02-13-2013, 09:51 AM | #1 |
Member#: 337163
Vehicle:2002 Subaru WRX Blue |
5 speed, what years work...
What year WRXs can I take a trans from that would be a direct swap for my 02 WRX 5speed POS. My gears broke amongst other things.
02-13-2013, 10:15 AM | #2 |
Member#: 218242
Vehicle:2006 STI Aspen White |
I believe any 02-07 wrx 5 speed will be a direct replacement. With that said the newer the trans the stronger the gears are. For example a 05 wrx trans will have stronger gears than a 02 wrx trans.
02-13-2013, 10:36 AM | #3 |
Member#: 110078
Vehicle:02 Bugeye JDM STi OBP BLACK |
02 and 03 I believe will swap in with your existing axles. 04 and 05 use different axles, you can still swap it but you'll need the matching axles. There are other differences on the newer models, 06 forward, that can be overcome to install on your 02. That said, you posted in the wrong section, there is a transmission dedicated section, search there.
02-13-2013, 10:36 AM | #4 |
Member#: 285270
Vehicle:03 WRX PSM |
^WRONG!
Both of you need to read the TRANSMISSION FAQ's! Hint: All 5MT's are NOT created equally! Might want to learn about the different center diff ratio. Happy reading! Edit: you beat me rodman :-/ |
02-13-2013, 11:48 AM | #5 |
Member#: 149890
Vehicle:09 Forester Green |
the 02-05 are swappable. The 06-07 needs more work. Also, the axle stubs change mid 03.
Read the FAQ as there a bunch of little things and if you are in there, why not address other issues |
02-14-2013, 12:33 AM | #6 | |
Vehicle:OK buy Nates beans westcoastroasting.com |
FULL STOP dont listen to any of the idiots here you want STRAIGHT SWAP ya want any 02-05 wrx trans....that is IT the axles...taht is another story.....the mid 03 and up cars used differnt axles than the early bugeyes so if ya get one of those ya need the matching axles |
02-14-2013, 07:08 PM | #7 |
Member#: 337163
Getting a used 05 trans with 78k miles tomorrow and new axles so all should be well soon.
02-17-2013, 08:38 AM | #8 |
Member#: 337163
Is there any major difference as far as internals on the 05 as opposed to the 02 besides wider gears?
02-18-2013, 11:39 PM | #9 |
