Old 02-13-2013, 01:28 PM   #26
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
There has got to be more info and mods to the motor! Cams and head work, EWG. It's still way to high of HP for a VF. The power curves look like the right shape and rpm's on E85 for a VF but the numbers just don't jive even with a stock 07 STI making 250 on your corrected dyno. I think your cf on this is way off.
I know you can make a lot of torque with the VF and early. I made 450 WTQ at 3200 on the PnL dyno which is rated at 230 WHP for a stock STI. The PnL Dynojet seems to be right about where the automotive industry rating is for crank and wheel HP.
Old 02-13-2013, 01:36 PM   #27
Shayhan27
Member#: 205906
05 WRX
Originally Posted by Equilibrium Tuning View Post
And FWIW, I also believe these numbers are high just as I believe other Dynocom's and Dynojet's are high. This dyno is now the moon dyno just like all the others. But again, who cares about the numbers? Look at the baselines, the shapes of the curves, and the trap speeds to decide what you think about the tuning. This car with this power would trap around 117mph.
-- Ed
I had a long elobarte response to this but I have decided to cliff note it.
Dyno numbers are cool, but they done make your schwantz bigger.
I personally think 1/4 mile E.T.'s really tell the true story.
I do however want to say GREAT NUMBERS unfortunately I have to add a but which is I would be interesated to see what it does in the quarter mile.
Shayhan27 is offline   Reply With Quote
Old 02-13-2013, 03:34 PM   #28
wrxlaunch
Member#: 181298
Kinda injectors?
Old 02-13-2013, 03:39 PM   #29
thorne
Member#: 130063
Silb
Honestly, I'm wiating to hear about how they logged boost. If they say stock ecu I bet anything the car was running more then 23, It might be possible to high 500 ftlbs of tq if you spiked 28psi??? not sure I've never tried
thorne is offline   Reply With Quote
Old 02-13-2013, 03:53 PM   #30
Kojak77
Member#: 151766
2007 STi
Originally Posted by CTSparky View Post
I'm sorry but these numbers must be bogus. The numbers will be nowhere near what a 1/4 mile pass would show.
No offense meant to the shop at all but these numbers are not in line with the rest of the USA.
What were your numbers on E85? I thought you were up there?
Kojak77 is offline   Reply With Quote
Old 02-13-2013, 04:07 PM   #31
thorne
Member#: 130063
Silb
Kojak, I've tuned bunches of e85 STg2 and 2+ cars
wtq415-440(Highest I've seen but stopped st 24.5-25psi) 20+ degrees of timing 11.5 Gas AFR
whp340-370awhp ~26degrees of timing
Old 02-13-2013, 04:14 PM   #32
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
Originally Posted by thorne View Post
Ummm, I'm not sure where to start...
I'd like to see the map for this car. I find it hard to believe a VF series turbo could hit that much HP or TQ at that PSI level. To hit 430+tq/365whp on a e85 STi i was running 24 psi and allot of timing. I've tuned TONS of e85 cars. On the dynojet we have typically make 420+awtq 350+awhp.
How did you log the boost? If you used the stock ecu do you have a upgraded MAP? Maybe your running WAY more boost? I'm just perplexed
Like 16 up to 29 for timing. I looked at the turbo and it was a vf43. I can't say it didn't have a bigger wheel or anything but nothing looked to be modified on the turbo.
The car just made a lot of power. Baffled me too. I was expecting maybe 400 at most on the standard correction and 340 ish mustang
Boost was ecu only. Had a stock map sensor on it.
Cory
Old 02-13-2013, 04:30 PM   #33
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
Originally Posted by wrxlaunch View Post
Kinda injectors?
Id1000 at 99%. Dw 300 pump
Old 02-13-2013, 04:32 PM   #34
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
This is consistent with the results I see on this setup. Those timing values are right about MBT timing from my experience.
If its holding 18.5 psi at redline then it sounds like there might be other mods involved.
Old 02-13-2013, 04:33 PM   #35
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Well that says something... I see about 80% max on 1000's.
What kind of MAF values did it reach?
Old 02-13-2013, 04:33 PM   #36
Shayhan27
Member#: 205906
05 WRX
Ok now the story is making sense.
I think the OP needs to be changed a little bit.
The OP reads as if it has a down pipe exhaust and AEM intake and nothing more.
Now were talking about a Fuel Pump and injectors. I mean I guess at those numbers you would be an idiot "Which most of the time I am" to not automatically know there were fuel upgrades.
Old 02-13-2013, 04:36 PM   #37
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
4.74 If I recall right
Old 02-13-2013, 04:40 PM   #38
Equilibrium Tuning
Member#: 26933
2006 STI
Fixed
Old 02-13-2013, 04:42 PM   #39
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
That's also higher than I normally see. That's around 345ish on an AEM I believe. 300 - 315 g/s is about the most I've ever seen a VF48 flow on stock manifolds and I don't think its significantly different than the VF43.
Somehow this car was able to flow more than what's normal which is interesting.
Old 02-13-2013, 04:47 PM   #40
jnorth85
Member#: 76785
2000 580Whp The RSTI
SRP
im guessing it has head work/cams possibly the owner isnt aware?
jnorth85 is offline   Reply With Quote
Old 02-13-2013, 05:07 PM   #41
Equilibrium Tuning
Member#: 26933
2006 STI
As far as the owner knows, the engine is all stock with about 90k miles on it. The car does also have an EWG. I don't believe the injectors are really maxed out, but rather the fuel pump is dropping pressure on the top end. I recommended he upgrade the pump or direct wire it.
Like we said, this one shocked us all here with the power it made and how easily it made it. Either its a freak, or there's something about the setup he's not telling us or doesn't know about.
-- Ed
Old 02-13-2013, 05:21 PM   #42
Nuke209
Member#: 108089
NF Performance
hm...upgraded vf internals...?
Old 02-13-2013, 05:22 PM   #43
toph
Member#: 78640
14 KTM SuperDuke
15 STi CWP | 02 STi Wagon
500LB/FT of torque is mental on a stock turbo, especially without an EL header. Is he going to run this in the 1/4? I think that right there is the proof.
toph is online now   Reply With Quote
Old 02-13-2013, 05:46 PM   #44
manitou
Member#: 193757
2006 XTI Limited
The stock map sensor is only good for 23-24psi that's not enough boost for these numbers. I'm convinced its over correction. I could see maybe 460-470 lbs on a stock motor buyer that's about it. PERIOD!! There are no freak motors like that its that's total BS!! Like I said what's up cams head work fueling.......wtf we're not idiots!! LOL
Old 02-13-2013, 06:17 PM   #45
Equilibrium Tuning
Member#: 26933
2006 STI
I'm not sure if he has any plans to drag it, but I can tell you with this power he would be trapping around 117mph. This is based on other cars with similar power levels.
-- Ed
Old 02-13-2013, 06:21 PM   #46
Equilibrium Tuning
Member#: 26933
2006 STI
Guys, it is what it is. These are the numbers this car put down and it surprised us all. We can all guess at why it did what it did, but at the end of the day we didn't see or find anything really unusual about it aside from the power it made. I have seen a few freak cars in the last 8 years of tuning Subarus, but I did not expect it from this car.
You guys can say whatever you want to say about the absolute numbers, but one thing I'll say about our dyno is that its very consistent. This car just blew away all the other VF E85 cars we've tuned and/or dyno'd here.
-- Ed
Old 02-13-2013, 08:59 PM   #47
CatfaceType-R
Member#: 81102
I know about the dyno recalibration, so bear with me.
Power goes up every year, not because of cheating or parts, but the belief in what is possible. The vf has more in it, that's my opinion.
Old 02-13-2013, 09:24 PM   #48
xXANCHORMONXx
Member#: 310590
This poor kid is gonna hit the track talking about his 400 horse stock motor and get spanked by a real 400 horse car. Dynojets are ****, period.
If you want to post these new higher dyno charts your gonna need to have stock dyno charts to show the gains because that will not change if a base run and a tuned run is done on the same type dyno.
364/440 is what the numbers should be on a mustang. Your old dyno readings for a stock Sti was 200/200 so now you can see the gains.
I'd go back to the old calibration, there's no point of having a high reading dyno.
xXANCHORMONXx is offline   Reply With Quote
Old 02-13-2013, 09:28 PM   #49
C J
Member#: 132587
2006 JrTuned STi
[email protected]
-- Ed
I trapped 117mph with my VF39 setup but I don't think my car made anywhere near these numbers. The highest I ever saw on a VD plot was 360whp/440torque.
C J is offline   Reply With Quote
Old 02-13-2013, 10:00 PM   #50
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
So a stage 2 with e85 can make 170whp over stock? That just doesn't seem right? I'm confused
Slimsti is offline   Reply With Quote
