Old 02-05-2013, 01:31 PM   #151
SW21MR2
Member#: 60135
2005 Kona Stink-E
I suspect you plan on doing what you're going to do OP regardless what people say on this thread.
SW21MR2 is offline   Reply With Quote
Old 02-05-2013, 02:23 PM   #152
Isshinryu28
Member#: 336091
Originally Posted by Elusivellama View Post
And then you woke up.
But hey, you have a collection of flat-brims that you can put on backwards. I'd pick a red one (25hp) and make sure that you cultivate that sneering bro-look, otherwise other bros will not take you seriously. Bro.
Hahaha then your mom gt out my bed Internet tough guy
Isshinryu28 is offline   Reply With Quote
Old 02-05-2013, 02:24 PM   #153
Isshinryu28
Member#: 336091
Then get out lol
Old 02-05-2013, 02:25 PM   #154
Isshinryu28
Member#: 336091
Originally Posted by SW21MR2 View Post
This should do it.
Lol no doubt little out of my budget range
Old 02-05-2013, 02:26 PM   #155
Isshinryu28
Member#: 336091
I'm going to do what my tuner suggest in the end came here for advice and get some ideas of my own. Whole purpose of having a forum
Old 02-05-2013, 02:42 PM   #156
SW21MR2
Member#: 60135
2005 Kona Stink-E
You didn't like my Stealth Bomber E-bike suggestion?
Old 02-05-2013, 02:47 PM   #157
Jack
Add Lightness
Member#: 13699
2004 Outback, 13 XV
(From General)
Sell WRX
Buy fox body mustang $3k
Buy Ford crate 514 new $11k
Install Ford 9" 12 bolt $2k
Install your choice of supercharger $3k
Install nox $1k
total $20k (so you only need to get $10k for your WRX)
Run mid 7's.
Old 02-05-2013, 02:48 PM   #158
woody06967
Member#: 110330
2007 STI Limited
2016 Golf R MT
To answer your question, 10 grand will go a long way, especially if you spend smart (some used parts, group buys, etc.)
woody06967 is offline   Reply With Quote
Old 02-05-2013, 03:30 PM   #159
Isshinryu28
Member#: 336091
Naw thought that was good lol
Old 02-05-2013, 03:44 PM   #160
cosseywrx
Member#: 276443
2005 2.1 stroker WRX
In parts and labor i spent about 12k on my car. Winter tuned 16lbs at 300whp. Built 2.1stroker and a greddy 18g. Lots of other mods. Stock 100k tranny to. Wrx 5spd. Summer time boost will go up and car may get dyno.
cosseywrx is offline   Reply With Quote
Old 02-13-2013, 03:31 AM   #161
Isshinryu28
Member#: 336091
Update final qoute in
All forged internals on wrx motor
Process west tmic
Fuel pump
Injectors
20g turbo
Tgv delete
Tuning
Labor
Kartboy shifter with bushings
8200 dollars not bad only weak link left would be stock tranny
Old 02-13-2013, 04:04 AM   #162
cosseywrx
Member#: 276443
My stock tranny at 100k is amazing surprisingly.
Idk uf you had a big tmic but its usually in the way of everything. I did this and it lasted like 3 days then went fmic and no lag change
Old 02-13-2013, 07:57 AM   #163
meat_WRX
Member#: 96919
2004 sti
black
Process west tmic
Fuel pump
Injectors
20g turbo
Tgv delete
Tuning
Labor
I highlighted the stuff you over paid on and should not of bought. Did you get the at least buy the process west used? Should of bought a used Turbo XS TMIC or waited for the new grimmspeed TMIC .. Short shifter is a super waste of money.
If you bought both new, you probably could of save a grand alone.
And i love it when peopel say "all forgd internals"..... what does that mean? what did you really buy? you bought a forged crank?
meat_WRX is offline   Reply With Quote
Old 02-13-2013, 08:10 AM   #164
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
The kartboy shifter is a fairly inexpensive upgrade, and it makes worlds of difference.
340Duster is offline   Reply With Quote
Old 02-13-2013, 11:19 AM   #165
meat_WRX
Member#: 96919
2004 sti
black
I've never had a problem shifting an oem shifter. When you're on a budget, that could be left out.
and it looks like he might of paid for install. so that's a real waste.
Old 02-13-2013, 01:20 PM   #166
jpatt006
Member#: 289470
2010 Forester XT
No Turbo XS TMIC available for the 2011...
jpatt006 is offline   Reply With Quote
Old 09-17-2013, 03:23 PM   #167
Isshinryu28
Member#: 336091
Went with a spearco and build is done fOr budgeted amount put down 407hp/383trq
So to answer 10k is enough now to build tranny with ppg or Sti swap mmmm
Old 09-17-2013, 03:35 PM   #168
Jack
Add Lightness
Member#: 13699
2004 Outback, 13 XV
(From General)
There was a used STi 6 speed in the nesic f/s classifieds for like $2k. It's Mike460 selling it. Lots of us have bought parts from him.
Old 09-17-2013, 03:51 PM   #169
Masta Splint
Member#: 189211
2005 18g WRX wagon
$10k is def. more then enough to achieve 400whp, but you need to realize your 5 speed WRX tranny can not hold anywhere near that amount of power. So befor eyou do anything else you need to go buy and have installed a full STi 6 speed setup, I mean everything to not just the trans but the whole drivetrain. The STi drivetrain is a billion times stronger and will easily hold the power you want. Only thing is to buy all the parts for a STi drivetrain and have them installed your gonna end up spending prob about half your budget right there since they normally go used for around $4k, then youll need to pay for install as well. After you do that your gonna have to buy new wheels because youll have a STi bolt pattern which is 5x114.3 not 5x100 unless you get a conversion hub. So if you get wheels thats another decent chunk of change, if not and you have wheels that will work or go with the conversion hubs to be able to run your wrx wheels still that will save you some cash. Now with prob the $4k youll have left over since like I said that drivetrain is gonna set u way back you can start looking at power stuff. For quick power I would do a 20g turbo (its large enough to achieve the 400whp your after but small enough that it will spool quick and youll be able to almost max out the power on it leaving you with little to no lag), FMIC, 1000cc injectors, bigger fuel pump (like a walboro 255 or something similar) and a pro-tune. If you have any money left over which I think you will you may want to look into brakes because having a ton of power means nothing if you cant stop.
Masta Splint is offline   Reply With Quote
Old 09-17-2013, 04:20 PM   #170
jedurham
Member#: 364392
Really? My buddy's Rex puts out 400 whp and is on the stock 5 speed and it's holding up just fine. I can see the use in trading it out, but I'm not sure it's a necessity..... Please correct me if I'm wrong as I would have to do the same switch when I get mine!
jedurham is offline   Reply With Quote
Old 09-17-2013, 04:34 PM   #171
mrkyle3
Member#: 272675
2004 Miata
I do know the newer 5 speeds are much stouter than the old ones. There's still residual cautioning going on from the reputation of older 5 speeds. They definitely don't hold as much as the 6 speeds though, and I'm not really sure what their "limit" is.
Old 09-17-2013, 08:05 PM   #172
Isshinryu28
Member#: 336091
What do standard ppg setups usually hold up to
Old 09-17-2013, 08:18 PM   #173
mrkyle3
Member#: 272675
2004 Miata
More than you could possibly make with these engines. Probably not true, but A LOT.
Old 09-18-2013, 11:23 PM   #174
amalgrover
Member#: 183480
2011 Audi A3 Quattro
2009 Forester XT
^ not necessarily true...trust me, went through 3 sets on a daily driven Subaru. They break more than people think. Not saying they are weak, but just saying that they are FAR from bulletproof
Old 09-19-2013, 12:42 AM   #175
Dat8687
Member#: 243261
2004 WRX
Java black pearl
I don't think its possible.. Unless your ONLY spending money on power mods and no other mods.
Dat8687 is offline   Reply With Quote
