I missed the Navi I had in my AVIC-x930 and the screen res on the 4400 was lacking.
Finally the iOS6 functionality issues with the 4400 were killing me.
Hopefully SVXDC will have a harness for me when I get it (I am guessing the 4400 harness he sent me won't work on the 950)
Old 01-15-2013, 03:07 PM   #387
turkey928
Member#: 305127
2012 WRX Sedan
Sorry to hear about this but glad you're not too upset! I'm just waiting on remaining parts before I can install my 4400 (hopefully with no problems). I already have the harness and ASWC from SVXdc and am just waiting for the bypass and JDM bezel.
Anyhow, not sure which stock HU you have but if you haven't seen it already, check out this thread regarding some tweaks that can be made. Might help a bit while you have it in: http://forums.nasioc.com/forums/show....php?t=2317060
turkey928 is offline   Reply With Quote
Old 02-07-2013, 02:00 PM   #388
yudangorgor
Member#: 151107
do I reuse the stock mounting bracket with the new HU? i have a jdm bezel
yudangorgor is offline   Reply With Quote
Old 02-07-2013, 04:30 PM   #389
RockyMtnGT
Member#: 127953
2016 STI Limited
Lapis Blue
Yes that's what I did.
avh 5500bhs and Focal speaks are going in this weekend
Old 02-07-2013, 11:54 PM   #390
yudangorgor
Member#: 151107
ok one more question guys.. in preparation for my first audio install
do i simply just slide the wires into these tiny holes or what do i do to secure them in place?
Old 02-08-2013, 02:13 AM   #391
freddyo_0
Member#: 339277
2011 WRX STI Limited
You would be connecting the 20 pin harness (your radio) to that harness (car) connector.
freddyo_0 is offline   Reply With Quote
Old 02-08-2013, 04:36 AM   #392
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
No. You need to buy an aftermarket harness. Then solder or crimp that to the harness that comes with your new head unit. See this post (post #18 from this same thread).
Old 02-08-2013, 12:35 PM   #393
ea126405
Member#: 317032
Please take this post constructively, as I don't mean it as a bash. It might be a good idea for you to have some on-site help during the installation. I mention this based upon the questions you are asking. Although, this is not a super complicated upgrade, you want to be successful and not cause unwanted problems with your wiring/electronics.
ea126405 is offline   Reply With Quote
Old 02-08-2013, 02:03 PM   #394
doubleurx
Member#: 64024
03 996 TT, 964 C4
salt and pepper
I just had the 5500bhs, alpine V70 amp, Alpine Type R's and a Jlw3v3 in an AI enclosure installed. Amazing sound, still figuring out the head unit, but so far I am very pleased. Installer was great, they pulled all new wire to the speakers and maintained the stock location for the cable, usb and dig audio. They also got all my steering wheel functions working perfectly.
doubleurx is offline   Reply With Quote
Old 02-13-2013, 03:20 AM   #395
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
I'm 40 and have been doing this stuff since I was 13.. I agree with you. He should support his local stereo shop and give them some business.
BWX is offline   Reply With Quote
Old 02-13-2013, 02:32 PM   #396
doubleurx
Member#: 64024
03 996 TT, 964 C4
salt and pepper
That's what I did. Dropped the car off at our local little shop and they did an awesome install with no issues at all. Well worth the money as far as I am concerned.
Old 02-13-2013, 02:48 PM   #397
yudangorgor
Member#: 151107
there's something about DIY's that give you a sense of satisfaction after it's done and complete.
Old 02-13-2013, 04:26 PM   #398
freddyo_0
Member#: 339277
As long as your confident and practice before hand. Just do it right and research, extensively.
Old 02-16-2013, 07:32 PM   #399
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
Believe me I know, but your question leads me to believe you shouldn't be installing your head unit into your car, and should let a pro do it.. but hey, it is your car. Just read a lot before hand, I guess..
Old 02-20-2013, 09:54 AM   #400
Frankie07
Member#: 347537
looks sick. i wanna do that to my 07 when i get some cash just got the car so im broke now hahah
Frankie07 is offline   Reply With Quote
Clutch "clicking" in 2012 wrx STIDAWG Transmission (AT/MT) & Driveline 7 03-17-2013 12:22 AM
Where to ground in 2012 wrx hatch? slowhat Car Audio, Video & Security 3 02-25-2012 12:35 AM
pioneer avh-p4000 install in 06sti nation1979 Car Audio, Video & Security 25 02-26-2009 02:47 AM
Pictures of Hid's installed in '02 WRX :) paultg New England Impreza Club Forum -- NESIC 7 12-16-2001 05:22 PM
Found out a short throw shifter wasn't installed in my WRX.. cout Bay Area Impreza Club Forum -- BAIC 5 05-03-2001 06:59 PM
