Welcome to the North American Subaru Impreza Owners Club Sunday May 3, 2015
Old 02-13-2013, 07:30 AM   #51
Shinji Hirako
Member#: 301002
08 Impreza Wrx
Originally Posted by corvallisbattery View Post
On a cold engine those numbers are decent. On a hot engine with fuel cut and WOT I'd say maybe a bad tester. If you tested it twice with two different tools and got the same results I'd say low compression. But fact is you have a good grouping with low cylinder variance. About %8. Well within spec.
The engine was cold. It was about 34 degrees last night. I used the same tool, cranked over for a 7 count. For 3 times per cylinder.
Shinji Hirako is offline   Reply With Quote
Old 02-13-2013, 11:17 AM   #52
corvallisbattery
Member#: 333030
'05 WRX
5 count and once per cylinder is all that is needed. Warm the engine up and perform test again if you want reassurance, otherwise your numbers look OK... most importantly they are consistent.
corvallisbattery is offline   Reply With Quote
Old 02-13-2013, 11:32 AM   #53
Shinji Hirako
Member#: 301002
08 Impreza Wrx
THANKS CB. I will reassemble and try this again tonight given that it doesn't snow.
Old 02-10-2015, 02:14 PM   #54
DanWojewoda
Member#: 193997
2004 Impreza WRX
What was the outcome of this? Was there smoke from the oil filler tube? Just curious. Thank you.
DanWojewoda is offline   Reply With Quote
