Old 02-04-2013, 02:03 AM   #2726
SWP is Sexy
Member#: 302389
I'm a stormtrooper pewpew
I ran stage 1 relatively unmodded (stock, then catback) for over 10k with no problems, but again I would at least have the reserve cash to replace those parts
SWP is Sexy is offline   Reply With Quote
Old 02-04-2013, 03:42 AM   #2727
Dka67
Member#: 296721
11 5door
Originally Posted by thildwrx View Post
So in your guys opinion would a dp and ots stage 2 be relatively safe? Stage 2 is as far as i want to go, but also want to be safe.
That's something's that should be brought up with your tuner. It's what I told mine(COBB), and I'm happy with it!
Dka67 is offline   Reply With Quote
Old 02-04-2013, 07:49 PM   #2728
thildwrx
Member#: 303531
12 Subaru WRX
Ok I'm getting my oil change this week and my local tuner I trust uses royal purple but lately I've been reading negative reviews on it. I don't know if its just here say forum users. Anyone with actual knowledge or that actually uses it have any feed back or should I just go with the proven t6?
I'm probably just over thinking.
thildwrx is offline   Reply With Quote
Old 02-04-2013, 07:54 PM   #2729
mcuzzin
Member#: 292732
2007 FXT
SGM
1. You obviously don't trust him haha
2. T6 is proven, and cheaper. But! Not being able to see your location at the moment, ill tell you it is a bit thick for winter. It could just be me but my car had a hard time starting up when it was about 10*F. All in all, it still started and it was fine and dandy when the oil came to temperature.
3. You are over thinking
mcuzzin is offline   Reply With Quote
Old 02-04-2013, 08:01 PM   #2730
Celery GT-5
Member#: 98210
2016 Forester XT
CWP
I've been using rp for a while. I haven't had issues but I've heard some bad things. It apparently sheers down to 20 weight after 1000 miles or so but then thickens up later on I think...according to an analysis thread I was reading. Some nissan tuners I know really don't like the stuff. They said they have seen a lot of thrown rod bearings. I'm switching to something else on my next change...its probably fine but I've heard too many bad things.
Celery GT-5 is offline   Reply With Quote
Old 02-05-2013, 03:04 PM   #2731
_davin
Member#: 260501
2003 miata SE
Blurple
Are you referring to the T6? I can assure you it works just fine at forty below. And yeah it's significantly cheaper.
_davin is offline   Reply With Quote
Old 02-05-2013, 03:07 PM   #2732
Celery GT-5
Member#: 98210
2016 Forester XT
CWP
i can't imagine starting my car at 40 below..it doesn't seem to like starting when its in the single digits
does t6 hurt mpg at all?
being that its 5w40 it should be good for the same temps as 5w30 as underscoredavin said
Old 02-05-2013, 03:12 PM   #2733
Asharus
Member#: 276300
2015 Ford Mustang GT
Oxford White
i switched to T6 from 10W40 and 20W50 amsoil for winter purposes. i wouldnt mind using it throughout the summer either.
Asharus is offline   Reply With Quote
Old 02-05-2013, 03:28 PM   #2734
Celery GT-5
Member#: 98210
2016 Forester XT
CWP
will subaru really void your warranty for using 5w40?
Old 02-05-2013, 03:36 PM   #2735
_davin
Member#: 260501
2003 miata SE
Blurple
Theoretically if they actually tested the oil and could prove what it was, assuming you didn't tell them.
Old 02-05-2013, 03:38 PM   #2736
Celery GT-5
Member#: 98210
2016 Forester XT
CWP
well they might make you show some proof that you have been changing the oil in a timely fashion, like receipts
Old 02-05-2013, 04:04 PM   #2737
nightdown fox
Member#: 309636
2015 STI LE
WRB on Gold!
...which is why I buy my own oil and have the dealer change it, so there's always a record of it.
nightdown fox is offline   Reply With Quote
Old 02-05-2013, 04:09 PM   #2738
SWP is Sexy
Member#: 302389
Then theyll definitely know you didnt use 5w30 lol
Old 02-05-2013, 04:24 PM   #2739
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
Why would they void your warranty for using 5w40? It says in the owners manual that you can use 5w40.
xabre1200 is offline   Reply With Quote
Old 02-05-2013, 04:31 PM   #2740
_davin
Member#: 260501
2003 miata SE
Blurple
It specifically states 5w30, and has to meet some eco friendly standard.
Old 02-05-2013, 05:56 PM   #2741
Celery GT-5
Member#: 98210
2016 Forester XT
CWP
lol what a pain in the ass/waste of time/money
I think I'm gonna switch to castrol or something
Old 02-05-2013, 06:28 PM   #2742
rage-wrx
Member#: 258508
WR Blue
Page 11-13 in the manual states oil specs
It says 5W-30 or 5W-40 for temps below -30 to temps above 30
It also says 10W-30 or10-40 for temps -20 to 40 & above.
The manual also states that you can use any brand of oil as long as they are the same API classification & SAE viscosity as those recommended by Subaru. It also has to be energy conserving.
Rotella T6 meets all these requirements(5w-40,API-SM) except one,energy conserving.
rage-wrx is offline   Reply With Quote
Old 02-08-2013, 08:03 AM   #2743
rsutton1223
Member#: 280744
2009 CTSV 1,216whp
Black Raven
My car has started the transformation to Designo Magno Alanite Grey from AMG.
You can follow the process here ---> http://forums.nasioc.com/forums/show...364496&page=29
rsutton1223 is offline   Reply With Quote
Old 02-13-2013, 08:09 PM   #2744
mcuzzin
Member#: 292732
2007 FXT
SGM
Yep. What mods/map are you running? I am OTS Cobb stage2+ ACN91 with Cobb sf, invidia catted dp, 08 spt catback. Running Rotella T6. When it sat outside at 10F or below, the next morning it was slow to crank over but it still started. Only took a few extra seconds than normal...nothing crazy. Just felt like it didn't want to or it was pissed at me for trying to start it so cold. Once it started it was fine.
I can't imagine what -40F even feels like haha
Old 02-13-2013, 09:25 PM   #2745
_davin
Member#: 260501
2003 miata SE
Blurple
That's a matter of your starter and battery, not the oil, but a second or two is expected.
My setup is almost identical to yours.
Old 02-13-2013, 09:35 PM   #2746
Celery GT-5
Member#: 98210
2016 Forester XT
CWP
my car is sluggish to start when its cold, but it does start.
Old 02-14-2013, 01:27 AM   #2747
mcuzzin
Member#: 292732
2007 FXT
SGM
Touché
Old 02-14-2013, 03:45 AM   #2748
_davin
Member#: 260501
2003 miata SE
Blurple
Why have I never heard of any new WRXs using STi rear struts?
Old 02-18-2013, 06:54 PM   #2749
fl4tpower
Member#: 282664
2011 STi ltd Stage 2
Obsidian Black Pearl
So I'm running my STi stg 2 w/ ebe, cai, and turbo inlet on a stock fuel pump. Going to Agile auto in Maryland to get a pro tune w/ one step colder NGKs and a perrin ebcs. Should I throw the new DW65c in the tank before I get tuned? Do I need it? Peaking the car out around 19-20psi for my tune. Thanks
fl4tpower is offline   Reply With Quote
Old 02-18-2013, 07:02 PM   #2750
PearlRex11
Member#: 284420
2011 WRX Sedan
I would say you might as well, even though our cars already pretty much max out the injectors with stg2, I don't know that it would hurt anything. Then you would just have to put in bigger injectors when you are ready.
PearlRex11 is offline   Reply With Quote
Differences of 2011 wrx motor and 2011 sti motor stpkenton Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 03-06-2012 11:03 AM
Differences of 2011 wrx motor and 2011 sti motor stpkenton Newbies & FAQs 3 05-12-2011 09:27 PM
2011 Subaru shifter fitment! All TWM Shifters still fit! TWM Performance Vendor Announcements 14 02-28-2011 03:27 PM
iPod 3g DLO Jam Jacket (clear) and Radtech 3g Indigo Podsleev 10gb/15gb agentmaxwell Private 'For Sale' Classifieds 1 05-24-2006 07:41 PM
Attn: Clayton, Ben and all others involved in the 6MT discussion. sherifx Mid West Subaru Owners Club Forum -- MWSOC 1 07-31-2002 03:00 AM
