Old 02-06-2013, 12:47 PM   #1
yama200
Member#: 335672
Default Just pulled my carpet, what upgrades can I do while it's out?
So had to pull the interior bc I dunked my 03 WRX into a DEEP puddle durring a storm and had water inside the rear floorboard. The stock insulation got soaked and absorbed a TON of water so I'm thinking of stripping it off of the carpet if it doesn't dry well.
Pulled it yesterday so I'm driving it with the driver seat only (more fun than it sounds actually) while carpet dries. What can I do while it's out? What are my options/best deal on aftermarket insulation?
yama200 is offline   Reply With Quote
Old 02-06-2013, 12:57 PM   #2
silvercookie
Member#: 180033
2005 WRX
Go to home depot or lowes and get some Quick-seal. it is ~45mil sound deadner pretty much. and regardless of what people say it does not smell. should run you about $16 for a 6"x 25ft roll.
Make sure it is the aluminum backed one also.
I think they also sell sheets of closed cell foam you can lay down, but it doesn't have an adhesive on the back.
silvercookie is online now   Reply With Quote
Old 02-06-2013, 03:20 PM   #3
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
You can add sound deadening. That's really the only "upgrade" you can do. There are several threads around showing the pro's and con's of doing it and with what material.
Old 02-06-2013, 07:30 PM   #4
wrxkid157
Member#: 201046
2004 WRX
^^^^^ that! and run speaker wire if you plan on running a sub or amping your speakers. make for a clean install.
wrxkid157 is offline   Reply With Quote
Old 02-06-2013, 09:40 PM   #5
predent
Member#: 171606
2006 Saab 9-2X Aero
You might as well upgrade the turbo. It has nothing to do with the carpet, but if you have the time...
predent is offline   Reply With Quote
Old 02-06-2013, 10:08 PM   #6
minorc
Member#: 208229
2010 STi
HAHAH!!
minorc is offline   Reply With Quote
Old 02-07-2013, 03:05 AM   #7
mkimmey
Member#: 330924
I lol'd.
mkimmey is offline   Reply With Quote
Old 02-07-2013, 08:17 AM   #8
DoogieSTi
Member#: 247023
2007 STi
Sound logic...
DoogieSTi is offline   Reply With Quote
Old 02-07-2013, 08:49 AM   #9
WiechWRX
Member#: 249659
2012 WRX Limited
Replace it with shag carpet. /thread
WiechWRX is offline   Reply With Quote
Old 02-07-2013, 09:23 AM   #10
KrazyKarl
Member#: 94706
2007 STI
1995 Miata
Seam welding?
Just did this on my soon-to-be track car miata and it made quite a difference in chassis rigidity.
KrazyKarl is online now   Reply With Quote
Old 02-07-2013, 09:29 AM   #11
subieguy87
Member#: 153412
1998 Impreza wrxRS
Originally Posted by KrazyKarl View Post
Seam welding?
Someone finally said it!
subieguy87 is offline   Reply With Quote
Old 02-07-2013, 09:57 AM   #12
luan87us
Member#: 335013
2013 Premium WRX 5dr
This! I'm going to get some of those quick-seal stuff to deaden my doors when I install some speakers in them.
Old 02-11-2013, 02:51 PM   #13
CobbWRX
Member#: 310040
2004 WRX and 15 sti
Went to pick some up today it was 15 feet for 18
CobbWRX is offline   Reply With Quote
Old 02-11-2013, 04:36 PM   #14
damonhimself
Member#: 235835
2011 WRX 5DR
Put some of this stuff down there. It's the best thing ever!
Last time i went to take my boat out, I found that someone installed a screen door on the bottom of my boat. My first thought was "not again!" I sprayed 37 cans of this stuff on there, and later that day I caught a delicious bass.
damonhimself is offline   Reply With Quote
Old 02-11-2013, 04:59 PM   #15
EROCS04SBRUSTI
Member#: 234397
2004 WRX STI WRB
15 DGM FXT
Run wires for 2 amps and 2 18'' woofers and dynamat and play this!lol
EROCS04SBRUSTI is offline   Reply With Quote
Old 02-11-2013, 05:49 PM   #16
jawsoflife603
Member#: 344912
2011 Subaru
blue
Nahh don't do anything, just buy this http://www.quirkworkssubaru.com/used...8b77ff187c.htm
jawsoflife603 is offline   Reply With Quote
Old 02-12-2013, 11:08 AM   #17
yama200
Member#: 335672
You guys are ****ing hilarious, really! I did everything you suggested-actually cut out the floorboards and replaced with screen sprayed with flex seal-saved a lot on weight! I also swapped the front seats for lawn chairs and ditched the rear seats and filled the space with extra speakers!
Old 02-12-2013, 11:50 AM   #18
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Old 02-14-2013, 01:16 AM   #19
Taylorhengen
Member#: 347005
Hi,
Yeah I agree with yama200 ..you can go for it.
Taylorhengen is offline   Reply With Quote
