Old 02-12-2013, 05:22 PM   #1
KornShaDoW097
Member#: 313618
2004 WRX
Does anyone know of what parts I need from the stock intake? I have plenty of sites that sell them by the piece but What is the minimum I need to be able to properly set up aftermarket injectors and after k&n intake?
http://www.ezsubaruparts.com/parts/2...gramCallOut=14
Which of those pieces do I need?
Also does anyone own a stock intake I can buy or borrow?? I'll pay shipping!
KornShaDoW097 is offline   Reply With Quote
Old 02-12-2013, 05:30 PM   #2
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
Um, the factory MAF curve is pretty well set up for the stock system. Taking off pretty much any of the parts changes the scaling. Your question does not really make sense.
The common mod of taking off the silencer in the fender changes the MAF curve quite a bit on the low end.
lukeskywrx is offline   Reply With Quote
Old 02-13-2013, 08:19 AM   #3
quazimoto
Member#: 70395
You do not need the stock intake to calibrate the MAF. What exactly is the issue?
Old 05-26-2013, 10:58 PM   #4
KornShaDoW097
Member#: 313618
2004 WRX
Youre asking why?? isnt it obvious?..I'm going to calibrate new larger injectors and after my aftermarket intake.
Old 05-27-2013, 07:47 AM   #5
quazimoto
Member#: 70395
I asked because obviously it is not obvious what your doing. If the aftermarket intake is already on and calibrated properly there is no need to go back to the stock airbox just to do injectors. I't's not like the stock MAF scaling is spot on anyways.
Old 05-28-2013, 03:20 PM   #6
KornShaDoW097
Member#: 313618
2004 WRX
I bought the car with no stock injectors or intake. So I need to calibrate both.
Which parts are needed to be the correct maf scaling? Do I literally need the entire thing? Or what parts can I get away with to help calibrate injectors?
Because that stock intake is expensive
Old 05-28-2013, 06:17 PM   #7
quazimoto
Member#: 70395
If the injectors came with a flow sheet with latencies you can use that to get the injectors close. You can generally get a used stock airbox for around $40-$50. You will need the after MAF tube as well.
Old 05-28-2013, 11:50 PM   #8
wrx1392
Member#: 342331
2003 wrx
blue
1,2,9 are the biggies ,im sure you can but these used.why not just get the car tuned with whats on there now?
wrx1392 is offline   Reply With Quote
Old 05-29-2013, 12:22 AM   #9
KornShaDoW097
Member#: 313618
2004 WRX
I'm getting more open to the idea every day but the $500 price is something I can't afford right now and I live as south as you can get in Cali so it would be a mission to go get it tuned.
I'm leaning towards hub tuning with church though, anyone got hookups?
Old 05-29-2013, 12:23 AM   #10
KornShaDoW097
Member#: 313618
2004 WRX
I see thanks. Good thing I haven't changed it yet... Then again it's melted at the turbo inlet
