Old 08-17-2012, 10:19 PM   #1
acmeinc
Member#: 220258
2005 WRX
Default Help with odd turbo sound
Can anyone discern this sound which seems to be turbo related?
https://docs.google.com/open?id=0B0I...jRVMDFtOE5KNWc
Prior to getting some work down (head gaskets), my car was not making this sound. Now, any revs above ~4k produce this elephant trunk type sound. The normal turbo sound is hidden underneath, and can be heard while driving. This is some other sound layered on it. Any ideas?
It may be hard to hear, listen hard betwen 8 and 9 second mark, that is when it is most prominent. I'm also gonna try to get a better clip soon.
EDIT: here's a public link, http://pwnspeak.com/turbosound.mpg
acmeinc is offline   Reply With Quote
Old 08-17-2012, 10:36 PM   #2
04reddragon
Member#: 216553
2006 wrx sti
gray
link not working? i cant open it up when i click on it
04reddragon is offline   Reply With Quote
Old 08-17-2012, 11:04 PM   #3
JerseyDubbin
Member#: 260054
2004 AW WRX Wagon
VF43, Opensource Tune
i listened and i really can't discern much from it. I believe you have to logged into gmail (or just google in general) to hear it.
JerseyDubbin is offline   Reply With Quote
Old 08-17-2012, 11:14 PM   #4
alx8283
Member#: 225024
2002 wrx
The link didn't work for me, but from your description it sounds like a boost leak. Check your bpv --> tmic connection.
alx8283 is offline   Reply With Quote
Old 08-17-2012, 11:17 PM   #5
04reddragon
Member#: 216553
2006 wrx sti
gray
agree i think its a leak
Old 08-18-2012, 08:50 PM   #6
acmeinc
Member#: 220258
2005 WRX
Thanks for the input. I'll have my mechanic take off the BPV to inspect it. Anything particular to look for? The TMIC nor the BPV were touched in the shop so I'm unsure how this could be the problem...but I'll check.
Our smoker is broken, else we would have ran that through. But, if there was a leak, wouldn't I be getting signficantly less boost? I'm getting almost exactly 13.5 psi.
I'll see if I can get a better sound clip if the BPV doesn't do it. And I edited the first post to include a public link.
Old 10-30-2012, 11:04 PM   #7
acmeinc
Member#: 220258
2005 WRX
I believe I figured out the sound. The noise resembles that of a bad bearing the center diff. A local WRX owner pointed this out and reading forum posts tend to support this.
Old 02-13-2013, 01:31 PM   #8
acmeinc
Member#: 220258
2005 WRX
I am still yet to confirm the diff is the actual issue. But, I replaced my clutch recently, and the sound is still evident.
Any idea how long I can go with this sound before I start causing major damage? Again, the sound only creeps up under load. Normal acceleration is fairly silent.
